PeteD
Sonica DAC Cancelled (Unofficial)
Sorry I have nothing to add. I was promised some information that evidently hasn't been forthcoming.
No worries Marc - thanks for the response.
http://archimago.blogspot.com.au/2017/06/measurements-oppo-sonica-dac-ess-sabre.html
found this link testing the D/A of the OPPO Sonica converter.
OPPO Australia finally nailed its fate here in Aust.  But this link gives you the performance measurements of the this unit compared to the a few others too.  Note that even though there's what's claim to be a superior latest ESS 9038 chip and a whole different analog and PSU circuitry the measurements between the Sonica and the OPPO 105 are notnthat different.
Excellent review !
Thanks a lot for the link.
I think I will take anxiolytics :lol: until I have the Sonica Oppo in my hands, this should happen in a few days.
Regards
Edited by arpavieja78
3 hours ago, arpavieja78 said:
Excellent review !
Regards
I had to google anxiolytics.....:blush:
let us know now what you think when you get it.
Check out Chord's latest presentation at RMAF 2017. Measuring steady state conditions doesn't  tells us enough about how they actually sound
Long but well worth the time
Having said that, the 9038 in the Oppo 205 sounds noticeably better than the 105 and HA1 in the store when I was using headphones.
And is it true that the Sonica doesn't get Roon support - but the 203/205 already does. Maybe there is some truth to the Sonica being discontinued.
The order has arrived:
Oppo Sonica Dac/Streaming
Ortofon 2M Red cartridge MM
Dayton SPA 250 Amplifier  plate subwofer
I had a listened to the HA1 sample at a show,  the biggest injustice that they did to that unit was to use a standard mechanical volume pot.   It sounded nothing like the 105 with the same headphone at the same volume using the same tracks in a USB stick.  In the same show I also listen to a Stax 009 with a highly sort after tube electrostatic driver that used a Alps k50 pot....i was disappointed for life and will no longer pursue a Stax 009.
when you used totally different psu designs and totally different opamps,  I doubt that the unit will sound the same, even if they measure almost identical the aural presentation is going to be expected to different.   That said the OPPO products  measure extremely well under test.   And I'm greatful the Sonica didn't use a mechanical volume pot!
Thanks for the likes " :)
here another review.
For now I can only anticipate that it is superlatively built. The finishing is impeccable and it weighs its own, they have not lowered costs by saving on materials.
I must get the proper fuse before connecting it to the electrical network. Here we have 220 volts, 50 HZ.
https://headfonics.com/2017/05/the-sonica-dac-by-oppo/
I forgot to mention that Oppo responded immediately to the criticism of lack of remote control
It was originally designed to be used through the application on a smartphone or tablet.
But this is not as fast and comfortable as a dedicated CR, for a small surcharge, they send it.
And I asked for it, it's not the control of the Prima Luna amplifier, but it's small and pretty ...:aww:
I would use a tablet/iPad like I use the 105.   The remote I got with the 105 never get used
9 hours ago, Addicted to music said:
Usaría una tableta / iPad como uso el 105. El control remoto que obtuve con el 105 nunca se usó
Oh my God, then I've thrown away my money ?:emot-bang::lol:
I think for 35 US $ I will be able to put it to good use when I do not need to use the app.
For example, when I use a CD transport and the Oppo Sonica as a DAC, why do I want to use a smart phone?  :baby:
You need wifi to used the phone or tablet.
