MrSchnitzer
PrimaLuna; standard vs HP
12 hours ago, bhobba said:
Make no mistake - it one of the best amps on the planet - even not upgraded.
I wholeheartedly agree with you after listening to the PL HP driving my speakers and headphones. This is one seriously good sounding tube amp using PL stock 12au7 and KT88.
I'm in awe and simply soaking in the euphony, power and control that the PL is having on my transducers.
Just a teaser pic.
Congratulations @Odyssey
I got my PL HP March 2017 with KT120s and can say this is the most enjoyable my system has ever sounded.
The only mod I did was add a thin white sliver of Ptouch label tape to the volume knob for a visual cue.
I like that the input selection via the remote is direct and not a dumb step around method.
At first I was a bit annoyed that by default the input selection always fires up on CD but soon realised this would be useful and instead of the CD plugged in there I plugged in the source I use the most. Perfect!
The remote is a piece of art and is the most impressive remote I have ever seen. But I use a Logitech Harmony remote to control everything and the PL was easily added to the Logitech functionality.
Thank you @rockpig.
I echo everything you said about this amp. I love it !!! I'm going through albums after albums now. I've never been so smitten with a gear before... well maybe my Rega RP8 with Apheta cartridge and Avid Pellar phono.
Here's another photo.
Glad to hear you are enjoying the PrimaLuna HP Matt. I remember being equally excited about how good our system sounded once the Pl was introduced into it.
Then a couple of months later to make it even better I got back into vinyl and the PL really started to show what a great bit of gear it is.
cheers Terry
On 9/22/2017 at 7:25 AM, Ancientflatulence said:
I am out on the dry dusty blacksoil plains in the North West of NSW  ............. not a lot of kit around here that didn't come from Harvey Norman ......... :):)
I should say that the Prima Luna has been sitting forlornly to one side since a Weston Artisan KT150 landed on my doorstep ........... the day is approaching when I will have to decide between the two .............. :(
Looking at upgrading at the moment and both of these are on my list.Have you come to a decision yet and interested to hear what you views are on them both.
@OdysseySo a few months in now - what's the verdict?
Also, does anyone use the HT input? If so, is there any interference or high pitched buzzing?
I did try it for several days just after I got mine and it was fine, no buzzing at all.
cheers Terry
On 15/03/2017 at 9:00 PM, MrSchnitzer said:
I'm fairly sure I'm going to buy one, but I'm currently stuck in a cycle of trying to work out which speakers to choose (from a short list that I've narrowed it down to.)  In an ideal world I'd try the amp with various different speakers, but that's often impractical.
Hey @MrSchnitzer have you got the PL amp in the end? If so which speakers are you driving?
How about you @mcvinyl did you end up with a PL or did you go for the Weston?
I'm considering getting a PL myself but not too sure which model would best suit my Yamaha NS-1000 speakers - and whether integrated or power amp would be the best way to go about it?
Very good amp for the money.
i had the HP version but I had some issues with mine that Magenta could not resolve (weird buzzing noise in one channel).
In in the end went with a PS Audio BHK 250 / Pre - but that cost 4x as much as the PL.
i still have extra an Octet of KT150 and KT120’s stored when I tube rolled. Preferred the 120 in the end but that may have been aesthetics as well.
Preferred Gold Lions in front for their top to bottom balance (help that that are not that expensive).
Miss the PL sound.
I have made my mind up on a Weston Topaz KT 120, It was a toss up but seeing that it will be sitting pride and place in the kitchen dining area my interior director loves the look of the weston with the copper plated cover upgrade and I wont  discourage that.Still in talks with Earle at the moment on some cap upgrades and other options, its great to be able to communicate with the man himself and create your own personal amp. Now I just have to move on some gear to help with the funds which is like cutting my arm off but have to keep telling myself it will be worth it in the end.
That's a great choice particularly since it's been endorsed by the Interiors Director ?
