Mat-with-one-t
SOLD:Stereoknight M-100 monoblock balanced valve amplifiers
Item: Stereoknight M-100 (100watt+ per side into 8ohms, or 200+watt per side into 4ohms - your choice) fully balanced design valve monoblocks WITH octet PrimaLuna KT-88s
Location: Melbourne, Australia (inner northern suburbs)
Price: $4200 ONO
Item Condition: Almost perfect
Reason for selling: Sidegrading (very reluctant sale)
Payment Method: Pickup - Cash, Paypal, bank transfer.  Pickup preferred (thus a buyer picking up will be given preference).
Here are a very hard to come by matching pair (sequential serials) of StereoKnight M-100 valve (tube) monoblocks.  I had originally purchased them off a gentleman here in Victoria, and since then they have been lovingly and sparingly used, as well as upgraded and some expense.  They are in near perfect condition.  They have solid aluminium cases (I've never seen a build quality like them - really!), and there are only the odd tiny marks.  I have tried my best to photograph all aspects of them.
Information can be somewhat difficult to track down, however for those in the know, these are built by the man now responsible for Audio Music (AM AUDIO) - Mr.Fang.  I am very happy to say that he is easy to contact and will provide any information and support needed.  He stands by his products, and they are massively over-engineered, so should last a lifetime!
Here are some links to have a look at.  Note that the StereoKnight site is no longer active, as the company is now Audio Music (AM), and most reviews and spec's are relating to the M-75 monoblocks.  Advertised here are the much upgraded M-100's, which as I understand it were produced only towards the end of StereoKnight's reign.  Some of you will likely be aware that these all were (and AM still are) distributed in Australia via Greg Osborn here in Melbourne.
http://www.osbornloudspeakers.com.au/
http://www.audioreference.co.nz/brand/am-audio
http://www.am-hiend.com/index.html
And here is a review of the (lesser) M-75's (please note the spec's on the ones I have for sale here are different):
http://www.dagogo.com/stereoknight-m75-mono-block-amplifier-review
Also note that I have added a full octet of select PrimaLuna KT-88 power tubes (4 per side).  These retail at $175 each (thus full set = $1400).  http://magentaaudio.com.au/product/primaluna-kt88-tube-silver-label/ I bought these tubes off a fellow member, at which time they had very little use (he changed to KT-120's as I recall). Note that, having discussed with Mr.Fang, you could use KT-120's in these beasts, making over 120 watts per side.  Wow.  Not that you'll need more power........Note that the newer Tung-sol KT-150's won't work in these according to Mr Fang (but now we're just getting greedy!).  These beasts, irrespective, will most certainly lend themselves to tube rolling, given how madly revealing they are!
At night, they look like two small cities all lit up.  Really cool.
NOTE: I am also happy to do a deal on the full set of KT88's (and some other spares) I replaced which could be used as spares (Electron Tube KT94).  Just ask!
Here are the specs from the web (for the lesser M-75's):
http://www.stereoknight.com/M-75.html
Specifications (note that these have much upgraded spec's.  Please contact Mr.Fang via AM Audio for specifics).
  • Tubes: 1 X 6H30,   2 X 6922  4 X KT88
  • Power output:  2×75W (8? ULTRALINEAR); 2x 140W (4? ULTRALINEAR)
  • Input: 1 x RCA, 1 x XLR
  • Frequency response: 10Hz?60kHz
  • THD: 1%(1kHz)
  • Input sensitivity: 2 V
  • Input impedance: 50 K?
  • Output impedance: 8?, 4?
  • S/N ratio: > 90 dB
  • Dimensions: 500×330×240mm
  • Net weight: 29Kg x 2
  • Power consumption: 550W maximum
  • Full balance design.
  • High grade 600W EI type power transformer, extra wide band C-core output transformer (StereoKnight signature).
  • High end components (Nichicon and Hovland capacitor), parts (StereoKnight designed heavy duty gold-plated binding post) and wire (TEFLON insulated wire and Japan made POCC rectangular solid core copper wire) all the way.
  • ZERO-NEGATIVE-FEEDBACK technology.
  • ZERO noise: dead silence background.
  • MOSFET voltage stabilization.
  • High control power (75WPC or 140W at 4?), capable of driving a wide range of loudspeakers.
  • Easily accessible individual output tube bias measurement and adjustment points on side chassis.
  • Detachable IEC power cord, high quality gold-plated StereoKnight custom binding posts and RCA jacks.
