source for quality spade & banana connectors??
Hi all. Where is a decent source for spades and banana connectors for speaker cables, at the right price? Australia or overseas
Alan
Edited by aertex
  • Replies 43
Popular Posts
Gold is a better conductor than Rhodium, but if the base metal is brass that is not a good conductor at all.   Brass is like 28% where copper is 100% and gold is 70% Rhodium about 38%
I would never tin the wire before crimping. Actually if you read into it, it’s not recommended at all. The tinned wire can much more easily crack and break.  The recommended way is to twist the wires.
Your guys are great, lots of helpful advice here. I was a bit hesitant at first but I'm now feeling a lot more confident about being able to pull this off.  I'll definitely be posting back here w
Depends on what you mean by quality and right price.  Selby (Australian) has a lot of well-machined connectors but all of them will probably be gold-plated brass or nickel.  RS Australia has the Swiss mult-contact banana plugs which are gold-plated beryllium copper and a bit of an industry standard.  They're around $4-$5 each but need soldering plus heat shrink over the solder joins.
If you are looking for higher quality than brass e.g. pure copper, gold-plated copper, or silver plated copper connectors then it gets more difficult and prices are quite a bit more expensive.
Geoff
For me, the best and cheapest is bare wire. I have tried various connectors and no connector at all sounds best, maybe not as convenient though.
Seriously, as long as they are gold plated etc. is various brands of the banana plugs really going to make a difference to the sound? Or is it more $$$ = higher perception?
Guest scumbag
Yes it will make some difference however small and more-so when the speaker impedance is low. I gave a link to a good quality cheap spade as per the OP's question and in fact no one has suggested any connectors that are expensive.
Guest BobbyD
The only ones I will now use (if not using bare wire) are Audio Note silver.
Can be sourced in Aust and best bang for buck I have heard, just need a soldering iron.
Where is the source in Australia for these Audio Note's Surge? And yes bare wires are a pith, hence my need for connectors for 2 pairs of cables I have
Guest BobbyD
http://www.audionote.com.au/Audio_Note_Australia/Cables_%26_Accessories.html
Drop an email to address on this page from supplied link , that will get things rolling.
@guru will help you from there, very good to deal with.
Hope this helps....... Regards
Currently using Audioquest 500 series banana plugs really good quality hanging silver directly over pure Purple Copper but the SureGrip 300 could be another alternative
theaudioexperts.com.au got some prices but any local Audioquest dealer will be able to help you
Neo
Guest scumbag
@aertex the Audioquest stuff (the 300 series or better would be where I would start looking) is good but you just have to make sure that you get your AQ stuff from a reputable dealer. There are a lot of suppliers (Ebay etc) based in China that are selling rip offs of AQ stuff. Apparently they are the most ripped off high end brand. If it's really cheap then it might be a fake. Just my 2 cents worth.
Mark
  • 4 years later...
On 10/03/2017 at 8:32 PM, Guest scumbag said:
These are very high copper content brass with a nice think gold plating - http://www.chromeaudio.com.au/store/connectors-spade-terminals-c-66_99 - well priced too.
Hi all, I was wondering if anyone knows whether Chrome Audio are still in business and if anyone else has tried the spade terminals above?
I've sent them a message and got no reply and the number on their contact page goes to a private phone that is not related to their online shop.
Alternatively if anyone has any idea where one could source some decent spade connectors, preferably gold plated real copper that would be great. I'm trying to avoid the cheap and nasty stuff on eBay.  Thanks in advance
Edited by Willmax
ETI research have Tellurium Copper with Rhodium plating ones
https://eti-research.com/spade-connectors/
I think I'd prefer the lower mass over the newer design, unfortunately it is discontinued at Soundlabsgroup website, but that is sort of what I'm looking for.
I found these EGM which look nice but there is no mention of copper, so probably other base metal is used I assume.
https://www.heynowhifi.com.au/collections/cables-connectors-plugs/products/egm-audio-spade-plug-gold-plated-1-pc
same deal here, no mention of copper anywhere
https://www.heynowhifi.com.au/collections/cables-connectors-plugs/products/audioquest-p10m-spade-connectors-6-8mm-10awg?variant=39543318249622
Edited by Willmax
Not sure if I'd call the EGM low mass, but....yeah are they a copper alloy base metal or brass.