You can use the smart phone but I haven't seen the user interface on a android.  The Apple iPhone is a little difficult to use; naturally it's not as comprehensive like a iPad/tablet becuase of the screen size.  The 105 has a "pure audio" mode and it shuts down the screen and I also believe the video circuits but don't quote me on that.   The wifi enable with a tablet enables you ALL controls of the 105. originally the  105 only came out with the remote and you need a panel connected to display your navigation and control.   Once the apps for the  phone and iPad was released, it did away the remote and the requirement for a panel for display, it's all on the tablet. It also allows you to navigate a USB HDD 3.0 to all your music files in alphabetical order.  The wifi allows you also to navigate all your attached drives on the network.  Extremely powerful feature.   I don't send music from a PC to the 105 via USB.  I load them on a portable  2TB HDD USB 3.0 and attached that to a USB port of the 105.  The beauty of this is that it eliminates and isolate noise from the PC.  The 105 has a buffer RAM where it  stores the data that it recalls from the USB drive.  You can see the drive go active when it recalls for the data.
i do agree with you, the built quality is of very high standards.  I've never had a problem with the 105 apart from FIrmware Upgrades and updates on apps.
On 30/10/2017 at 5:04 PM, Addicted to music said:
Necesita wifi para usar el teléfono o la tableta.
Puedes usar el teléfono inteligente pero no he visto la interfaz de usuario en un android. El iPhone de Apple es un poco difícil de usar; naturalmente, no es tan completo como un iPad / tableta debido al tamaño de la pantalla. El 105 tiene un modo de "audio puro" y apaga la pantalla y también creo en los circuitos de video, pero no me cito sobre eso. La habilitación wifi con una tableta te permite TODOS los controles del 105. Originalmente, el 105 solo salió con el control remoto y necesitas un panel conectado para mostrar tu navegación y control. Una vez que se lanzaron las aplicaciones para el teléfono y el iPad, eliminó el control remoto y el requisito de un panel para mostrar, todo está en la tableta. También le permite navegar un USB HDD 3.0 a todos sus archivos de música en orden alfabético. El wifi también le permite navegar por todas sus unidades conectadas en la red. Característica extremadamente poderosa. No envío música desde una PC al 105 a través de USB. Los cargo en un HDD USB 3.0 portátil de 2TB y lo conecté a un puerto USB del 105. La belleza de esto es que elimina y aísla el ruido de la PC. El 105 tiene una memoria intermedia RAM donde almacena los datos que recuerda de la unidad USB. Puede ver que la unidad se activa cuando recupera los datos.
Estoy de acuerdo con usted, la calidad construida es de muy altos estándares. Nunca he tenido un problema con el 105, aparte de las Actualizaciones de FIrmware y las actualizaciones de las aplicaciones.
Thank  you for your comments.
Just today I put into operation the Oppo Sonica. All I can say is that it has left me pleasantly surprised. Very surprised!
The level of detail, dynamic range and frequency response has left me with a big smile on my face .. Everything is very harmonic and natural, like music in reality.
Who said that the Cd is inferior in sound quality to the vinyl?
I have been able to confirm by my own ears that the real sound of the CD is "hard" as they assign it, only because the DAC is not up to a good conversion.
This Ess Saber 9038 chip is serious, really.
I have put the Oppo Sonica to the test with a very elementary Cd reader as transport, taking the digital signal by optical fiber (Toslink) and then to the DAC, then to the Prima Luna Dialogue Two amplifier with KT-88 and finally to the DTWTII speakers of Troels Gravesen ... Very happy !!!
But I will not talk more about this product out of respect for users who can not buy it in your country. You have things at your fingertips that are very good too, from what I've read.
I have not yet tried streaming with Tidal, I have to configure everything, but I guess there will be no big differences to what I described, they transmit 44.1 KHZ, CD quality.
I just want to add that the test was with a guitar and voice CD, and it is a really analog record, edited in digital, and it has many years ..
So the best is yet to come !
Agree with Addicted to Music and I used my 105D and now Cambridge CXN in the same way - i.e. music files on a portable HDD connected to the device via USB. The other great thing about using a tablet or phone app for remote control is that you don't need to be within line of sight like you do with the hardware remote.
I do not understand what you mean by this.
I have a lot of CD and right now I am rediscovering the sound of them with this amazing DAC chip Ess Saber 9038Pro.
