Boris Karlof
FS: LS3 5A AB1 subwoofer XO kit
Item: Brand New AB1 subwoofer  XO kit
Price: 260
Item Condition: new 9/10
Reason for selling: other priorities in my life ATM
Payment Method: Pickup - Cash, COD
BankTransfer Pickup preferred.
Extra Info: Skimp on the quality of the components in the bass section of your passive crossover and overall sound quality will be compromised as all other signals will be filtered by the quality of passing through these components. That is the simple inconvenient truth that many loudspeaker manufacturers like to avoid confronting. This is the Achilles heel of the standard kits and Rogers AB1 bass enhancement module as I like to call it. It really doesn't go low enough to qualify as a subwoofer.
The kit consists of  X 2 Erse 17 MH .5 Ohm DCR 500 watt rms inductors  and  X 4 Cross Cap Jantzen 100 uF 400 V polypropylene that are more than a fist full each. Check out the price of these things add postage and know you are getting a bargain that will enhance the performance of your AB1.
Hi Mark I have a pair of Audio Space AB-1 copies which have really impressed me with bass reproduction when properly controlled. I currently have an ME550 MkII being loaned to me while my Accuphase E-205 is in for repairs.
Would you expect a significant improvement with changing out caps and inductors, are they installed in the AB-1 towers and are there any reviews with standard components changed out?
Thanks in anticipation, Regards
John
    • By Muzza71
      Item:  Tauris Georgia HiFi Stand 4 Tier Shelf Tempered Glass
      Price: $100
      Item Condition: Very Good
      Reason for selling: NLR
      Some light swirl marks and scratches but nothing to obvious.
      750mm Height 650 Depth 500mm Wide
      470mm between inside posts
      450mm deep to rear frame.
      245mm bottom shelf height
      200mm middle shelf height
      210mm top shelf height
      Shelves be can interchanged.
      The rear frame has been opened up to accommodate different terminal positions on amplifiers and source components on 2 shelves.
      The bottom shelf has 6mm rubber sandwiched between two perspex glass plates to assist with sound absorbsion/isolation.
      Bottom shelf weight limit 45kg, other shelves 25kg.
    • By Muzza71
      Item: Speaker Stands 735mm High - Tempered Glass
      Price: $50
      These can be filled with your preferred sound deadener/Absorber.
      735mm high including spikes, perfect for smallerish bookshelves around 300mm in height
      Top plate D 180mm x W 150mm x 8mm thick
      Bottom plate D 300mm x W 220mm x 8mm thick
    • By bdavis84
      Item: KRIX Phoenix Floorstanding Speakers
      Price: $600
      Item Condition: Like New
      Reason for selling: Downscaling
      Extra Info: 2 small holes in one of the speaker mesh. Otherwise great condition. Barely used over the past 7 years. Also includes quad braided speaker wire valued at $25 pm.
    • By bdavis84
      Item: KRIX Concentrix Centre Speaker
      Price: $220
      Extra Info: Great Australian made centre speaker. Barely used over the past 5 years.
    • By bdavis84
      Price: $220
