Adsyadsman
AT95E cart modding - tips on how to
Hi all,
Sorry if this is in the wrong section, but I wanted to reach out to any of you happy modders out there that can hopefully shed some insight...
After an accidental incident a member of my family had with the needle on my TT, I need to order a new stylus (needle arm snapped off completely off the cantilever)
I currently am using a AT95E cart, and since I need to replace the stylus, thought I'd get the ATN95EX dark red stylus over the standard ATN95E green one.
The only difference I can see is (apart from being a few $$ more) is the diamond tip is smaller on the EX being 0.3 x 0.7 compared to the stock 0.4 x 0.7 on the green E, so hopefully this should translate into better tracking and 'sound'.
But, whilst I wait for this, I thought I should see if I can do some quick mods to improve the cart... so after googling on the interweb there are quite a few 'experimentalliers' that have tried different ideas to squeeze more audio joy from the AT95E with varying amounts of success.
Im not too keen on the whole making up custom wood frames and sticking tape, blu-tak, etc on the outside of the cart as Im trying to keep the 'factory fresh' look, and as the TT is a bit of a show-piece, the MRS wouldnt be too keen on a cruddy looking 'thingy' stuck on the end of the tonearm...
So, I read about potting the cart with wax or lipstick, etc, to help deaden resonances. And with the term 'simple' attached in the sentence, this caught my attention.
But how?
Is it filling the internals of the plastic mount that the cart body screws into (there are a couple of voids that could be filled), or somehow filling the internals of the cart body itself?
If its the latter, I cant see how this would be 'simple' as the cart body is housed in a 'one piece' pressed metal enclosure, with only a seam on the top, which I would be very hesitant about trying to pry open to reveal the guts.
So has anyone done this 'potting' technique? Could you please explain what is involved, and probably more importantly, was it worth it? Did it bring more life into the AT95E?
And any other simple mods worth trying? (another one I think I read was blu-tak between the cart body and stylus)
Not too keen on filling the needle tip (another mod I read about) too delicate for me to attempt...
Eventually, I'll probably upgrade to a AT100E cart as at least then it opens they way to more stylus options later, but for now, if I can squeeze some more out of the AT95E...
Sorry for the long thread, I do tend to dribble a bit when trying to explain something.
But looking forward to any helpful advice.
Thanks.
Hi
Why not just purchase the AT100E cartridge as it is only a little over $100 in many places ....
JJ
Hi JJ,
Thanks for your reply.
Yes, I was seriously considering that.
But I can get the ATN95EX for under $40 and the AT95E cart I pretty good. I'd like to keep it in service if I could and use the additional $$ on more discs to spin for now.
Eventually, yeah, a cart upgrade is definitely on the cards, so the AT100E will be on the shortlist to be the new pickup (or may splurge on the 120), but for now that lil AT95E is just crying out to be used.
BTW, my TT is a PL-518x, a great solid unit, but on the lower end of the budget scale so I can't justify with the minister of finance throwing too much $$$ at it.
Thanks again.
Hi
A cheap upgrade is that thin foam, that is a little thicker than plastic, and cutting a piece and placing between the cartridge and headshell....
JJ
Thanks JJ,
I've got some of that self adhesive speaker sealing foam that's about 2-3mm thick, but it compresses fairly easily.
I'll try that also.
Cheers.
Interesting thread
The 95E is cheap enough at $43 delivered to take a few risks with.
I keep 1 on hand for emergency duties and test purposes .
I put one on a Strathclyde TT I lent to @jamesg11 and it served him well for over a year on an SME arm.
 The cart punches way above its price point which might not be saying much!
Thatsaid you should just upgrade your cart.
@Adsyadsman suggestion sounds safe or a tiny strip of ultra thin ply.
On ‎16‎/‎03‎/‎2017 at 9:02 AM, Adsyadsman said:
Hi all,
But how?
Thanks.
I have been playing around with AT95E mods too.  I now have my AT95E glued into a wooden body, I have installed a Jico Hyper Elliptical stylus (trimmed of the surrounding plastic body) and have loaded it to 36K.  I also use a 2.25g tracking force. I am blown away how good this sounds. It is punchy, detailed, no audible distortion on inner grooves or with the SSS on vocals.  I put it up against my AT OC9/II running through a Blue Cinemag SUT, its every bit as good and a little bit more dynamic.  It only loses out a smidge on midrange and air.  Not much in it and way cheaper.
I'm putting it through a Schitt Mani with a Swagman PSU, which is brilliant... I'd have to  spend $2,500 on something like an Avid Pulsus to hear an improvement I think.  I have also tried various phono stages, Cambridge 640p, Project Box SE, Lounge, Les Box Modded valve Yaquin MS 23... the Mani / Swagman beats them all.
Good luck.
1 hour ago, nkoulban said:
Good luck.
I've got a VL that I got the Wooden body for and trimmed all the plastic away, leaving just the plug. Cleaned it up like you wouldnt believe.
When I read about modding/potting this cart, I was considering doing the same and buying a wood body, but then I came across a used Clearaudio Concept MM cart. It uses a 95 type stylus with trimmed ‘wings’, which is really easy to do (I practiced on an old stylus). This suits me perfectly as it rules out expensive accidents! ATM I’ve still got the standard ‘black’ stylus mounted (which even the standard ‘green’ stylus improves upon apparently). Compared to the AT95e, the Clearaudio sounds a bit more refined, and any IGD or sibiliance I used to hear is gone. I might lash out and try an EX stylus next!