For this the basic functions that use the remote control allow me to manage everything on and off, volume control and selector of source inputs. It has some other functions that I have not analyzed yet.
I have not used wi fi with my netbook, nor with my smart phone. Also as you say you can use an external HDD (I own one with a lot of music files without loss)
Thanks for the tips.
What he is saying is that with the remote you need to point the front of the remote to the device so it sees the commands, so both the remote and the device must be within line of sight.   Most remote have an transmitting inferred LED and the device has a receiving photoreceptor to see the commands from the remote.  With wifi you don't have to be with line of sight, as long as the wifi is within range between the tablet and the device.
ok now I understand. Thanks for the clarification.
I leave some images of the CR of Oppo Sonica.
See the comparative size with the CR of my PL, it is another price, sure, for 35 U$S I guess it could not be offered anymore.
I can not find where the batteries will be changed, I imagine they will be of the "coin, button, etc." type, like those of the PC motherboards.
I have not found on Oppo's official website the option to order the same with or without CR .... mystery ....
Looks similar to the HA1 remote. Poke a wire into the hole on the bottom end of the remote and the battery compartment pops out.
Ohhh ...:ohmy:
like the little hole in the CD readers of PC computers to open the tray when it gets stuck with a CD inside .....
I have a special tool for it, it should be preferably steel, a simple wire would not work in those cases.
Thanks, very useful information.:thumb:
I have to admit that there is a problem with the Oppo Sonica Dac which is (in my opinion) very disturbing.
It does not play files continuously, without interruptions, when we use streaming. (the fault is known as gapless) It's disappointing.
I have presented the problem in other forums in the USA and nobody can tell me why Oppo does not solve this point.
There are people who say that there will be no solution through any firmware update. If this were possible, they would have done it already, it sounds logical. It is also said that the hardware used does not allow the complete storage of bits, (for example of a complete symphonic work, with its contents so revealing of the climate lived between the different passages of the work.)
And also with music recorded continuously, even if it's not live.
Abbey Road of The Beatles, for example, has interruptions in several passages when it was conceived to listen to it in one go !
They have not lost anything, boys .....:angry:
They should have kept it as just a DAC. it makes sense to have a player before the DAC. We Aussies sorted them!
    • By olegau
      ZL T5 Music Audio Decoding Player HIFI Fiber Coaxial Analog Signal Output Support APE FLAC ANSI MP3
      I bought recently eBay $90 each two ZL T5 Music Audio Decoding Player . This player is good alternative to expensive DAC units. It has everything I need and does job well.  I connected my CD player to line in of the unit and line out to my amplifier. So that I have many options of music source: CD player, USB flash or portable USB HD, computer and so on.
      My favorite is the USB flash drive. The unit supports 32GB flash drive. It is hundreds tracks of any audio codecs. The player remember last track even when power off.   What is interesting is one player supports a micro SD card, another does not but it is not big issue.
      Disadvantage is the remote control only.  It has small beam angle. Sometimes you have to push a remote knob  several times.
      Description:
      ZL T5 lossless digital music player, the main chip SP3306AL, can play APE, FLAC and other current series of mainstream lossless music formats, real output lossless audio quality, with digital fiber optic signal output, digital with axis signal output, a set of analog RCA output, you can connect audio equipment with optical signal, coaxial signal inputs. A set of analog signal input, can also convert the digital signal (optical, coaxial) output. It can be used as an analog signal input to digital signal output of the decoder DAC using a machine, USB input and analog signal inputs can freely switch remote control.
      Keys operation Description:
      - 4 buttons, respectively, ST standby key, S key to switch the source, volume + .- keys.
      - Remote control buttons:
        AUX analog signal input keys
        USB USB input keys
        MODE two audio switch key
        RPT single cycle and the order of play switch key
        E Q two kinds of sound
      Features:
      - Single cycle and sequence playback.
      - With hardware audio processing EQ1.EQ2.
