Owen Y Posted March 27, 2017 Share Posted March 27, 2017 (edited) (This discussion, has been migrated from @Sir Triode's Affordable Ultrasonic RCM from Poland thread.) This project was inspired by @EV Cali's DIY machine & advice from biochemist guest110 on Audiokarma. Based on the same 6L China-made Ultrasonic cleaner tank (avail on ebay.au), with a bit of engineering input, we rigged up a simple & affordable-to-manufacture prototype, using sheet stainless steel, a locally avail inexpensive rotisserie motor (same as @EV Cali's), a rod, spacers & a couple of record clamp nuts. here's the prototype running..... Cheers, Owen http://darklanternforowen.wordpress.com/ Edited November 12, 2017 by Owen Y 3 Link to comment Share on other sites More sharing options...
Owen Y Posted March 27, 2017 Author Share Posted March 27, 2017 (edited) PS. With the the 0.1% detergent concentrate mix, you can see the surfactant action - nicely filming over the record surface. Cheers, Owen http://darklanternforowen.wordpress.com/ Edited March 27, 2017 by Owen Y 1 Link to comment Share on other sites More sharing options...
Owen Y Posted March 27, 2017 Author Share Posted March 27, 2017 A bit more info: Fluid mix: For starters, I'm using a water + Triton X-100 detergent/surfactant concentrate. (I haven't checked if this is avail downunder, mine came from USA via a pal). Drying: So far, in our low 20's C summer weather, using a water + detergent/surfactant mix, then air-drying is fast. (20-30 min?) Plain water doesn't film over the vinyl & takes much longer to dry. .I have a vacuum RCM but have not bothered using it for drying after US cleaning. Right now, I'm using just carbon-filtered (drinking) water. Static: Vinyl is a poor conductor but water is a good conductor, so simply rinsing will reduce static. Wiping a record, is not such a good thing, if you want to avoid static-electricity. And I believe that it is good to use a non-ionic, neutral pH detergent for starters, to avoid residual static charge. (There is also a theory that a thin residual film of detergent left on the vinyl, after cleaning, aids groove tracing - I have to say it certainly sounds that way, signif more dynamic range, more energy..... ) Cheers, Owen http://darklanternforowen.wordpress.com/ Link to comment Share on other sites More sharing options...
rocl444 Posted March 27, 2017 Share Posted March 27, 2017 i bought 500ml triton x-100 in NZ just over a year ago. so for a 0.1% mix what is your process @Owen Y ? Link to comment Share on other sites More sharing options...
Owen Y Posted March 27, 2017 Author Share Posted March 27, 2017 Hi @rocl444 - I am avoiding alcohols for starters, so I do a 10% mix-down first as best as you can (it does not dissolve easily in water) - leave in frig overnight for it to dissolve - pretty much as per guest110's advice below: Quote ....one easy method is to just mix a teaspoon of 100% Triton with a teaspoon of distilled water and work it in slowly to dissolve. Gradually keep adding more teaspoons of distilled water and mixing until a total of 9 teaspoons have been added (roughly a 10% detergent stock). I keep this 10% stock in a used dish soap bottle You want a final concentration of detergent around 0.1 to 0.2% so this 10% stock gets diluted 50 to 100-fold in the final working wash solution. Cheers, Owen http://darklanternforowen.wordpress.com/ Link to comment Share on other sites More sharing options...
Owen Y Posted March 27, 2017 Author Share Posted March 27, 2017 (edited) As said, in order to make it economical (for us & any other semi-DIYers) we are going to laser-cut a small batch, rather than one-off fabricate. If interested, there will be some postage & you will have to buy the cleaner (ebay.au A$172 - 253) & motor (Kogan A$25).. The cleaner that I purchased: http://www.ebay.com.au/itm/Digital-Ultrasonic-Cleaner-6L-Stainless-Steel-Heater-Timer-Industrial-Grade-6L-/302040010527 (Note - 240v version.) Let me know or PM if you might like to join. Cheers, Owen http://darklanternforowen.wordpress.com/ Edited March 28, 2017 by Owen Y Link to comment Share on other sites More sharing options...
