250/400w Zeus Audio, Class AB Diy Design/Build
Just thought I'd put up my amplifier build. This amp was up and running around 6 months ago, but I've just put the final touch in it. Replaced my 1000va Nuvotem transformer to a Torroidy "Supreme audio grade" transformer. I'll post some pics of the process here. I have called this the "Zeus Audio - Simamp". I had some cast silver "Zeus Audio" name plates made for my Tsunami speakers so I thought to carry on the tradition with the other projects I build.
Original speaker Logo. 3d printed wax, then cast in silver. Expensive logo.
I started by reading the Bob Cordell book "Designing Audio Power Amplifiers".
I produced a schematic using the best bits of the book.
Image result for designing audio power amplifiers bob cordell
Decided to use a nice symetrical layout. Not because it sounds better, but because of my psychological tendancies.
The amplifier was also tsimulated using the same "Ltspice" program learned by reading the book..and google.
Voltage out (green). Power across 8ohm load (blue)
simulated power acros 8ohm load
Current though 8ohm load at max power before clipping.
FFT plot @ max power 1000hz
THD @max power 1000hz
To be continued
Simon
  • Like 11
  • Replies 100
Popular Posts
Updated input board. No mistake this time.   Updated power stage board.   Now we're getting somewhere!   Final boards, transformer and box. Notice the extra shield
Picture says everything. 22000uf 100v. Have 8 in total crammed in the chassis for  176000uF total for the power supply.   Custom made Toroidy transformer. Highly recomended. 50v second
Here is the original pcb layout. I say original because this one had some mistakes which made the amp oscilate and destroy some transistors. Always the first batch has something wrong!
The original boards arrived from pcb manufacturing (PCB Way) in China. Don't let the C word sway you, these are great quality boards.
Boards showing back side as well. Note the power section has thick traces on the top and bottom layers for extra current capability. I have to give a thank you to "ostripper" from diyaudio forums for letting me copy techniques he used on some of his amp board designs.
Not great photo I know. This shows the original boards populated and sitting on a large heat sink.  Electrolytic caps are Nichicon Fine Gold and Panasonic FC. You will also note the transistors aren't the usual 3 leg BCE type. Those are Onsemi NJL1302D/NJL3281D. The D at the end means they have an embedded diode in the package. The diodes for 2 of the transistors are  then used in the bias circuit for what is meant to make it have greater stability.
  • Like 7
Custom made Toroidy transformer. Highly recomended. 50v secondaries x sqrt2 =  70V positive and negative rails.
Earth wire for shielding between windings.
Encapsulated in resin and put in a polished stainless enclosure for even better shielding from stray emi.
Here it is with my old nuvotem transformer. Cant be seen as it's under my diy emi shield of a cooking pot with nice copper bottom. Also note the amplifier boards are different. This is my second version with separate input boards and power supply boards. You will also see a soft start board on the side of the pot/transformer. That is definitely needed when dealing with a large transformer and copius capacitance.
   You will note the use of copper bus bar as the power supply rails and gnd . Overkill but it looks great.
Edited by niss_man
  • Like 12
  Final boards, transformer and box. Notice the extra shielding over the input modules.
Had to shorten up the bus bars a bit to fit the larger Toroidy transformer.
That is Spalted Rainbow Sassafras from the forgotten state Tasmania. Some gorgeous wood comes from that gorgeous state. Thanks Tassie.
Thats about it. Except my new logo's which have to be attached.
  • Like 14
No MOSFETs this time Simon?
I would also like to express my interest in an integrated version of this product.
Edited by Cafad
No mosfets this time. The last amps I made were SKA GB150D diy modules designed by Greg ball. This design is a bit more involved.
I would love to build you an amplifier Jeff. It would be quite a long process though. Would have to redesign or add some boards for the preamp section. I would like to use a lightspeed attenuator as the preamp( or maybe a clone note as @robmiddid) as I am using except mine is in another preamp box. The box would have to be upgraded in size from an already large box as well. Give me a pm or call.
Edited by niss_man
WOW love your work COPPER BUS BAR, excellent, nothing like current on tap
Can see some big hours in the work there
Toroidy make lovely potted and encapsulated transformers, they always come in the blue wrapper and are actually polished steel, you can tell by the darker hew the steel colour has to SS
Harbuch make some nice transformers as well. Ordered 4 yesterday after a listening test India vrs Australia Transformers in a little amp project. The ferite core means a lot to the final listening am finding (EDIT and hand founded for audio in SA apparently) .
Please keep posting your wears excellent stuff !!
Edited by Guest
Harbuch make some nice transformers as well. Ordered 4 yesterday after a listening test India vrs Australia Transformers in a little amp project. The ferite core means a lot to the final listening am finding.
I was wondering if it was steel and not stainless. With this transformer I can put my head very close and there is no hum or noise. A supremely quiet transformer. Not cheap at around $600 delivered by sea mail but I'm glad I tried them. I will use Toroidy again for sure.