Given the phono stages that you've tried - and given you're in Melbourne - I'd be very interested in bringing over my 'Muse' phono stage for you to have a listen to.
PM me if you're interested.  (It will cost you a lot less than $2,500 if you like it!  :) )
Try the resistive loading. I used 2 RCAs and soldering in resistors.  This transforms the AT95s tonal balance for me from a bit harsh and tipped up to smooth and punchy.
Hi Andy, thank you for your generous offer.  Unfortunately the bank of wife has implemented cost controls on me for a while.
:lol:
Ah yes, I know the feeling. The bank of wife has seized both of my assets as collateral...
Meanwhile here's how Stanley Enginneering De do a wood body conversion on AT95E, the process for their body on Tonar Diabolic very similar.
http://info.stanley-engineering.de/wordpress/?page_id=128
(Tonar Diabolic? That's another bargain MM cartridge, need more info? I'll post!)
a showcase of their other bodies including a nude plastic stylus assembly cut away, (DIY if you have a steady hand!) on a Audio Technica AT95E
regards Ian
    • By denimhunter
      Item:         AUDIO TECHNICA AT1503iiia tonearm
      Price:       $1050
      Item Condition: very good
      Reason for selling:
      Audio Technica reissue of AT 1500 mk3, 10 inch, broadcast tonearm with removable headshell originally designed for use by Japanese broadcaster NHK.  Med-High mass transcription tonearm suitable for low compliance cartridge. Suitable for SPU as well.   The arm is selling for over $2,200 on eBay and in the US. Original din to RCA tonearm cable is Included.
      I am also selling on a separate listing, Aurealis din to rca cable which will work well with this tonearm.
      Refer to the following for information:
      https://www.lpgear.com/product/AT1503IIIA.html
    • By leqt1969
      Item: Audio Technica ATH-W1000Z headphones
      Price: $320 + postage
      Item Condition: Excellent
      Reason for selling: Too many headphones
      Up for sale is an like new Audio Technica ATH-W1000Z headphones. Comes with every thing in box. This is current model and still for sale at most high-end headphones retailers.
      Plenty of reviews. google to find out more.
      Link to specs:
      https://addictedtoaudio.com.au/products/audio-technica-ath-w1000z-audiophile-closed-back-wooden-headphones?gclid=EAIaIQobChMI2dTtoMjf4AIVyw0rCh1zoAHUEAAYASAAEgKRfPD_BwE
    • By Yngvi
      Item: Denon DP-70M Turntable  -  100 Volt Japanese Model
      Price: $350.00
      Item Condition: Good
      Reason for selling: Thinning out the vintage herd
      Extra Info: Turntable is is In good condition except for the chip on the front of the unit and a hairline crack on the back of the base. Cover is in good condition.  Includes a MM Technica 205C IIX cartridge
      Pick up only !!
    • By deb_stero_net
      Item: Audio Technica AT95EX/HSB Cartridge & Headshell Combo
      Price: 150 + shipping
      Item Condition: New (Unopened)
      Reason for selling: Not needed
      Dual Moving Magnet Stereo Phono Cartridge with Elliptical Diamond Stylus
      The heritage of the AT95EX follows years of success of the AT95E associated with modern materials aimed at producing high performance cartridges at a reasonable price. This 0.3 x 0.7 mil elliptical cartridge fits half-inch mount turntables. It features durable dual-magnet design, excellent channel separation and low distortion for outstanding tonal quality.
      Frequency Response: 20-22,000 Hz Channel Separation: 20 (dB at 1 kHz) Vertical Tracking Force: 1.5-2.5 g (2.0 g standard) Stylus Construction: Bonded round shank Stylus Shape: 0.3 x 0.7 mil elliptical Mount: Half-inch Replacement Stylus: ATN95EX
    • By Tobes
      Item: Audio Technica ART-9 MC cartridge
      Price: $500
      Item Condition: Excellent ~150hrs
      Reason for selling: Sold my tonearm, raising funds
      The Audio Technica ART-9 is a top flight moving coil from one of the longest established cartridge makers.
      This is an exemplary tracker and plays all types of music beautifully, extracting excellent detail with expansive involving sound.
      Do some forum searching on Audiogon and the like - where comparisons have been made to multi $K cartridges.
      You can find the specs here: https://audio-technica.com.au/products/at-art9/
      As you can see the RRP is $1499 so this is quite a saving for low hours example.
      Type Magnetic Core Moving Coil
      Frequency Response 15 to 50,000 Hz
      Channel Separation 30 dB (1 kHz)
      Channel Balance 0.5 dB (1 kHz)
      Coil Impedance 12 ohms (1 kHz)
      DC Resistance 12 ohms
      Tracking Force 1.6 to 2.0 g (standard 1.8 g)
      Vertical Tracking Angle 23 degrees
      Recommended Load Impedance Min 100 W
      Coil Inductance 25 mH (1 kHz)
      Static Compliance 35 x 10 – 6 cm / dyne
      Dynamic Compliance 18 x 10 – 6 cm / dyne (100 Hz)
      Output Voltage 0.5 mV (at 1 kHz, 5 cm/sec)
      Stylus Shape Special Line Contact Stylus
      Cantilever 0.26 mm Ø solid boron
      Stylus Construction Nude square shank
      Mount 1/2” centers
      Dimensions 17.3 (H) x 17.0 (W) x 25.6 (L) mm
      Weight 8.5 g