Blade74 Posted March 27, 2017 Share Posted March 27, 2017 What sort of money Owen?Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Owen Y Posted March 27, 2017 Author Share Posted March 27, 2017 Hi @Blade74 - aiming for comfortably under A$200, hopefully $175 - depending on the batch size & laser-cutting.. Cheers, Owen http://darklanternforowen.wordpress.com/ Link to comment Share on other sites More sharing options...
Owen Y Posted March 27, 2017 Author Share Posted March 27, 2017 The baseplate comes in 3 pcs, with in-built nuts for super-easy assembly (just 4 screws, 1 allen key needed), attach the motor (3 screws), slide whole assembly onto the tank, done.Load the records & spacers, insert into motor drive, drop into the tank.Switch on motor, switch on tank, set timer, start.(No heating.)Cheers, Owen http://darklanternforowen.wordpress.com/ 1 Link to comment Share on other sites More sharing options...
Owen Y Posted March 28, 2017 Author Share Posted March 28, 2017 (edited) Note - the key dimension, for our fitting to attach nicely, is the tank-top width - 174mm approx (6-3/4" to 6-7/8"). And be sure that it is 240v. Cheers, Owen http://darklanternforowen.wordpress.com/ Edited March 28, 2017 by Owen Y 1 Link to comment Share on other sites More sharing options...
Leinster Lad Posted March 30, 2017 Share Posted March 30, 2017 Learnerd friends, it is now time for me to ask some advice. I have now got myself a DIY US cleaner. Brilliant Rotator from @Maggie and a garden variety 10L US from evil bay. Cleaned a bunch of records today. Water, 5% Isoprop, 5mls of rinse aid and 5 mls of liquid laundry detergent. Water @ 40 Degrees Cycle time of 15 minutes. Air dried Not stunned or amazed with the results. Certainly no "inky black quietness" I still get a few crackles and pops, and also some kind of "groove rubbing" noise in places, on some records. Others are quieter, but still not silent. Am I missing something or are some records just "noisy" ?? 1 Link to comment Share on other sites More sharing options...
EV Cali Posted March 30, 2017 Share Posted March 30, 2017 (edited) 9 hours ago, Leinster Lad said: Learnerd friends, it is now time for me to ask some advice. I have now got myself a DIY US cleaner. Brilliant Rotator from @Maggie and a garden variety 10L US from evil bay. Cleaned a bunch of records today. Water, 5% Isoprop, 5mls of rinse aid and 5 mls of liquid laundry detergent. Water @ 40 Degrees Cycle time of 15 minutes. Air dried Not stunned or amazed with the results. Certainly no "inky black quietness" I still get a few crackles and pops, and also some kind of "groove rubbing" noise in places, on some records. Others are quieter, but still not silent. Am I missing something or are some records just "noisy" ?? I would say "stunned and amazed" is probably going too far ,in regard to what result you can expect. Pleasantly surprised is more likely. An Ultrasonic cleaner will not repair damage or improve the original recording,it will only remove dirt and contaminants on old records and release agent on new records. If the record looks undamaged and there are still a few pop and crackles, give it one more go and see if that gives further improvement. Some records are "noisy" but I notice the first record on your rotator is DSOTM and Floyd pressings are normally very good and silent. Some of what you are still hearing could be caused by your stylus or arm / cart set up. I am in Queensland and after a record has been breathed on and touched a number of times over a thirty to forty year period, the humidity can help form a film of mould and muck on the surface of the records. Cleaning with a URC will bring a big improvement to these records making the sound fuller and quieter. Also I recently purchased a new 12" 45 single by John Butler ,whose recordings are normally of a high quality ,plus as a 45 there was lots of room for the grooves. When I played it there was background hiss the entire length of the recording. To say the least I was extremely disappointed, cleaning with my URC removed all of the hiss. I use more or less the same cleaning procedure as yourself apart from the liquid laundry detergent. I would not use liquid laundry detergent as I do not believe it is needed and it may introduce contaminants that stay on the records and give some noise. I also note you have gone for the 10L bath when most of us are using the cheaper 6L that your Rotator is intended for. Not really a problem but you are using a lot more chemicals without gaining the advantages of being able to clean more records at a time or more space between the records that the 10L bath could give. My experience is cleaning with a URC is definitely worth the effort and reasonable cost and I am now reluctant to play a record I have not yet cleaned with the ultrasonic bath. Edited March 30, 2017 by EV Cali 4 Link to comment Share on other sites More sharing options...