The Weston's certainly have a great aesthetic appeal and being able to customise to suit your preference as far as upgrades and appearance is just stupendous value. The look of the Primaluna has a very understated/utilitarian look IMO kind of reminds me of the Bewitched 6550/KT88 deluxe amp.
Bewitch-6550-EH-Integrated-Amplifier-Del
Edited by Willmax
Has anyone got the photo board installed on the Prima Luna?
Phono Board??????????? ............ :):)
I actually considered it for a while then decided to go down the path of a separate phono stage as I could not find a review anywhere of how good or bad the PL phono stage was.
If you actually find one please share it.
If you look inside the HP Integrated especially after having the Caps upgraded its hard to see where anything else can be fitted.
cheers Terry
Edited by TerryO
Thanks for the link, Unfortunately I think the reply from Herman from PL in 2016 kind of says it all and even though there have been several more enquiries since then it would appear there is still no answer. I think even if they get it up  I'll give this option a miss.
155af26fad87ced13a38f7597548eed7?s=120&dbeheerder says:
Hi Robert! Trying might not be so easy as till now it is a kind of a hassle to get a board installed. The MM version is kind of OK. The MM/MC is something we are still discussing here and it has to be mounted outside on the bottomplate for hum-sentivity reasons. The problem is that we designed the amps to be line source only. The MM and later the MM/MC are designs made after that the amps were designed and in fact already in production. Noth boards perform very well for what they are, but space is really an issue. Will have discussion here again about that on Monday. Have a nice weekend. Best regards, Herman
Edited by TerryO
Sometimes I wish PL should have built in the phono to their amp.  That would make a hell of amp.
From what I gathered once Herman got to the Kiseki, he realised he couldn't make a good enough internal phono preamp, he decided to drop the product.
I ordered one in 2014 at SouthPort HiFi - but the customer decided not to go ahead with the order so if you ask Mike to rummage through his inventory, you might be able to find one :P
The chassis stays quite cool, but as with all valve amps - the tubes get very hot and need ventilation space.
I currently have an amp that runs 4 EL34's and it is not too bad with heat output. I was curious if the PL puts out enough heat to make you think twice about using it in summer without A/C?
My PL runs on 4 KT88 tubes. Never too hot in summer.
    • By Mikeptl
      Item: PrimaLuna ProLogue Premium Stereo Power Amplifier (KT120)
      Price: $1200
      Item Condition: Excellent - they look pretty much like new to me - no scratches, marks etc.
      Reason for selling: Upgrade
      Extra Info: I have this amplifier for about 3 years and in storage for 1.5 years. Only had about 150 hours on it as a 2nd system. I have upgraded the stock power tubes to Tung Sol KT-120 matching tubes. The amplifer is in perfect working conditions. Will ship to other states plus extra shipping cost.
    • By reflux075
      Hi peeps,
      Any sugguestions as to where I can get a PrimaLuna preamp serviced in Melbourne? Many thanks.
    • By The Audio Experts
      Item: PrimaLuna - Prologue Premium - CD Player $2000
      Price:  $2000. (RRP $3999)
      Item Condition: Like New, played a handful of discs comes with 3 months warranty and all packaging and accessories. Still has plastic protective film over metal chassis
      Reason for selling: Display Model.