Cool, wack on a magnet if in doubt
Locals make some nice ones too particularly if you know what to get, but the Toroidy is supreme and addictive :D when the need comes to build again .
I love an over the top build Simon.  Nice stuff!  I wonder how many people look at those photos and have a comprehension of just how much planning and effort actually goes into building from scratch like that.  Awesome work...and your own circuit to boot...that's hardcore DIY right there.
  • Like 3
Thanks Anthony
I would like to have added up the hours I spent in planning, reading, sitting on the computer designing, buying and building, testing, finding mistakes and building again. I think it would have shocked me as well. As you know half the fun is in the learning in the process and the other half is the sastisfaction at the end of it.
This is "Deep end DIY" :D:D
  • Like 3
Nah, you probably wouldn't...or at least I probably wouldn't...the answer would be a little disturbing.  I just hope we can both eventually listen to this stuff for more time than we spent researching and building it...that would be a good outcome.
1 hour ago, Boris Karlof said:
Ha!
I love it when art meets science.
Shine on & keep on keeping on. Audio needs more souls driven by passion
Nice one.
Thanks Mark.  :)
Fantastic work @niss_man. :)
What a daunting project to take on.
You definitely deserve to be commended for your efforts. :thumb:
What about the sound?
You mentioned it's a keeper but what more can you tell us about its sound and performance?
Beautiful work from start to finish@niss_man If you ever decide to move it on, consider me seriously interested!
Sent from my SM-G900I using Tapatalk
I won't write a review of my amp as I would be totally biased of course. I do however like an amp that is there to do it's job and do it's job well. To me that is something that acts as a conduit between cd/pre/dac etc and the speakers. Something that can deliver grunt when needed and also be delicate when needed. Something that can play quick dynamic music as well as it can laid back music. In other words what I'm saying is, I want my amp to sound like nothing. In my eyes if you want to change the sound then change the source components and cables. I know all amps do have there own sound and if I were to say something about the amp I would maybe use words like "detailed, fast, powerfull, finess" or maybe even the word "nothing".
                      I am sure other more unbiased people would have much more to say about the amplifier in more detail but only once it is in there own system at home. Comparing this amplifier to my SKA GB150D amplifier I would have to say this has more detail (less mossfet midrange fuzz), finess, power and neutrality.
Simon
Probably not going to happen.
Simon
It's okay you're allowed to be a little bit biased !!! :D
It sounds like your amp is good at exactly what you like, can't ask more than that. :)
Slightly off topic but if you ever get the chance to listen to a Halcro amp (the high end class AB models) you definitely should. :offtopic:
By the description of what you like in an amp I reckon they would be exactly what you like in a really extreme version.
To describe them they are pretty much invisible.
Yes I have been lucky enough to hear the Halcro Star wars Tie Fighter ones a few times. Mike Lenehan's, @Cafad 's place and at a QAC meet as well.
Well I don't usually do reviews on power amps but I could certainly give the Simamp a run against my Halcro if Simon was willing to let it out of his sight for long enough.
We have yet to seriously discuss the possibility of a Sim-Int amp though and that would be my preference.
Hey Simon, how is it for heat?  And while I'm on the topic of slightly more technical questions, how many watts in class A and what sort of input impedance are we talking about here?
1. Heat = Sweet FA (technical term) or luke warm most of the time. Warm in peak of summer.
2. Class A watts = 4w or if I was a manufacturer = 8w
3. Input Impedance = 100k Ohms.
Good stuff.  I'll take two!
Or maybe just one integrated version.
Just now, niss_man said:
You already got one with balanced in.
Only power amp but a Zeus integrated amp will make it a perfect set.
Form an orderly line at Simon's door!  :D
13 minutes ago, niss_man said:
Too heavy. 34.7kg
Nah.  Heavier the better I reckon.
56 minutes ago, niss_man said:
Too heavy. 34.7kg
Yeah, that's a good weight for an amp.  My back may disagree at some point but fortunately it doesn't get a vote in the here and now.
    • By BKO
      Item Condition: Mint Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Perth State: WA Payment Method: Cash, PayPal or EFT Reason for selling: Going full separates PRICE REDUCED FOR QUICK SEll
      Further information:
      Marantz SR8012 AVR. Made in Japan, build quality is immaculate.
      Bought new in July 2020. RRP 6890.
      Has more than 2 yrs of Marantz  Australian warranty left.
      Has been used sparingly in dedicated HT room.
      Will power up to 11 channels with 11 separate amplifier channels.
      Potent brains and brawn for Home theatre setups.
      Has most audio surround and video codecs; DTS:X, Dolby Atmos, Auro 3D and is compatible with HDR10, HLG and Dolby Vision.
      Has pre outs for all channels to add power amps for even more flexibility.
      Full list of specs here https://www.marantz.com/en-ca/product/av-receivers/sr8012
      Review by Audioholics here https://www.audioholics.com/av-receiver-reviews/marantz-sr8012-receiver.
      Have Original paperwork, remote and Audyssey calibration mic with its stand. Don’t have original packaging (my other half thought it’s junk now and threw away without my notice ) but can pack appropriately, as required.
