Gieseler Audio
GIESELER KONVERTER (DAC/Preamp) Official release.
John - no not a Antipodies but technically very similar. It a pc server that I built using a linear PSU & SOtM PCI usb card.
Runing Windows 7 & JRiver or sometimes Vortexbox/Daphile with a quick HD swap.
Joe - no Aries connnected directly to the Konverter with a Curious USB cable.
Mark - no don't have a SMS-200 yet but thinking seriously about purchasing one.
Mat - certainly good value but shortfalls vs the straight Aries as Mark pointed out.
Terry - sold my good CD player a few year back so can't compare.
Why...you need a benchmark from which to demonstrate progress...
Oh yeah.  Gotcha....
Although I do think Clay knows where to get a good LPS [emoji6]
Guest scumbag
True dat
3 minutes ago, Raffinator said:
Don't doubt that...
To be confident that "its better"...then there should be an established benchmark as a base...
And it should be resident..
Guest scumbag
Why? cd seems a fairly arbitrary choice to benchmark to.
Sigh...OK...
Guest scumbag
And you'd be comparing to a specific cd player.
Then if not CD, which I would imagine is still the number one used source platform to listen to music, then what would be your benchmarks platform Mark?
cheers Terry
Edited by TerryO
Guest scumbag
I didn't bring up the topic of bench marking so I don't see that I have to answer that question. My point is that cd is an old technology so we need to look to contemporary benchmarks. Oh, and I think clay may have his own benchmarks but they may be encapsulated between his ears and not in a single example in a given piece of technology.
1 hour ago, Rob181 said:
Don't doubt that...
Its a simple test.
Listen with their supposed gee whiz bang revolutionary power supply they call pure power that is supplied with the unit and Clay's own power supplies he  makes.  Which sounds better - it shouldn't be hard.    I trust Clay's power supplies so much I asked him to build one and we will do just that.
Bill
Guest scumbag
Sorry for any derailing of the thread Clay . I am however at a loss as to why there is some onus in you to benchmark or prove 'claims' about your product.
Anyway, I'll butt out now otherwise I'll start getting more PM's about it....... Bye.
Edited by scumbag
That was done years ago when Mike had an uber CD transport.   At first it clobbered computer audio - then came the Audiophileo and units made by some company I forget that run off batteries and put in the original PDX's   It was clearly better so Mike got rid of it.
However Rawl99 has the really uber CD player - an upgraded Wadia that is better - it has yet to be surpassed although things are getting closer.   It however is in a different price class to any of this stuff and will not stream, do MQA and Tidal, all the new exciting stuff.  Is things like the Auralic now better or as good as the Wadia - don't know, but will take the Auralic over to Rawl's eventually and find out.
Rawl makes the Killer DAC but is finding those old Phillips double crown DAC hard to get and is looking at a new design that will be high res and handle the output of devices like the Auralic.  How will that sound - only time will tell.
Bill
Guest scumbag
Come on guys
I thought this was a thread about clays new dac preamp?
11 hours ago, TerryO said:
Hi Clayton, if you don't mind me asking how does it compare to playing the same music on CD?
cheers Terry
This is the simple question I asked in relation to Clay introducing the Auralic Aries and Tidal in to his system and his comments about how good it was when connected up with his Konverter DAC and some how others have turned it into a debate about whether or not I should have asked the question.
I wasn't asking Clay to prove how good his product is, I was simply asking how the two delivery systems compare on his system.
What is so wrong with me asking this question? As for CD's being old technology that has no relevance that was said years ago about vinyl as well, CD's aren't going to disappear any time soon and most people who will end up buying Clays products will end up having both CD's and systems like Tidal, which I actually do, so why shouldn't I as a potential customer be able to ask this question how the two delivery systems compare using his DAC?
cheers Terry
Edited by TerryO
Hi guys,
I think Terry & Rob brought a good point regarding just how well a good quality CD player stacks up against all the current streamer/server DAC setups which are getting really popular now.
Thank you bhobber who brought up the day at Mike Lenehan's when we all (our small group) finally decided that a music server + DAC Combo was the way to go. Asynchronous USB input boards running on very low noise PSU's was IMHO the game changer.