      Payment Method: Eftpos, Cash, PayPal (+3%) or Direct Deposit
      The ProLogue Premium CD Player comes equipped with: True Dual Mono design using two 12AU7 dual-triode tubes and one 5AR4 rectifier tube per channel. While it is fine to use a single tube as a buffer and claim your CD player is "tube", it can't be compared to the PrimaLuna design and what it does for the music. Vacuum tube rectified power supply adapted from the award-winning ProLogue Three preamp that incorporates eleven separate power supply regulation circuits. Tube rectification is synonymous with organic sound, especially with CD players being know as sounding like "a computer." State-of-the-art Burr Brown SRC4192 24 bit/192kHz upsampling circuit and Burr Brown PCM1792 DACs. Two SuperTube Clocks™. An ultra-low jitter clocking device that replaces the solid-state oscillator with a vacuum tube. Yields incredible detail retrieval and dynamics throughout the entire audio spectrum. Why use two? The addition of the second clock further reduces jitter, resulting in greater detail and resolution. Highest quality USB digital input allows using your computer for storage and playback of your music with all the benefits of features like playlists and easier access to your whole music library. Rather than just add in a USB input as an afterthought, PrimaLuna engineers searched endlessly looking for the best-sounding USB interface we could find. We found the hiFace, made by M2Tech in Italy. This USB input converts the jitter-filled USB digital signal to S/PDIF, dramatically improving the digital signal quality before it even gets to the SuperTube Clocks. This USB input is a true high-resolution digital input, so you can play back your high resolution digital files, up to 24-bit/192kHz. Premium parts including polypropylene coupling caps, triple pi power supply filters, custom designed isolation transformers which separate the analogue and digital devices, Resulting in decreased signal degradation and improved sonics from top to bottom. Many CD players weigh in at five kilos or less. The ProLogue Premium tips the scales at 15 kilos! Beautiful heavy-gauge anodised brushed aluminium remote control. Controls all important CD operations and will even control functions on the DiaLogue components. Comes with rubber rings on both ends to protect furniture. New power transformers. Heavy-duty, dual-mono, power transformers increase control and detail. PTP-circuit. If the power transformer should overheat, this innovative "Power Transformer Protection" circuit cuts primary power, allows the preamp to cool down, then resets itself. Chassis made of finely finished heavy gauge steel, and five step automotive quality finish. Each coat hand rubbed and polished. Removable tube cage included no charge. Conservative design runs tubes easy for long life.
      Specifications:
      Freq. Response: 20Hz-20kHz +/- 0.5dBOutput Voltage: 2V +/- 0.5dB Distortion & Noise: Below -96dBChannel Separation: 90dBDynamic Range: Greater than 120dBPower Consumption: 50 wattsTube complement: 4 - 12AU7, 2 - 5AR4Dimensions: 14.5" x 8" x 15.5" (WxHxD)Weight: 33 lbsAnalog Outputs: 1 pair RCADigital Outputs: 1 coaxial / 1 opticalDigital Input: 1 USB
    • By MAXXX
      Item:  PrimaLuna ProLogue5 tube power amplifier
      Price:  $1400  $1300
      Item Condition: Mint, AS NEW
      Reason for selling: Too many amps
      Extra Info: Purchased recently, imported from Europe end of March 2018.  as brand new from the dealer. I want  to keep this one but sale of my other tube amps (with heavily reduced prices) is not going well...KT88 tubes, auto biased and can use lots of other tubes. (see link: http://www.primaluna-usa.com/prologue-five/ )
      Comes in original double box, happy to demo for local buyers. This is new amp, advertised AS NEW only because of open box and few hours of testing.
      Postage for Australia $50.
      Still in the box, tested for few hours only...I'll add more photos later.
      ProLogue Five Specifications
      Output Power 36 watts x 2 Inputs 1 Pair RCA Outputs 4 & 8 Ohm speaker taps Freq. Response (+/- .5dB) 20Hz-85kHz THD < 1% at full power S/N Ratio 89 dB Input Sensitivity 775mV Power Consumption 210 watts Standard Tube Compliment 2 - 12AX7
      2 - 12AU7
      4 - KT88 Dimensions (WxHxD) 11" x 7.5" x 15.5" Weight 37.5 lbs
    • By HarbethRob
      Item: PrimaLuna Dialogue Premium Integrated amplifier with KT150 tubes
      Price: $2,200 plus shipping
      Item Condition:Excellent
      Reason for selling: Moving on from tubes
      For sale Primaluna Dialogue Premium Integrated amplifier with KT150 tubes. In addition, will also include original PL KT88 tubes and a whole bunch of 12au7 tubes (electro harmonic, Primaluna, Phillips etc).
      Can send additional pictures to anyone interested.