  • Full high quality aluminum alloy body construction, power meter in faceplate and acrylic enclosure cover design: sturdy built with art.
I have been using these amps as follows:
Pre - Wyred4Sound STP-SE
Power - Stereoknight M-100 valve monoblocks (via XLR in true balanced configuration) - I preferred ~100+W into 8ohms compared to ~200+W into 4ohms, but other systems will vary.
speakers - Osborn Epitome (approx 90dB efficiency)
sources - various, including hi-res digital and vinyl
I must say these amps are truly extraordinary.  I've never heard more beautiful bass.  They simply don't suffer from slow or muddy bass.  They are glorious in this sense.  Clarity is superb, and separation and soundstage blows me away.  If you're a jazz fan, I'd look no further (your favourite female vocal will make you shiver.  Start with a quality vinyl pressing of "What's New?" by Helen Merrill and you'll melt.  Having said that, I have a very eclectic taste in music (from jazz to classical to indie rock to heavy metal to 60's rock and back again....) and these amps produce it all with aplomb!  Anyone looking for high-powered (and yes, we're talking up to over 200wpc fully balanced into 4ohms if preferred!!), these are hard to pass up.  They'll drive almost anything easily. For those in the know, any audiophile tube amps producing this sort of drive usually cost well over the price of these!  They really do respond to a truly balanced end-to-end setup, so fire up that balanced Preamp and invest in some quality XLR cables (I preferred a copper/silver mix to all silver, however (as always) each system and ear is different)!!
I have all the original boxing and packaging.  I worry about posting, even with proper factory packaging, but can do if needed.  Tubes may need to be removed and padded up).  You will need to get your own power cords (although I can throw in some cheapies, however I'd recommend something to match their quality).  I have been very loving of them.  They have always been allowed to warm up prior to use (they really come on song after about an hour ideally).  They will definitely benefit from a couple of heavy & solid isolation platforms to sit on.  They certainly sound a whole lot better (especially mid range) with the PrimaLuna (silver edition) tubes, compared to the set of KT94's that came with them.  All my gear runs off a power conditioner.
Please note that the power output needle on (I seem to recall the right channel) one amp does not work.  It was not working when I got them (I am the second owner), and does not affect sound of course.  I have not looked into getting it fixed, however I am sure this could easily be done.  I may get the opportunity to have it looked at next week if time permits.
You'll note the little doors on the sides of each amp.  They come off with an allen key (supplied), and you need a basic multimeter (I'll throw in with the sale) in order to bias each tube.  There is a bias screw next to each corresponding power tube (see pics).  It's really easy, and according to Mr.Fang you can decide your output preferences.  These amps can produce a lot more power, but it's up to the listener what their preferences are.  Notably, the PrimaLunas went in and needed very little (if any) bias adjusting (ie. a matched Octet!).  http://www.primaluna-usa.com/tube-rolling
These amps go very easy on tubes (if standard biasing is applied), so they should last ages.
These monsters are big and heavy and beautiful:
- around 30kg each
- packaging adds 2kg each
- size (each in cm) is 46w, 22h, 30w
- colour is silver aluminium with clear perspex lids
I will happily arrange for an audition only for those truly intending to buy (amps are currently not in use).  I live in inner-north of Melbourne. Price will be formalised before this happens (I don't want to spend ages working through critical listening, only for someone to try to lowball me.  I am sure you all understand (and I will negotiate on price if required and reasonable), but it's happened too many times before).  I am always very light-on for time (it took me 3 months after having stored the amps to get around to this ad!), so please do your own research.  Price is negotiable, however it reflects age, condition, use, rarity and a $1400 tube set!  Don't let them pass you by if you've been thinking of high powered tubes but the prices have held you back.  Given this sort of quality and the bliss into which you will plunge, they represent tube heaven at this price range in my opinion.
Happy listening!
Mat
They do look spectacular.  Wonderful images that really sell them.  GLWTS.
Regards Cazzesman
pity where is that small lit up city?
It's a magical twin city that appears in my lounge after dark called "Tubeland".....
Regards Cazzesman
Thanks mate.  Yep they certainly make a statement!
I should also mention that I can do the amps with the original KT94 set (can discuss a price) if that helps bring the price back into range, and I'll sell the PrimaLuna tubes separately......Mat
Hi all - happy to do deals for the right buyer.  Can do instalments, tube changes, packages, etc.  sing out!  You don't often get a chance to grab high powered tube monoblocks!!!