That was the also point in time when I personally moved away from disc spinners as a digital source.
However most decent DAC's these days have a coaxial S/PDIF input so its dead easy to connect a CD player as a transport & have a listen. It might be a good idea to use that as a reference point. Of course as someone pointed out the sound quality will varie depending on the CD player used. I know I was fairly disappointed with my Oppo BDP 95 when playing CD's & then one day just for fun I tried it via the coaxial input on my Klein DAC - massive improvement!
Anyway bottom the line is I will certainly try connecting a descent CD player into the Konverter S/PDIF input & see how it stacks up against other pc based digital sources. I still have a bit of a collection of reasonable Marantz & Philips CD players at work so time to blow the dust off & give it a whirl! Actually getting a bit nervous - I might be in for a surprise.
Edited by Gieseler Audio
Guest scumbag
So apologies to all for getting my grumpy pants on again last night. Perhaps I should impose a curfew on myself.....:sorry:
Hi Clay
We, by which I mean me, you and Bruce, tried it at a GTG you were at with an Oppo using a good Coax cable made by Keith Eichmann who was also there. It was into your Klein and it sounded very nice and analogue like - so nice I use it with my Oppo. But the USB was just a touch more transparent, detailed and lively.   By the usual criteria it would be, and was by most there, including me and you, judged better.  But the SPDIF was very nice, so nice I got a cable myself and use it between my Oppo and DAC, the Drirect Stream.  It was at that same GTG everyone, including me sat there wide eyed at how close the Klein was to the much more expensive DS - we couldn't believe it.   The Konverter is closer again - as Clay mentioned, and its true, you walk into  room where the Konveter is playing and you know there is a DS there.  Casual listeing will not reveal a diffference - only a careful comparison will - its there and you can heat it - but boy is it close.   Considering the DS is twice the price of the DS that's an amazing outcome - and you get a pre to boot.
Ok since I have the Oppo set up in my system and have quite a few actual CD's lying around I grabbed one - 25th anniversary edition Carpenters - Interpretations and played Sing.  To me via casual listening I really cant tell the difference and how I usually listen to it.
I usually listen to it by simply plugging my hard disk of music into my windows notebook computer and windows has an option to Cast to the Oppo.  I am now listening to the same album and song that way.  God its hard -  but its slighly more trasnsparent and dynamic.  Mind you I have passed the files through this program which does improve things by getting rid of clipping caused by ham fisted audio engineers and up-sampling to 88.1:
https://www.xivero.com/audiorepair/
Now for the heck of it I have on disk the carpenters singles in SACD but entropy encoded to Flac using:
https://www.xivero.com/xifeo/
Not a small difference - much more detailed, dynamic, better air, more 3d, all the usual HI-Fi stuff is better.
Now via Tidal.  They don't have the same album but have plenty with Sing.  So I played it that way.  It had a slightly thicker presentation - not as light and airy - but it sounded darn good.
Ok my ranking from this little experiment
1.  High definition cast to Oppo
2.  Normal definition but corrected and cast
3.  The actual CD
4.  Tidal - but it had a slightly different presentation - it would be a personal preference.
Note the Auralic has an audio engine likely to make things even better for Tidal.
What we can say however is CD is still viable and can produce good sound but, at least for the Oppo casting it from computer is better, but it may be due to the enhancing programs I ran it through and HD is better again.  That would seem one of the real values of computer audio these days - you can do a lot more with it.
Bill
Edited by bhobba
Guest scumbag
cheers Terry
Yes, on reading the posts from last night, I can only apologise for going off on a rant. That is a valid question.
All good Mark, no problems at all. ... :thumb:
cheers Terry
cheers Terry
Ditto...guilty of having those days...takes a good man to know & admit it...
Will the DAC only version be known as the Konverter as well or has it got it's own name?
Joe - the DAC only version will have a different name. Once again it's German & I'll let everyone when the unit is released.
@Gieseler Audio
Clay, what is the output impedance of the Konverter? Having a fleeting thought of trying it with an ME 75C power amp and know that the MEs love a (very) low impedance pre...
48 ohms so should have no problem driving the ME