Not as many doing spades these days as there once were.
Edited by muon*
Yes agree not low mass and no mention of the base metal... which is a bit sus
There are a few interesting options in the Parts Connection link above, under connectors / spades.
Another local alternative below, unfortunately it won't suit my amp
https://www.jdaudioonline.com.au/product/kimber-pm-25/
Edited by Willmax
33 minutes ago, Willmax said:
@Bill125812 have you got any experience with the EGM Audio connectors in general?
Sorry mate.   But no experience at all
The Valve Store in Glen Waverley (Vic) has the EGM spades as well https://www.thevalvestore.com.au/41-audio-connectors
They have one version that is "gold plated" and another which is "rhodium plated", no mention of the base material.  I saw them a while ago and wondered if they were any good.
Would they be considered to be a quality spade?  Would the gold or rhodium version be better?  Would there be something that would be a much safer purchase for a quality spade that won't break the bank (I know the WBT's are good, but they are expensive).
Brass verses Beryllium Copper as a base metal
Brass 28%
Beryllium Copper 32% to 38% (heat treated for maximum electrical conductivity) Edit: Correction! high conductivity Beryllium Copper has an Electrical conductivity: 45–63% IACS
https://copperalliance.org.uk/about-copper/conductivity-materials/copper-beryllium/
Not sure about resistivity, but as seen above Beryllium Copper as a base metal should generally be a better electrical conductor compared to Brass.
Edit: Most will se some of this as splinting hairs, but I like any advantage I can get in the signal path :)
Edited by muon*
  • Like 4
Found a good range with different option at https://www.hificollective.co.uk/components/spades.html
Sadly I could not find anything local that would suit what I was after so I ended up ordering some CMC gold plated copper spades from the above site. I hope it arrives soon.
Now I need to work out the best way to attach them to a flat ribbon copper cable :P
Edited by Willmax
Now I need to work out the best way to attached them to a flat ribbon copper cable :P
Fold the corners of the ribbon ends at and angle so it comes to a point, kind of. Depending on the width of the ribbon you can get it to form well to fit with folding.
I always forget hificollective as they are a tad dearer than parts connexon who is my go to shop if i can't get what i need local. Although i used to shop at both equally as I needed parts from both places.
Edit: geez, they look nice, and cheap too! :thumb:
Edited by muon*
Rather than fold, roll the edges of the ribbon so the ribbon is flush with the inner-face if the connector when inserted, tin the face of the ribbon after rolling when you have a good fit and also the connector before soldering to secure, and secure the cable to connector with the self adhesive  type of heat shrink tubing.
You might modify that above and get an even better idea for good area contact and strength :)
When I've used that crimp-style connection I will insert the wire, then close the ribbon with pliers so the two pieces touch in the centre.  As I don't have a ratcheted crimping tool, I will place it on an solid surface and use a hammer to flatten so it is extremely tight and secure.  No need to solder.  I will cover the top and bottom of the spade so the hammering doesn't mark it.
Before starting I will slip some heatshrink around the cable to slide over the back of the spade after connecting it so it looks nice (using red and black to reflect the polarity of the connections).
While doing that, I will also use a piece of red/black heatshrink a few inches up from the spades so each speaker cable is identified as the left/right channel.
I would never tin the wire before crimping. Actually if you read into it, it’s not recommended at all. The tinned wire can much more easily crack and break.  The recommended way is to twist the wires. Then crimp. If done properly you will almost get a solid weld like bond.
  • Thanks 1
I was looking at the whole approch in a different way, maybe not a good idea *shrug*
Get yourself a decent set of crimpers. Hammering is a bad idea as you can over compress the joint, damage the wire and damage the crimp connector.
I'll definitely be posting back here when the spade connectors have been delivered.
  • Thanks 1
I was looking into getting a crimper a while ago, but I would have so little use for them I wonder if it would be worth the investment (ie, one or two crimps every few years).  The cheap ones I saw didn't have a ratchet, and I don't have a strong hand grip.  I don't know much about them, is there anything you can suggest that I look for or avoid in a budget crimper?
