Dave the Rave Posted March 12, 2017 Share Posted March 12, 2017 I am sending music files/ Internet radio via wired Ethernet to my Oppo 103 serviced by my Minimserver on my NAS. Cleared any hint of siblance and brings more highs (compared to USB feed to my DAC). Can enjoy heavy rock music too. My Yggy dac connected thru Toslink but most people say AES XLR input is the best. What is the most cost effective way of getting an Ethernet input to AES XLR device built? Don't want to invest on pricey Aries or Singxer etc... at this stage I have a Gustard U12 but want to avoid USB input. Link to comment Share on other sites More sharing options...
krakatana Posted March 12, 2017 Share Posted March 12, 2017 Rednet 3 and Rednet D16 do this. But they are not cheap. Link to comment Share on other sites More sharing options...
mloutfie Posted March 13, 2017 Share Posted March 13, 2017 (edited) there is no cheap option for AES at least not easy unless you want to make your own i2s to AES board. Not that hard if you know how something like getting texas instrument DIT4192 eval board or making something similar. If you want cheap I suggest going SPDIF RaspberryPi with Digi+ pro board pretty much a ready made option minimum assembly only required. It would still be much better than toslink Edited March 13, 2017 by mloutfie Link to comment Share on other sites More sharing options...
Dave the Rave Posted March 14, 2017 Author Share Posted March 14, 2017 @krakatana yeah heard lots of praise for the Rednet but price tag is way too high. @mloutfie Thanks for the suggestions... where can i find good info/product details to build the Digi+ solution? Link to comment Share on other sites More sharing options...
mloutfie Posted March 14, 2017 Share Posted March 14, 2017 (edited) Pi you can get from many places like elemen14 or even jaycar for the digi+ you can get the board from here https://www.hifiberry.com/shop/bundles/hifiberry-digi-bundle/ I suggest you get the pro version worth the extra money. more info https://www.hifiberry.com/products/digiplus/ Edited March 14, 2017 by mloutfie Link to comment Share on other sites More sharing options...
Dave the Rave Posted March 15, 2017 Author Share Posted March 15, 2017 Thanks mloutfie. Could not find the Etherney input and AES XLR output in the hiberry products.... i will keep reading as i am trying to understand how they all fit together. Link to comment Share on other sites More sharing options...
mloutfie Posted March 18, 2017 Share Posted March 18, 2017 The hifiberry Digi is just a shield board for raspberry pi so you need to get a pi first that would handle the network connection where the Digi will do the spdif out (not AES) like I said in previous post there is no cheap ready made AES solution. You will need to go full diy if you want AES Link to comment Share on other sites More sharing options...
Dave the Rave Posted March 19, 2017 Author Share Posted March 19, 2017 @mloutfie Thanks. I am not that competent on DIY so will keep looking out for other used sales. Link to comment Share on other sites More sharing options...
krakatana Posted July 12, 2017 Share Posted July 12, 2017 There is finally a lower cost AOIP Dante converter coming out, the Radio Design Labs SF-ND2. "Only" goes to 96kHz however. http://www.rdlnet.com/product.php?page=886 http://www.markertek.com/product/rdl-sf-nd2/rdl-sf-nd2-network-to-digital-audio-interface Link to comment Share on other sites More sharing options...
Dave the Rave Posted July 21, 2017 Author Share Posted July 21, 2017 @krakatana Thanks. Interesting as i play 16/44k songs mostly. Will read more on its sonic contribution. Price is excellent. Link to comment Share on other sites More sharing options...
Dave the Rave Posted February 8, 2018 Author Share Posted February 8, 2018 Could not find much feedback and reviews on the Radio Design Labs SF-ND2 (AES/EBU out via ethernet feed) Anyone had any experience with it? If not, any other latest AOIP options (low cost for try out)? Link to comment Share on other sites More sharing options...