PKay Posted March 30, 2017 Share Posted March 30, 2017 Owen, I'm very interested. Link to comment Share on other sites More sharing options...
Owen Y Posted March 30, 2017 Author Share Posted March 30, 2017 Hi @Nap250 - I have you on our 'notify' list Parts from China about a fortnight away Also laser cutting & an injected moulded coupler ( a bit of engineering involved but end-cost is good. Cheers, Owen http://darklanternforowen.wordpress.com/ 1 Link to comment Share on other sites More sharing options...
Owen Y Posted March 30, 2017 Author Share Posted March 30, 2017 Hi @Leinster Lad - good work - however i would echo @EV Cali's thoughts here - In particular, Liquid Laundry Detergent I believe can contain, in addition to surfactant/detergent & enzymes - strong bleach chemicals, optical whiteners, bulking/binding agents, fragrances, etc. Best avoided - get yourself some Triton X-100 concentrate or similar. Rinse Aid is not needed if you have detergent, it probably has other chemicals also best avoided, eg for removal of lime deposits. Heating is not absolutely necessary in a US cleaner, the cavitation process tends to heat the fluid anyway I've found, maybe 5-10deg C over 15mins. If older/used records, some clicks, pops, scratches, will of course not be removed by any cleaner, ie. vinyl damage, but mostly removed I've found, or reduced. Sometimes multiple or longer duration cleans are beneficial. Cheers, Owen http://darklanternforowen.wordpress.com/ 2 Link to comment Share on other sites More sharing options...
ABG Posted March 31, 2017 Share Posted March 31, 2017 @Leinster Lad Some records are inherently noisy. You can minimise the noise, but you'll never get rid of it. Some records are produced exceptionally well and will play without a hint of noise. Most fall somewhere in between. My experience is that all of them are improved by cleaning in an US cleaner. The results are significantly improved (and often drastically improved) by running the still wet records fresh out of an US cleaner through a vacuum type RCM. I tried letting records air dry when I first got my US cleaner - let's face it, it's less work - but now I run them all through my Record Doctor V after a bath. I reckon the US cleaner loosens the crud, the RCM sucks it away from the grooves. See if you can borrow one to try for yourself. I reckon you'll be pleasantly surprised. 3 Link to comment Share on other sites More sharing options...
Leinster Lad Posted March 31, 2017 Share Posted March 31, 2017 Thanks @ABG and @Owen Y I cleaned a bunch more records today, difference being that I did not turn on the inbuilt heater and cleaned for 30 minutes per cycle. Records are much quieter ( some still not perfect ) so generally happy with the results now. Over the coming few batches i'll experiment with "the brew" and yes, having the 10L tank certainly uses more ingredient ( but in the scheme of things, it is really not much ) And I can see why some people are exploring a filter set-up ! 3 Link to comment Share on other sites More sharing options...
zenikoy Posted March 31, 2017 Share Posted March 31, 2017 1 hour ago, ABG said: @Leinster Lad Some records are inherently noisy. You can minimise the noise, but you'll never get rid of it. Some records are produced exceptionally well and will play without a hint of noise. Most fall somewhere in between. My experience is that all of them are improved by cleaning in an US cleaner. The results are significantly improved (and often drastically improved) by running the still wet records fresh out of an US cleaner through a vacuum type RCM. I tried letting records air dry when I first got my US cleaner - let's face it, it's less work - but now I run them all through my Record Doctor V after a bath. I reckon the US cleaner loosens the crud, the RCM sucks it away from the grooves. See if you can borrow one to try for yourself. I reckon you'll be pleasantly surprised. I absolutely concur. 1 Link to comment Share on other sites More sharing options...
Owen Y Posted March 31, 2017 Author Share Posted March 31, 2017 13 hours ago, Leinster Lad said: And I can see why some people are exploring a filter set-up ! Am interested in results from anyone filtering their tank fluid - say using paper coffee filters or something more sophisticated. Cheers, Owen http://darklanternforowen.wordpress.com/ Link to comment Share on other sites More sharing options...