I would actually recommend one with a ratchet as you said.  And one with interchangeable heads Is preferable. Will cover anything you need.  I’ve have a few but recently bought this one. I was very sceptical but is actually really good
https://www.ebay.com.au/itm/301623918249
Edited by Bill125812
  • Thanks 1
    • By kurof
      Item:
      Price Range: reasonable
      Item Condition: New or Used
      I'm after 4 large spade connectors that can accommodate approx 7mm+ cable, I'm Biwiring and it's hard to get 2x 4mm cables in one spade.
      pm me if you have some
      Cheers!
    • By haygeebaby
      * Item: Nirvana Audio S-X Ltd. Speaker cable 2.5m spades
      * Item condition description: Excellent condition
      * Price and price conditions: $1500
      * Reason for selling: NLR
      * Payment Methods: Cash / Bank transfer
      * Extra Info: This is one of those unicorn speaker cables that is very hard to find. Purchased for a pair of Avantgarde Duo Omega horns. Initially had my equipment between the speakers but have since setup the equipment along the side of the room. Thus needing 8 meter runs of speaker cables.
      The S-X cables are well reviewed on the internet. Priced just below $4k AUD when new. Stereophile ranks the cable as one of the best. Enjoy-the-music rates the cable at nearly 98 out of 100 for all characteristics.
      I really enjoyed this cable. Wonderful sound. Very quiet backgrounds. Very good build quality.
      https://www.stereophile.com/cables/1005nirvana/index.html
      http://www.enjoythemusic.com/magazine/equipment/0602/nirvanaaudio.htm
    • By frankn
      Item: FS :  Krispy Audio L3 RCA interconnect cables for sale, listed below -  UPDATE/Prices reduced
      Price: see each item listed below
      Item Condition: As described in list
      Reason for selling:  Surplus to requirements / running XLR
      Payment Method: Pickup - Cash, EFT Only
      Extra Info:  Listed below - New Lower prices include shipping.
      Pictures:  Yes Krispy Audio L3 cables;
      All present as new or excellent, no kinks, dents etc.  Used in pet free, non-smoking household.  Length measured incl. RCA plugs.
      1.42m / $260 (slightly older version, has lockable black locking Furutech metal RCA, cover is Black braid with green spiral).  This cable uses the same Furutech Alpha series balance audio FA-220 cable with PCOCC conductor
      1.26m / $255(Furutech Alpha series balance audio FA-220 cable with PCOCC conductor, current Furutech FT-11G locking RCA)
      For example the same L3 cable 1.2m / new $400
      For example the same L3 cable 1.8m / new $468
      frankn
      Price reductions
    • By Phillb
      Item: OYAIDE SPYT Spade Lugs
      Price: $40 per box of 4
      Item Condition: brand new, unused
      Reason for selling: did not have a use for them
      Extra Info: Palladium over silver thick plating
      8mm, 6mm, AWG8
      Made in Japan
    • Guest scumbag
      By Guest scumbag
      Item: Lenehan Audio PDX Tube Dac -  Mundorf Silver Gold Oil - USB & I2S inputs
      Location: Brisbane Northside - available during work hours.
      Price: $old
      Item Condition: Excellent
      Reason for selling: Changes to my work environment mean I have to get rid of a lot of equipment. I will keep it and use it at home if no-one wants it.
      Payment Method: Pickup - Cash, Paypal (as a friend or add 3%)
      Can be fed either USB or I2S. It has a toggle switch at the front to change between the two inputs. 16/24bit toggle switch also, You would need a transport that outputs I2S with a masterclock to get this to work - I believe. 16 bit is when used via I2S and 24bit is for USB.
      Was originally a USB only input. Terry Demol (zenelectro) installed the I2S input and did a general check over for the previous owner. Dual Mono premium “U-K”-grade Burr Brown PCM1704 DAC chips. This is an early PCB version.
      The 2.2uf Mundorf Silver Gold oil caps are worth about $280 delivered by themselves. Running a matched pair of gold lion 6922 tubes. The battery isolated USB input (similar to JKSPDIF MK3 I believe),
      This unit gives what I believe to be a very pleasing timbrel quality to music - not in any way the stereotypical "digital" sound. If you don't like the mild influence of tubes or NOS DAC chips, this is not for you - please move on.
      Pictures: I've thrown in a bonus image to get you prepared for Halloween (you'll know when you see it).
