Gieseler Audio
GIESELER KONVERTER (DAC/Preamp) Official release.
Hi Ray,
the main outputs are either RCA or XLR selected by a switch. They do not work both at the same time.
However there is an additional pair of RCA outputs which are fixed output.
They output signal regardless whether you are using either RCA or XLR output from the main outputs.
Edited by Gieseler Audio
Fixed output, as in, not volume controlled? Like the old "Tape Out"?
Edited by BioBrian
too much confusion
Hi Brian,
sorry that is not clear. The second set of RCA outputs are variable outputs the same as the main XLR & RCA.
I just ment fixed in that they are not effected by the RCA/XLR switch.
Oh good, as I thought. Thanks for clarifying again, Clay.
So 2 outputs can be used at once: either XLR + RCA, or RCA + RCA, both volume controlled.
