Peter-C
Mober Bearing Housing for LP12
@Tasebass
Did you end up getting the bearing going again?
8 hours ago, Capone said:
@Tasebass
Yes...by replacing it with a Cirkus bearing I had in stock....
Incidentally it was the Radikal sensor that eluded me to the Mober bearing failing as the LED on the switch would not go dim ...( does this when speed is correct )....
Tase.
On 25/12/2019 at 8:15 AM, Tasebass said:
With Hand on Heart I have to report that the bearing has Failed in less than 2 years...
...basically it 'Locked up"  so I cleaned the well ...again...which didn't help then noticed the indentation on the thrust plate as shown...( best i can!! )
This was running with a TP Tranquillity too which reduces point contact upto 90%   supposedly.....:unsure:....
  .mmmmmmmm..
Tase.
Hi Tase,
sorry to hear about this - your Linn's look amazing by the way - I have  modified LP 12 myself although not as highly specc'ed (or as funky - in a good way - as yours:);
How is the ball bearing Mober sub platter looking - is there any sign of wear on this? Are you still using it / would you still recommend the sub platter upgrade?
I am asking because it was on my radar as the next upgrade along with the Mober DC motor unit.
Would really appreciate and value your thoughts.
Cameron
On 30/12/2019 at 6:43 PM, Cammyboy0_0 said:
Hi Tase,
Cameron
Thanks for the kind comments....a labour of love getting the decks to what I wanted....
As stated earlier I ordered 3  Mober units from Edmond ...His PS + motor....bearing and inner platter...The PS was not an experience I wish not to repeat though @Luc and @Peter-C I believe use the Mober PS with good results so they would be more qualified to respond than myself...
The bearing whilst a laudable Idea I believe was rushed into production without much ( if any ) proper R&D which Linn would participate in if bringing a new or revised product to market....one reason for their pricing with relation to other third party offerings for the Sondek....
Which brings us to the Mober inner platter...well yes its been good ..so far...I checked the tip at the shaft end and have noticed no wear...but then I have a few Linn inner platters with much more mileage on them that also have no visible wear....
From my perceptive with regards to certain third party mods/upgrades I would be extremely cautious especially where electronics are concerned.....arms and carts not withstanding...
Have fun Tase.
Have fun Tase.
Tase, I also have installed Edmund's composite inner platter - in my Cirkus bearing, with Tranqu fitted.  No problems so far - and it must be at least 2 years.  Edmund's inner platter certainly made my TT sound better.  :thumb:
At this stage, im leaning towards the Cirkus bearing & maybe Edmunds inner platter
8 minutes ago, Capone said:
At this stage, i'm leaning towards the Cirkus bearing & maybe Edmund's inner platter
C, I'm certainly a fan of Edmund's composite inner platter ... but not of his bearing (it's the Cirkus, for me!  :) ).
I recommend you consider the Tiger Paw 'Tranquility', though.  :thumb:
Hi Tase, happy NY, and hope your health gets better and better this year.
What was the problem with the psu? I remember opening the box from Hong Kong and following the instructions and... The thing just worked.
If I had a complaint it would be that the digital adjustment might be instantaneous but it's slow to show up on the display, apart from that I reckon it's leaps and bounds ahead of the Valhalla (obviously) and ease of use puts in above his Moses Hercules. The digital adjustment leaves the Hercules for dead.
@TasebassHaving installed a brand new Cirkus bearing over Christmas I note that the thrust pad is polished to an amazing finish and looking into it you see yourself looking back.
I compare that to the mober bearing that is unused and see a dull finish with lines at the bottom of the bearing.
Is the circle in the photo an indentation or a shiny spot?  The fact the bearing bound up is not a good sign.
I haven't installed my Mober bearing and as it had sat for considerable time the oil supplied in it had dried out and was dried flakes.  I think someone else reported the same.