      Prefer pick up as it is quite heavy.
      Can drop off for shipping if shipping can be arranged by the buyer.
      Also posted elsewhere.
      PLEASE READ
    • By Sonica
      Item Condition: Good condition Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: VALLEY VIEW State: SA Payment Method: Bank Transfer, Cash on pick up Reason for selling: Rising funds for a new audio project Further information: This is 100V unit and had it for more than a year alternating it with other 3 amplifiers. Never had a single issue with it and have used it together with a C2a preamp to get a great audio experience out of it. Banana cable connectors ready! So, is now time to find a new good home. It has a small crack on the back panel, it is very small but looks big in the close up photo. I know will regret selling this unique amplifier but I am an audio...nomad!
      PLEASE READ
    • By Minimalfi
      Hiya!
      I wanted to share my recent experience with my power setup as it surprised me and might be worth an experiment or two for you. Bit of a mega post but stick with it for teardowns and polarity adventures.
      I bought an Audio by Van Alstine humdinger to try and nail the very faint hum from my Innuos LPSU. Turns out it didn't. The hum is very faint but I have a million smart devices around and I thought it couldn't hurt to leave it. Recently I decided to sell the humdinger to 'tidy up a bit' after a speaker upgrade and as it didn't remove the hum.
      But I was listening to the Darren & Duncan Hifi podcast on critical listening and I realised I never checked to see if it sounded different. So I unpacked the humdinger found a US plug to IEC, oh did I mention the humdinger is wired for US plugs? Before anyone panics I checked with AVA and it is rated for 220v and 15amps.
      My jury rig across the floor (didn't want to get behind the shelves for the quick listen) was el cheapo power cable to humdinger and mediocre power cable to my amp. Blow me down - more bass (vs amp into Thor power filter). Also, better dynamics and overall clarity.
      Hmmmm...I have some nice power cables from Audio Principe which I had previously used into the humdinger with $6 korjo AUS to USA adaptors. Like many Hifi nerds I had previously ordered a war chest of bits and bobs including shielded power cable and USA plugs with a view to taking the adaptors out.
      Didn't assemble anything cos I was worried about polarity. The USA has the hot pin on the opposite side to AUS and I couldn't wrap my head around the 'right' way to correct it ( don't throw things!!). I was really curious (worried) the cheap adaptors were holding the US Polarity and in fact swapping it through my setup. I thought about buying a tester but ended up tearing the adaptor apart ($6 isn't much for peace of mind!). Turns out the adaptor was using a clever twist to swap the hot pin (correctly). But it was a pretty small plate and didn't connote a solid "HIFI" connection.
      Back to the war chest and I got a Volex (3 X 1.3mm shielded) cable which came with IEC already fitted. I added a qualtek grounded Nema 5-15 US plug. After thinking it through I realised the IEC on the amp end and into the humdinger will keep polarity. So I wired the cable as appropriate for USA. Using my audio Principe into the humdinger and Volex out I have decent cables and even more satisfying tunes out of my setup.  I kept the Thor out of the amps circuit because I was so pleased with the sound.
      If you read this far good on you! Obv I don't know what changed the sound cos I changed four elements but all I can say is experiment (safely!).
    • By Sonica
      Item Condition: Good condition Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: VALLEY VIEW State: SA Payment Method: Bank Transfer, Cash on pick up Reason for selling: Too many amplifiers Further information: Amplifier is in good condition and has been in storage for a few months. Some small signs of usage on the body. It has good reviews.
      PLEASE READ
    • By Danny525
      hi guys
        Part of my passion in loudspeakers, apart from enjoy listening to speakers - and appreciating Good sound, is knowing a speaker has power and authority. I don’t necessarily like to play very loud for more than 10min, but I do sometimes after a hard day at work - and I want to have the confidence that a speaker can handle the power.   In saying that I have bought a 220RMS Anthem power amp - MCA30 connected to a seperate pre amp - A Cambridge 851A. I know this is an integrated not a dedicated pre amp - however i am using as a pre amp. Connected to the pre amp 851A is a Cambridge dac magic and connected to my laptop via USB and played via iTunes or Tidal. I noticed, not on my 10” Ascension floortsranders  but only on my bookshelfs 140RMS Rated Ascenion bookshelfs (used a satori 7.5” bass driver) that there is slight distortion on the bass driver only, not the mid - only on certain songs.. This is at a volume that is not far from the pre amp clipping-1. My question is that I do not know if it is the pre amplifier that is clipping, or if it is the Speaker not being able to handle the load. It sounds as if the speaker can not handle the load and a slight pop sound from the speaker - but it’s odd because it’s only on one song. My 10” ascenion is fine handling the same gain on the amp - so I’m thinking that it might be the fact the bookshelf may not be to handle the power? Particularly the bass driver?   if anyone would know whether I just need a more powerful speaker (which makes sense as the amp is 180rms @ ohms) and my speakers are rated at 140rms and are 8ohm speakers.   if anyone can help a beginner like me that would be greatly appreciated   thanks daniel
