SETfan 101 Posted April 9, 2009 Share Posted April 9, 2009 I misconnected one of my speaker wires (dumb!!), and have ended up with a droopy ribbon on one of my Sonic Art (aka Fountek JP3.0) ribbon tweeters. It seems to play ok still, but dont want to risk playing too loud just in case. Anyway, it is obviously now mis-shapen, and I think it will definitely now vibrate or buzz when played louder, so need to replace it. Does anyone know of anyone in Oz that could do this, or maybe supply a replacement ribbon? Otherwise, I think it is only possible to buy a totally new matching pair of tweeter units again which is a bit costly. I found some instructions on the Fountek website, using household aluminium foil, but I am no DIY'er and would be guaranteed to "foil" at any attempt!!! :-) Cheers, Mark BTW: I use these in a Dick Olsher "Basszilla" 3 way, custom made open baffle design. Link to post Share on other sites
MichaelWC 3 Posted April 9, 2009 Share Posted April 9, 2009 Hi Mark, You may want to give http://www.speakerbits.com/Default.aspx a go. They used to sell these ribbon tweeters (or similar) and they specialise in repairing drivers. Though I don't know how much they charge. Cheers, Michael. Link to post Share on other sites
JA 4 Posted April 9, 2009 Share Posted April 9, 2009 I misconnected one of my speaker wires (dumb!!), and have ended up with a droopy ribbon on one of my Sonic Art (aka Fountek JP3.0) ribbon tweeters.It seems to play ok still, but dont want to risk playing too loud just in case. Anyway, it is obviously now mis-shapen, and I think it will definitely now vibrate or buzz when played louder, so need to replace it. Does anyone know of anyone in Oz that could do this, or maybe supply a replacement ribbon? /quote] Hello SF, On the Fountek Website I found these Australian contacts/distributors. Try them for a replacement ribbon. Asia Pacific Stones Sound Studio Po Box 94, Tyalgum 2484 NSW, Australia Tel: +61 2 66 79 3059 +61 2 66 79 3555 Fax: +61 2 66 79 3700 Website: http://www.stonessoundstudio.com.au WES Components Wholesale Distributors 138 Liverpool Rd, Ashfield 2131 NSW Australia. Tel: +61 2 9797 9866 Fax: +61 2 9799 7051 Website:http://www.wes.net.au Wagner Electronic Services Retail Outlet 138 Liverpool Rd Ashfield 2131 NSW Australia. Tel: +61 2 9798 9233 Fax: +61 2 9798 0017 Website:http://www.wagner.net.au Best JA Link to post Share on other sites
Jake 4,031 Posted April 10, 2009 Share Posted April 10, 2009 I have a pair sitting right here next to me (which I plan to use later this year), and I bought them from Wes components. Cheers, Jake Link to post Share on other sites
A9X 2,110 Posted April 10, 2009 Share Posted April 10, 2009 Fountek sell replacement diaphragms and I've even seen a pictorial step by step somewhere some time ago. Link to post Share on other sites
SETfan 101 Posted April 10, 2009 Author Share Posted April 10, 2009 Thanks Guys! Got on to Stones Audio in Oz, they will replace the ribbon for $90. A little bit pricey considering a brand new pair only cost $239 but I am not keen on the DIY repair using household aluminium foil that I also stumbled across!! I found that Aurum Cantus supply replacement ribbons for their tweeter which are cosmetically very similar for only US$4 but the ribbon corrugations appear different so I better stick with exactly the same as the Fountek/Sonic Art I have. Cheers. Link to post Share on other sites
Jake 4,031 Posted April 10, 2009 Share Posted April 10, 2009 If you bought a new pair then you would have 1 left over for a centre speaker project :o Link to post Share on other sites
A9X 2,110 Posted April 10, 2009 Share Posted April 10, 2009 Thanks Guys!Got on to Stones Audio in Oz, they will replace the ribbon for $90. A little bit pricey considering a brand new pair only cost $239 but I am not keen on the DIY repair using household aluminium foil that I also stumbled across!! I found that Aurum Cantus supply replacement ribbons for their tweeter which are cosmetically very similar for only US$4 but the ribbon corrugations appear different so I better stick with exactly the same as the Fountek/Sonic Art I have. Cheers. I meant buy an original diaphragm and replace it yourself. It doesn't look hard or require special tools.If you bought a new pair then you would have 1 left over for a centre speaker project :oI agree with your logic here (even as a spare for later) especially considering shipping both ways will be involved for the repair. Link to post Share on other sites
Steve M 1,834 Posted April 11, 2009 Share Posted April 11, 2009 (edited) I have repaired/replaced a Fountek ribbon tweeter for a friend - the job was a bit of a pain, but still doable for the average person if you have patience. The procedure took about 1hr to do. In contrast a Raven ribbon takes about 5 minutes to change, the Ravens are much better constructed, better magnets, plates and assembly, the whole thing is simple and modular and comes apart easily ...Ravens sound better too. BTW, I also roll/make my own ribbons with varying thickness of alluminium (or should that be thinness??). The thicker stuff gives a stronger soundfield at the loss of some featheryness. Don't laugh, but the best sound (and taste) comes from a chocolate Toblerone wrapper! ...wife likes it too, she gets to eat the chocolate. Cheers, Steve M. Edited April 11, 2009 by Steve M Link to post Share on other sites
Dr Good Vibe 209 Posted April 12, 2009 Share Posted April 12, 2009 If you like ribbons try panels. Link to post Share on other sites
