Peter-C
Mober Bearing Housing for LP12
Seems Edmund has been working on a new bearing housing for his SSP12 inner platter.
It appears to be a double ball race design going by the cross-section diagram on the Linn forum.
The Mober certainly spins a lot longer than the Cirkus bearing. I wonder if there is any difference in SQ.
Mober bearing housing:
Linn Cirkus bearing housing:
Edited by Peter-C
Well I have the inner platter but haven't purchased the Cirkus bearing housing yet.  Perhaps I should wait and see where this goes :wacko:
How very interesting, Peter!  :thumb:
I wonder how relevant it is for those of us who have purchased the Tiger-Paw "Tranquility" - given this causes the load of the end of the platter stub on the thrust plate at the bottom of the bearing to be reduced by 90%?
I think you most certainly should, Chris!  :)
Yeah, I was about to order a Tranquility myself :unsure:
The ball race is giving the tangential support to the inner platter / spindle but I would think there would have to be some mating surface at the bottom of the spindle for vertical support.  I'd expect that the ball race is just an alternative to the bearing liners i.e. the black or the white etc.
So this "free running" bearing may be good for the mober and other DC power supplies, but, I thought I had read for the synchronous motors there was a desire for drag to gain a smoother drive and reduce cogging???
Would this work on an Ariston RD110 SL?
Sent from my Redmi Pro using Tapatalk
See what others say about the loading on the bearing.  But, I would think the Ariston would be using a synchronous motor as well.
Yeah, using silicon oil for this reason was suggested by Simon on PFM (and AudioFlat) many years ago.
But I think I read that he had taken out his silicon oil when he installed either his Edmund Chan inner platter or the Mober DC drive?
So @andyr what would be your educated thought on using the bearing with the #9 speed controller be given you have control over the phase angle?
I guess this is somewhat irrelevant until someone gets hold of one and puts it on a AC synchronous motor TT
I vote Andy!  The circus is the only thing Linn on your table now isn't it and the outer platter?
The diagram seems to indicate there are 2 ball races and a thrust pad.
I'll have to ask Edmund when I get a chance (and get a price).
I don't think there will be any problem using Edmund's Mober bearing with the Number9 speed controller.
Currently, the only Linn components on my 'SkeletaLinn' are:
  • yes, the Cirkus bearing
  • the springs & grommets, and
  • the outer platter.
Although I am going to do an experiment one of these days, due to something @metamatic said.  Shane said one of his TTs (solid plinthed) sounded 'faster' when he used stiffer springs under the slab which the TT feet were sitting on ... and more relaxed & mellow when softer springs were used.
So I will substitute the 30%-stiffer springs that I had made up when I developed v1 of the 'SkeletaLinn', for the Linn springs I'm using now.  (Due to the LHS spring being too close to the cross-brace supporting the Cirkus bearing in v1 of the TT, there was too much weight pressing down on this spring - so it needed to be stiffer.  In my SkeletaLinn (v2), I moved the LHS spring 50mm further away from the bearing and achieved an almost equal weight distribution across the 3 springs - hence, I can use Linn springs.
Also, I'm toying with the idea of getting Duc (when he's well again) to make up a custom Delrin outer platter with rim-loading of lead shot.  Overall weight of the EC inner platter + Delrin outer platter will be the same as Linn's ... but there will be increased weight at the periphery - to increase the flywheel effect.
So if the Mober bearing is a goer, by the time I finish I won't have any Linn bits left!!  :D
Yes - so if there's still a thrust plate ... the 'Tranquility' should still be a good complement. :thumb:
I read it is no good for Hercules or Valhalla due to the bearing housing being bigger and not going through the round hole in the PCB.
Yes, I read that - and possibly Lingo, too.  NP with my SkeletaLinn - see the 1st pic in Clive's post here:
No good for me until I can replace the Valhalla :(
Roger does a shite load of work for most of the F1 teams.....Tiger Paw is His "side line' so to speak..
He studied the cirkus bearing and concluded its about as good as it gets for its application...i.e. low noise and friction...so the tranquillity was born.
Edmunds effort seems to have A LOT of contact points...lots of points lots of potential noise...even with a tranquillity...
All speculation of course ...but until one hears it....;)...however good a promo video is..
Tase.
Just a footnote a remember reading in the HIfi press back in the 70's why Linn used a single point thrust plate affair over a ball race type set up...
Edited by Tasebass
Tase.
C'mon, Tase! :P
So Edmund's Mober bearing has a pair of ball races.  So if there are, say, 10 ball bearings in each race ... there are 20 contact points.  Do you agree?
Whereas the Cirkus bearing has sleeves around the inside of the bearing well - which contact the inner-platter bearing stub.  All the way up and all the way round the bearing stub.
So I would say the Linn bearing has many more sq cm of contact area than ball races have!  This logic would appear to be borne out by the fact that an inner platter in Edmund's Mober bearing housing spins for much longer than the same inner platter in a Cirkus bearing housing.