      - Maximum support 32G USB storage, format can not be NTFS, but be FAT32 format.
      - Support lossy compression formats MP3 (MPEG1 / 2 / 2.5Layer1 / 2/3).
      - Support lossy compression formats WMA (WMA 7.0 / 8.0 / 9.0).
      - Support lossless compression format APE 3.95 or later Fast (C1000), Normsl (C2000), High (C3000).
      - Support lossless compression format FLAC.
      - Support WAV format codec (IMA ADPCM, INTEL ADPCM, PCM)
      - Support CUE file playback (ansi format).
      Specification:
      - Voltage input DC: 5V
      - Distribution Accessories: Remote Control * 1, high-quality power adapter.
      - T5 Size: 13.5 * 9 * 4 (CM)
      - Battery: CR2025
      The following format can not play properly:
      - Encoding as "Higf Extra" APE.
      - Bit rate over WAV. 4608kpbs
      - DTS encoding APE/WAV
      - AAC/OGG/MPC format
      - Damaged music format
      https://mysku.ru/blog/taobao/58085.html
      http://bvf.ru/forum/showthread.php?p=23487295
      https://www.drive2.ru/l/8889887/
      http://www.hdvietnam.com/threads/may-nghe-nhac-lossless-kiem-dac-gia-sieu-re.1138806/
      More information is here:
    • By Jing
      Item Condition: mint Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Vermont State: Victoria Payment Method: COD Reason for selling: surplus Further information:
      Very good player, excellent review.
      Being Used as DAC(Audio/Video) only.
      Maybe a bit too big for a DAC, and waste of its Blueray and CD player capabilities.
      Therefore try to simplify things.
    • By SBM
      Hi Guys,
      Good day, I am new to DAC and I see here in SNA details on Speakers brands, details and price in every bracket. Just thinking to have list of DAC quality DAC. If in case we have the list already please point me.
      Below 1000$
      1001$-3000$
      3001-6000$
      I am not sure does people spend more than 5000$ on DAC!
      To my knowledge :
      Gieseler(great Australia DAC)
      SoTM
      Chord
      RME
      Denafrips
      Atleast , it will give some pointers to the beginner(like me) in this community, to decide what is best when planning a DAC new/used. As we have lot of brands .
      Thank you
    • By mtan002
      Item Condition: Like new Shipping Options: Audition is not available, but in-person pickup can be arranged with limited personal contact,I can ship this item Suburb or Town: Point Cook State: Victoria Payment Method: EFT cash Paypal Reason for selling: Redundant equipment Further information:
      I bought this few months ago for $700.
      It is an excellent DAC at this price range with clear mellow sound.  But I decided to sell it because I miss the MQA sound.
      You can get the full description here: http://www.audio-gd.com/R2R/R2R11/R2R11EN.htm
      In summary:
      Discrete DAC single ended headphone- and preamplifier True NOS , R-2R discrete ladder DAC Built in pre- and headhpone amp Built in 2 groups DA-8 R-2R modules with 450MHz ultra speed CPLD Unique noise process technology will remove any digital artifact DSD native , DXD, PCM up to 384KHz Support Amanero Combo 384 USB interface High quality ALPS 27 volume potentiometer
      INPUTS
      1.USB input.
      2.Toslink optical SPDIF
      3.RCA coaxial SPDIF
      OUTPUTS
      •RCA single ended (Output is configurable: fixed or variable)
      •Headphone 6,3mm jack
      The price includes postage within Australia. If you come and pickup yourself, you save $25.
    • By hu4man
      Item Condition: Fully Functional Shipping Options: Pickup is available,I can ship this item Suburb or Town: Brisbane, QLD State: Queensland Payment Method: Cash on Pickup, PayPal, Bank Transfer Reason for selling: NLR Further information:
      24 bit/192k. Comes with stock power supply. SPDIF , Coaxial and USB inputs.
      Bought as backup DAC, but never used