Owen Y Posted March 31, 2017 Author Share Posted March 31, 2017 (edited) 14 hours ago, ABG said: @Leinster Lad Some records are inherently noisy. You can minimise the noise, but you'll never get rid of it. Some records are produced exceptionally well and will play without a hint of noise. Most fall somewhere in between. My experience is that all of them are improved by cleaning in an US cleaner. The results are significantly improved (and often drastically improved) by running the still wet records fresh out of an US cleaner through a vacuum type RCM. I tried letting records air dry when I first got my US cleaner - let's face it, it's less work - but now I run them all through my Record Doctor V after a bath. I reckon the US cleaner loosens the crud, the RCM sucks it away from the grooves. See if you can borrow one to try for yourself. I reckon you'll be pleasantly surprised. Yes vacuuming is worth doing for sure. OK if your live in a static-prone environment, then maybe you need to take care with any friction-brush type vacuum m/c on your records. Also, I know we're driven to obsession about water purity, but a (filtered tap) water rinse after cleaning can only be beneficial - followed by vacuuming if you like. Cheers, Owen http://darklanternforowen.wordpress.com/ Edited March 31, 2017 by Owen Y 1 Link to comment Share on other sites More sharing options...
ABG Posted April 1, 2017 Share Posted April 1, 2017 31 minutes ago, Owen Y said: Am interested in results from anyone filtering their tank fluid - say using paper coffee filters or something more sophisticated. Cheers, Owen http://darklanternforowen.wordpress.com/ Hi Owen, I use a fish tank filter (http://www.ebay.com.au/itm/Aquarium-External-Canister-Filter-Aqua-Fish-Water-Tank-Sponge-Pond-400L-H-/131374919147?rmvSB=true) based on advice provided by a fellow SNA'er and info I read on the VPI forums. Every time I change the water, I clean out the filter. The amount of black crud that comes out makes me glad I'm using it. Cheap insurance against those pieces of crud potentially sandblasting my records during the cavitation process. 4 Link to comment Share on other sites More sharing options...
Owen Y Posted April 9, 2017 Author Share Posted April 9, 2017 Hi @ABG - apologies, I thought I had replied.... A goood thought, I have yet to test out filtering. Many Thanks. Cheers, Owen http://darklanternforowen.wordpress.com/ Link to comment Share on other sites More sharing options...
Owen Y Posted April 9, 2017 Author Share Posted April 9, 2017 Minor update:Sorry about delay, some spacers have arrived, enough for a quite few cleaner kits.These are semi-soft spacers, which should work well, without damaging record labels.We have had some discussion here about the size of the spacers.Record labels are 100mm diameter.These spacers are around 75mm diameter.After testing, we chose these smaller spacers, ie not same diameter as the record label - as splashed water tends to be drawn up unseen by capillary action between label & spacer. In practice, we think it's better that the record label is always visible, as it's easier to adjust water level to suit.Laser cutting of 1st batch of stainless metalwork should be done within a week.Injection-moulding, for the plastic driver adapter for the motor shaft, should be close behind. Cheers, Owenhttp://darklanternforowen.wordpress.com/ 2 Link to comment Share on other sites More sharing options...
ABG Posted April 9, 2017 Share Posted April 9, 2017 Hi Owen, I would consider getting at least one spacer that's 100mm and use that to adjust your water level rather than using your record labels. It's something you'll be doing on an almost daily basis in summer - you'd be surprised how much water evaporates in warmer weather - and I wouldn't want to be using my record labels as a depth gauge. Mine has a mark showing the level it needs to be filled up, but I still fine tune the level with the spacer and no record on mine. Despite all the precautions, I still occasionally get a bit of water on the labels. Most of the time I just wipe it off with no harm done. Occasionally it causes the label to slightly bubble (maybe 1% of the records I clean). I consider it a small price to pay for having clean records with minimal effort. 2 Link to comment Share on other sites More sharing options...
Owen Y Posted April 9, 2017 Author Share Posted April 9, 2017 Fair enough. But I would just use your eyes to gauge water level - it doesn't need to be super close to label, say 5mm min. There could be some dirt, residual noise at the end of the runout groove but....it doesn't matter. Haven't wet a label yet Cheers, Owen http://darklanternforowen.wordpress.com/ 3 Link to comment Share on other sites More sharing options...
