Peter-C
Mober Bearing Housing for LP12
12 hours ago, djb said:
@andyr now get a grip
the point is to remove Ivor's upgrade compulsion NOT substitute Edmund for Ivor.
Haha - good point, David!  :thumb:
11 hours ago, Tasebass said:
Oooo and BTW...have ordered both platter and bearing off Edmund...:)
Tase
2 in one hit, Tase!  And no Tranquility?
I need to get my Tranqu fitted first - and enjoy that - before thinking of a Mober bearing.
Edited by andyr
Tranq's are on back order...yes tranq's as in plural...
Tase
Tase
How much was the bearing? Very interested. Been looking at Cirkus bearing for awhile so this definitely has my attention.
email Edmund....He's good to deal with...
chanedmund7@netvigator.com
Tase.
Tase.
Yes I have bought off him before, just wanted to know roughly.
Is it less than a brand new Cirkus Bearing?
On ?6?/?03?/?2017 at 6:24 PM, andyr said:
But given that a recording of a live music event always sounds degraded compared to the event listened to live ... why do you think that a before&after recording of the Mober will be able to show up the differences that you might be able to hear, live?
I suggest what is needed is 2 identical LP12 (same standard, same arm, same cart) side by side - listen to one ... then the other.
your proposal will also work, but don't discount the ability of a 96khz digital recording to capture any small differences, and also alow you to check bearing noise levels using PC software. Should there be an improvement before and after recordings can be shared. If the change in sound is so subtle as to not be captured by a digital recording then arguably its not really much of a change/ improvement. I hope my suggestion is taken onboard. I had no intention of distracting this thread, but from now on, in threads that take my interest, I will be challenging anyone who claims an improvement to prove it with an audio sample. Its not really hard to do, and should if anything reassure the modder, that their endeavour was worthwhile. I personally now take recordings fwiw.
You aint got the Tranq fitted yet Andy...??
Tase
Tase
No, Roger rang me on Wed night a week ago and we had a good chat.  He also supplies the threaded plastic insert (which fits over the Cirkus bolts) in a shorter length and this is probably what I'll need for my SkeletaLinn.
It is on its way.
And, given all I have is a CD-R ... how am I going to make recordings at 96Khz?:wacko:
It is on its way.
Hi Andy
Can you explain this threaded plastic insert?  Does it fit over the bolts and bearing housing to position the tranquillity lower magnet?  If this is so and it is specific to circus is it to be an issue with Edmunds Mober Ring Bearing?  I guess @Tasebass will know if they're compatible given he has gone for Edmund bearing and inner platter and tranquillity.  I hope they are as I'd like to keep my options open for the tranquillity if I go the Edmund bearing.
3 minutes ago, tesla13BMW said:
Hi Andy
Yes, if you have a look at the pics on the TPA site, you can see the upper disc fits around the boss on the underside of the inner platter - while the threaded insert in the lower disc straddles the 3 Cirkus bolts.  Turning the threaded insert determines how much the lower disc is lifted off the (in your case) subchassis.  In a Linn bearing, the distance from the top of the bearing to the top of the subchassis is, what, 3mm?  In my SkeletaLinn, the distance is 6mm - hence, to compensate, I need the slightly-shorter, threaded insert.
Roger said you lower the inner platter down into the bearing housing and if it hits the bottom ring ... this has to be lowered.  So remove the inner platter, screw in the threaded insert a couple of turne ... and try again.
Yeah, I believe Roger has one, too so you will know whether it is compatible or not.
Cheers @andyr.  Makes sense now.  I'd guess seeing as the lower disk straddles the 3 cirkus bolts and these are the same spacing for the mober and cirkus, so long as the top section of the mober bearing is the same outer diameter as the circus there shouldn't be a problem.
Issue still remains of the hole size through the Valhalla.  Perhaps I need to make the Valhalla "off board" - anyone got an extra switch or blanking plug for the top plate?
It’s not strictly necessary. A 44.1khz recording will do the job. I personally observe that a higher sample rate sounds more like the record than 44.1khz. But thats up to the individual to decide.
But I can understand your apprehension. I find CD recorders are a bit pernickety to use, and of course you need to spend a few dollars on a disc every time you want to make a recording. That’s why the modern recorders which record to a micro SD card are far more convenient.
IMG_3903.JPG.1360fe2805a21eb3573abc113d0c67e2.JPGIMG_3904.JPG.ad9ea85938c718a43dc51106c16a8002.JPG
So this is what we are talking about Yeah...?
I cant see a problem with the Mober bearing if the dimensions are the same as a cirkus bearing...
The insert rides the height for clearance gap once set against the 3 bearing mounting blolts  .... just hope the diameter is the same from Edmunds affair...
should Know by mid next week
Tase
Yes, the hole size through the Valhalla is a potential problem.