Hi Luc...HNY to you too champ and may you live long and prosper...:D...& I'm feeling about as good as I'm gonna get....which is awesome considering...:thumb:
As previously mentioned in this thread my unit arrived with a damaged motor which was noisy ....and the speed control unit would not 'lock on" 33.33rpm....45 was fine though....I spend quite a bit of time trying to get things to gel adjusting but to no avail
Edmund was a Gentleman though and offered a full refund on the Mober PS....which I accepted. Turns out the speed control He send out had an internal fault ....I cant remember what though.
I did ask Edmund to check everything before shipment so why this happened...????
Cheers Tase
Edited by Tasebass
...That would have probably been moi .......as mine was caked in some oily gooiii stuff which required some soaking in chemicals for a period of time...
The thrust pad on the Mober bearing has an indentation. which as stated is even more puzzling cause it was used in conjunction with a TP Tranquillity....
I'd be sticking with the cirkus...
Cheers Tase.
Cheers Tase.
Im taking your advice re-Cirkus👍
I've Edmund's Mober, with it's digital control and PSU and strobe sticker and that's it.
It's been a wonderful thing and it sits atop  and drives a mid 90's LP12 which of course has most of the goodies a newbie Linn buyer would want., Cirkus not the least of them.
So really I shouldn't be here in this thread about his bearing. The Cirkus does the biz.
Guest jakeyb77
Tase is this the same bearing? I’m assuming the chemicals had no adverse reaction?
Sorry to hear about the bearing. For all us uses I hope it’s not indicative.
But good to know a cirkus fixes it.
I used a combination of WD40/acetones/(nail polish remover) with a wax and grease remover...which I let the bearing soak in for a day or two....
At the time there was no adverse reactions...
cheers Tase.
    • By mm13
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Noranda State: Western Australia Payment Method: Paypal, EFT, Cash on Pickup + Paypal fee Reason for selling: Surplus Further information: Linn 2250 stereo power amplifier + Aktiv Treble Card in excellent condition. Come with  owner manual. 230W into 4 ohms and 115W into 8 ohms. Balanced and unbalanced inputs. I don't have original box but can pack properly for post. Postage will be $30 Aus wide.
      PLEASE READ
    • By ThisMustBeThePlace
      Item: Linn Sondek LP12 or Thorens TD125 (or similar)
      Price Range: $1200-$2500
      Item Condition: Used
      Looking for a Linn Sondek LP12. Preferably Melbourne. Will also consider a Thorens TD 125 dependent on upgrades, condition and price tag.
      What’s out there?
    • By Juzbear
      Item: Linn Compatible 90degree DIN to RCA cable
      Price Range: $100
      Item Condition: New or Used
      Extra Info:  I am looking for a cable for my Basik Plus tonearm for the old LP12 I am putting together from parts, so happy to get something fairly functional rather than hi-end.
    • By Neo
      Price: $50 Item Condition: 8/10 Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Lane Cove State: New South Wales Payment Method: PayPal Reason for selling: NLR Further information: condition as pictured, would make an awesome project at home
      No electronics and the condition of the woofer unknown
    • By Willmax
      I am seeking some advice/opinions from the more experienced members about the Ortofon M20E Super cartridge with Linn Ittok LV II tonearm.
      I have to admit that I am not clued in at all when it comes to cartridge and tonearm combinations, particularly the Linn Sondek LP12 parts and upgrades.
      My turntable came with this cart/tonearm configuration when I bought it, so I've always wondered if changing to a different cart would yield a sound improvement (no pun intended), not that it sounds bad, I actually don't mind how it sounds at the moment.
      I have a number of carts that I wanted to try but just not sure whether they'd be suitable for the Ittok LV II tonearm, for instance in terms of compliance, etc...
      Maybe the Ortofon M20E Super is already better than everything else I've got, for example - Denon DL-110 & DL-103 LCII, Ortofon 2M Red, AT95E - Who knows? Over to you...