Hi mate. Yeah still avail.  Trying to line up times for interested parties but as always, working too much so it's me that doesn't seem to be available!  Send me a PM if keen and we can work on a time to hear them....
Beautiful pieces, if only you where in QLD..
Haha I'm probs lucky, or at least my wallet is.
GLWS
GLWS
Cheers mate.  Will let you know if no locals end up grabbing them....
Thanks, appreciate it :)
The design is stunning. How do they sound in your opinion? (other than awesome)
Looking for tubes to pair with my Monitor Gold gx300's & Cyrus 8 Dac :)
I'm a bit biased of course, but they have a magic mix between the accurate thump and accuracy of a really good solid state amp, and tube warmth.  I have had a high end solid state with incredible attack and ease on the base, and have heard lower power tubes that I find lovely and engaging.  I reckon thee represent a meeting of the two.  Bloody amazing....
Sounds like a good pairing with my current system :)
Thanks for sharing
Will be following this thread.
Thanks for sharing
What pre do you use? I'd love to hear these babies with a range of pre's for my own interest, but I had settled on an excellent Wyred4Sound STP-SE for its amazing staging and it's convenience and balanced configuration.  Love it.
Only using the Cyrus 8 Dac - integrated amplifier via USB to my mac laptop. Very simple system at the moment lol, looking for something to Bi-amp or stand alone run the Monitor Gx300's (depending on which sounds better, bi-amp with Cyrus or just a nice tube amp alone)
Gotcha.  Well, the m100s would certainly run those speakers with ease (90dB sensitivity right?). I had a quick read and it certainly sounds like the gx300's love a bit of power!
SOLD.  Thanks all for your interest!
My spare set of 8x KT94's still available.  Send me a PM.  I'll get a separate ad up for them today.....
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By ViVa
      Struggling to find a decent Bookshelf speaker under $1k (maybe able to go higher)
      Liked the specs on Q Acoustics 3030i
      https://www.stereo.net.au/news/q-acoustics-3030i-standmount-loudspeakers-now-available
      The ELAC DEBUT 2.0 B6.2 are not bad on paper too.
      What are my options to get anything better than 46Hz and higher than 130W?
    • By alexb
      Item: Little Dot Mk II Headphone Amplifier
      Price: $SOLD
      Item Condition: Mint
      Reason for selling: Selling head-fi rig
      Payment Method: Pickup, EFT, Cash, Paypal (buyer pays all transaction fees & postage)
      Great condition and one of the best value headphone amplifiers available. Australian variant with 220v power supply. Upgraded Value Electronic CV4010 KQDD/K and 6H6 VIII tubes.
      The device has a single volume knob on the front along with a blue LED and of course, the 6.3mm port. At the back you can find the input and output RCA pots as well as the power button. The specifications of the amp are as follows:
      Input: Gold-Plated Unbalanced Phono (RCA) Jacks Output: 1/4" Gold-Plated Stereo Headphone out Driver Tubes: 6JI Power Tubes: 6N6 Frequency Response: 20HZ - 50KHz (-1dB) THD+N: 0.1% (50mW into 300 ohms) Suitable Headphone Impedance: 32 - 600 ohms Pre-Amplifier Output Impedance: 10K ohms Power Output: 300mW into 300 ohms 200mW into 120 ohms 100mW into 32 ohms Average Power Usage: 28 watts Dimensions: 210mm (length) by 110mm (width) by 130mm (height) Weight: 2.5 kg or 5.5 lbs.
      The Little Dot MK II boasts a SEPP (single ended push pull) circuit (in similar vein to the rest of the MK-series tube amplifiers) greatly increases sound quality, dynamic range, output impedance, and harmonic distortion. The Little Dot MK II also provides gain control of 3, 5, and 10 via internal DIP switches for fine-tuning so you can maximize synergy with almost any headphone you have, whether it be 32 ohms or 600.
      Some cheap tube amps have what is called a hybrid design, where the power is provided by a transistor based circuit and the driver circuitry is tube based. Examples of these designs are the headphone amps with only a single vacuum tube (the driver tube). Not only does the Little Dot MK II have a fully tube based design (both power and driver elements are tube based) it actually has independent circuitry for the left and right channels.
      So essentially, you have 1 power tube and 1 driver tube for the left channel and 1 power tube and 1 driver tube for the right channel. This is called an SEPP design (think of it as 2 + 2 design).