Or is it - I thought you had a 'Number9'?
I have an "original" LP12 switch, if you'd like it.
I will have a Number9 with 24VAC motor, but, until then I will still be using my Valhalla which I have recapped.  If I install the Valhalla off board this will allow me to be able to use the Mober Ring Bearing.  So I'd like to grab the switch off you please so I can mount this in the enclosure and still leave the switch in the LP12 rather than a hole or filling in a hole.
NP, Chris - I'll deal with this after I get back to Melbourne at the w/e.
Just need the TP Tranq's then some serious rebuilding.....IMG_3959.thumb.JPG.017cb9cfbe08f978d161d27e7e174527.JPGIMG_3960.thumb.JPG.2604f6cd80105913ceb014d019785e3e.JPG
Tase
Hi Tase,
You bought the Mober ps as well [emoji1303]
That bearing housing looks well made.
Id be keen to hear your thoughts on the dc A-Max motor once you've run it in, mine is still has a very slight bearing noise, probably due to the Khan tp.
Pete.
9 minutes ago, Peter-C said:
Hi Tase,
Pete.
 The Motor kopt some damage in transit....:emot-bang:
hope its OK. Not going to Know until i do the rebuilds . I've emailed Edmund to see if i can do a "cold" run just to make sure
These units will go on my Black deck replacing a Naim Armageddon which does sound very good.
Interesting your comments re the Khan as both my decks are super quite..
Cheers Tase
Ouch! yeah looks like it took quite a hit.
Also, you may have to modify the sensor mounting on your Khan (if it's the same as mine) as it's designed for the Linn tp.
I know Roger swapped the motor on his Mober to a re-max one, which I will probably do at some point.
Edmund gave me a re-max model no. to try.
Pete.
With Hand on Heart I have to report that the bearing has Failed in less than 2 years...
...basically it 'Locked up"  so I cleaned the well ...again...which didn't help then noticed the indentation on the thrust plate as shown...( best i can!! )
This was running with a TP Tranquillity too which reduces point contact upto 90%   supposedly.....:unsure:....
IMG_0928.thumb.jpg.ec068e1c9e73a80387ebd6296f134355.jpgIMG_0929.png.1e69775d2d609e85c68e8e9e69133159.png
  .mmmmmmmm..
Tase.
This was running with a TP Tranquillity too which reduces point contact up to 90%   supposedly.....:unsure:....
  .mmmmmmmm..
Tase.
Very sad, Tase.  :(  Hard to see how this could happen when you use a 'Tranquility'.  :(
  .mmmmmmmm..
Tase.
Not good at all!! 🤔
    • By mm13
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Noranda State: Western Australia Payment Method: Paypal, EFT, Cash on Pickup + Paypal fee Reason for selling: Surplus Further information: Linn 2250 stereo power amplifier + Aktiv Treble Card in excellent condition. Come with  owner manual. 230W into 4 ohms and 115W into 8 ohms. Balanced and unbalanced inputs. I don't have original box but can pack properly for post. Postage will be $30 Aus wide.
      PLEASE READ
    • By ThisMustBeThePlace
      Item: Linn Sondek LP12 or Thorens TD125 (or similar)
      Price Range: $1200-$2500
      Item Condition: Used
      Looking for a Linn Sondek LP12. Preferably Melbourne. Will also consider a Thorens TD 125 dependent on upgrades, condition and price tag.
      What’s out there?
    • By Juzbear
      Item: Linn Compatible 90degree DIN to RCA cable
      Price Range: $100
      Item Condition: New or Used
      Extra Info:  I am looking for a cable for my Basik Plus tonearm for the old LP12 I am putting together from parts, so happy to get something fairly functional rather than hi-end.
    • By Neo
      Price: $50 Item Condition: 8/10 Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Lane Cove State: New South Wales Payment Method: PayPal Reason for selling: NLR Further information: condition as pictured, would make an awesome project at home
      No electronics and the condition of the woofer unknown
    • By Willmax
      I am seeking some advice/opinions from the more experienced members about the Ortofon M20E Super cartridge with Linn Ittok LV II tonearm.
      I have to admit that I am not clued in at all when it comes to cartridge and tonearm combinations, particularly the Linn Sondek LP12 parts and upgrades.
      My turntable came with this cart/tonearm configuration when I bought it, so I've always wondered if changing to a different cart would yield a sound improvement (no pun intended), not that it sounds bad, I actually don't mind how it sounds at the moment.
      I have a number of carts that I wanted to try but just not sure whether they'd be suitable for the Ittok LV II tonearm, for instance in terms of compliance, etc...
      Maybe the Ortofon M20E Super is already better than everything else I've got, for example - Denon DL-110 & DL-103 LCII, Ortofon 2M Red, AT95E - Who knows? Over to you...