19 minutes ago, andyr said:
C'mon, Tase! :P
 C'mon Andy....
We have metal to metal contact with Edmunds ......the cirkus is metal to PTFE...BIG difference...
Unless Edmund has some proprietary manufacturing techniques we don't know about...
As I said Roger figured the cirkus FOR ITS APPLICATION was about as good as it gets...
( wonder how many F1 teams Edmund contracts to....with respect..)
Tase
Edited by Tasebass
Edmund has older Linn bearings, Cirkus bearings, Mober bearings, SSP12 inner platters and Linn inner platters.
Can't see the point in releasing something that doesn't sound better than the original.
Whether it's better than a standard Linn Cirkus bearing with a Tranquility...who knows?
17 hours ago, andyr said:
C'mon, Tase! :P
Think you will find that there is no direct contact as the oil  film separates the shaft and bearing
That is a good point.  :thumb:              Surely, though, it must be a mighty thin film (of oil)!
I hope if someone does install the new bearing that they take before and after audio recordings so that they can demonstrate that there is a change or improvement to the sound.
Strangely there are modifications for all manner of turntables and tonearms, but a dearth of audio recordings to demonstrate any improvement.
A 26" racing bicycle wheel spins for a long time too, but does that make its bearing suitable for a turntable? The point I'm trying to make is that there may be no correlation between spin down time and audio quality.
Or perhaps there is? But I've never heard any recording that proves it.
I wonder why the sellers of such products dont provide recordings to demonstrate their products superiority since if any claims are true, it should be demonstrable.
But given that a recording of a live music event always sounds degraded compared to the event listened to live ... why do you think that a before&after recording of the Mober will be able to show up the differences that you might be able to hear, live?
I suggest what is needed is 2 identical LP12 (same standard, same arm, same cart) side by side - listen to one ... then the other.
@andyr now get a grip
the point is to remove Ivor's upgrade compulsion NOT substitute Edmund for Ivor.
Na ya don't..
A crappy bearing will manifest itself quite clearly on any spec Sondek cause its performance benchmark starts and ends there...
Full Klimax Sondek with shitety bearing will not sound as good as a Majik Sondek with a top notch bearing..
Oooo and BTW...have ordered both platter and bearing off Edmund...:)
Tase
    • By Dacman
      Item: Nordost Red Dawn Leif RCA 1m pair (sold:and Linn RCA 1.2m pair)
      Price: Nordost $375 shipped. Linn $75 shipped
      Item Condition: Perfect
      Reason for selling: NLR cable clear out to fund new gear.
    • By DrDeeKay
      Item: Linn Ikemi
      Price: $999
      Item Condition: Very good, unmarked
      Reason for selling: Replaced with a universal disc player
      Payment Method: Pickup - Cash, PayPal
      Extra Info: This has been my reference CD and HDCD player for some years but I am simplifying my setup. Originally priced around $3600USD.  The review below sums the performance up perfectly. The Linn is in excellent working order, unmarked, comes with balanced XLR cables, a remote, and original box for safe transportation. This unit is very well constructed, delivers incredible detail and an expansive sound stage.
      HiFi Review. "Sound wise this is typical Linn. Fast, refined, smooth and very detailed. You can hear just about everything in the mix. Although rather than sound analytical it sounds warm and silky. It has beautiful tone and the way it flows from passage to passage is a real delight." Nuff said.
    • By thejt
      Item: Linn LP12
      Price: 1600 ono
      Item Condition: good
      Reason for selling: small child is now almost ready to destroy everything I own. Best it go somewhere safe.
      Extra Info: Early Linn LP12 for sale equipped with Rega RB300 tonearm and Linn Asak moving coil cartridge. I am told that I am the third owner of this beauty with the original owner having it for many decades. The second owner got a newer Linn rather than upgrade. The fluted plinth is in pretty good condition with a few small nicks as seen in the photos. Lid is crack free with only minor swirling. Hinges replaced by myself so are almost new. No idea about the hours on the cartridge but it plays without a hitch and stylus looks very straight. I've put on less than 50 hours personally having only got it right before our child was born. It has been well looked after by all owners and I even have the original documents. Bonus shim for the tonearm in case you need to raise the height to accommodate a different cartridge. Happy for inspections for anyone in Perth.
    • By Zoet
      Item: Linn Katan
      Price: $380 price dropped postage included to Eastern states
      Item Condition: 8/10
      Extra Info: I’ve owned these speakers since new Original boxes so they will be well packed All tools included. Were part of an Aktiv system
    • By Salisbury 79
      As the main Star Wars saga concludes, I came across this blast from the past (see photo which for some reason has rotated 90deg).
      This was very much in keeping with the cheeky Linn & Naim marketing at the time but timeless in its message nonetheless.
      The main difference for mine is that the Source these days starts at the mastering/file quality, pre the turntable / CD player.
