pray4rain
Running single speaker
Hi, I need to run only one speaker but I'm worried if connecting only one speaker (using only one channel) to the amplifier is ok or not. I get monoblock power amplifier which seems to safer to me but I still have to connect/use only one channel of preamp. Can anyone explain the effect to amplifier when I use only one channel of Integrated amplifier or preamplifier?
But seriously, I doubt very much the pre-amp would care in the slightest. In fact a good pre will be dual mono any way, so one side is just sitting there wasting a little bit of electricity. No biggy.
Some power/intergrated amps are made to be switched into mono. Its called Bridged Mode, and normally leads to lots of power.
Even if your amp isnt one of those, than it shouldn't bother it at all.
No doubt there are exceptions to that ....
What amp do you have/planning on getting ?
One other thing to note is that, depending on the content, left and right channels will be different e.g. drums on the left channel and vocals on the right.
You will need to combine both channels with a MIXER.
Edited by custom_made
Guest Clarence
You will need to combine both channels with a stereo to mono adapter like this:
or a mixing device
This is a good idea too.
But I was hoping to read more of the source signal (is this mono? Or are we talking about an AV system's centre front?).
So many solutions, as in above or how about a single self-powered (active) speaker?
Only note, while desperately trying not to bring tube rant to here, you wouldn't want to run a tube preamp's single channel alone, maybe with one side tubeless, as this will unevenly wear what may be a matched pair, or the like.
First I've ever read of such a request.
My understanding is the stereo to mono adaptor shown is actually meant to be a single source to dual sink.  Yes as said it will combine the two signals into one signal when used the other way around but you also get the signal from one side of the pre amp injected back into the other side of the pre amp.
Geoff @gmdb from Aurealis Audio was producing a mixie to correctly combine stereo to mono and I'm sure can provide a lot more information on the "hows and whys".
Yep. Do this ^ (edit: As in, use a MIXER.)
If you hear distortion from the adapter, then you'll want to try a mixer.
To me, it looks like Mono to Stereo. I couldn't find one with Stereo to Mono (Female mono and male stereo).
yeah ignore that message and use a MIXER.
Bad idea. DO NOT use this!
You need a resistive divider or a proper mixer. Using the above device will, at best, cause distortion and at worst, damage.
Ok I've said twice to use a mixer since that message. I will just go ahead and delete the message so we can get passed that.
Haha, they're not going to let you forget it!
To the OP, Rane has a lot use useful articles, and this is one of them......
http://www.rane.com/note109.html
Regards,
Phil
Edited by tygersmoke
Guest Clarence
Regards,
Phil
Well, now I know. Brilliant.
With an addendum, there seems to be an assumption unfolding here that the source is stereo.
Edited by Clarence
Addendum
You need a resistor combiner lead.  It combines the two stereo channels into one.
Something like the attached.
Sorry, didn't realise there was lots of info in the Rane document.  The main difference it there would be greater attenuation of signals in the one I've posted above.  You could make the resistors in the L & R arms 470 ohms.
Edited by shogun2
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By alexb
      Item: Little Dot Mk II Headphone Amplifier
      Price: $SOLD
      Item Condition: Mint
      Reason for selling: Selling head-fi rig
      Payment Method: Pickup, EFT, Cash, Paypal (buyer pays all transaction fees & postage)
      Great condition and one of the best value headphone amplifiers available. Australian variant with 220v power supply. Upgraded Value Electronic CV4010 KQDD/K and 6H6 VIII tubes.
      The device has a single volume knob on the front along with a blue LED and of course, the 6.3mm port. At the back you can find the input and output RCA pots as well as the power button. The specifications of the amp are as follows:
      Input: Gold-Plated Unbalanced Phono (RCA) Jacks Output: 1/4" Gold-Plated Stereo Headphone out Driver Tubes: 6JI Power Tubes: 6N6 Frequency Response: 20HZ - 50KHz (-1dB) THD+N: 0.1% (50mW into 300 ohms) Suitable Headphone Impedance: 32 - 600 ohms Pre-Amplifier Output Impedance: 10K ohms Power Output: 300mW into 300 ohms 200mW into 120 ohms 100mW into 32 ohms Average Power Usage: 28 watts Dimensions: 210mm (length) by 110mm (width) by 130mm (height) Weight: 2.5 kg or 5.5 lbs.
      The Little Dot MK II boasts a SEPP (single ended push pull) circuit (in similar vein to the rest of the MK-series tube amplifiers) greatly increases sound quality, dynamic range, output impedance, and harmonic distortion. The Little Dot MK II also provides gain control of 3, 5, and 10 via internal DIP switches for fine-tuning so you can maximize synergy with almost any headphone you have, whether it be 32 ohms or 600.
      Some cheap tube amps have what is called a hybrid design, where the power is provided by a transistor based circuit and the driver circuitry is tube based. Examples of these designs are the headphone amps with only a single vacuum tube (the driver tube). Not only does the Little Dot MK II have a fully tube based design (both power and driver elements are tube based) it actually has independent circuitry for the left and right channels.
      So essentially, you have 1 power tube and 1 driver tube for the left channel and 1 power tube and 1 driver tube for the right channel. This is called an SEPP design (think of it as 2 + 2 design).
    • By Raffinator
      Item: Vincent Audio SP-T700 Monoblock Amps (silver)
      Price: $2,200 pair
      Item Condition: Very good. 2 years old
      Reason for selling: NLR
      Extra Info: For sale are my pair of Vincent Audio SP-T700 Hybrid Monoblock amplifiers in silver. I am the original owner, and they are 2 years old. Selling due to a change of configuration.
      See https://www.vincent-tac.de/en/product-lines/tubeline/sp-t700.html for full details.
      See https://funaudio.com.au/brands/vincent/ for link to current importer.
      I have the original boxes in good condition, and I'm willing to ship at the buyer's expense. 16kg each in two cartons.
    • By sa2013
      Item: Marantz PM-KI Pearl Lite Integrated Amplifier
      Price: $870
      Item Condition: Excellent
      I had this amp for about 5 years. There are few very small and hardly noticeable scratches on the right side of the top panel (see photos), apart from that it’s in excellent condition, local buyers welcome to have a listen. I have the original box, manual and power cable. Prefer local buyer.
      Key Features
      Ken Ishiwata Edition Integrated Amplifier
      2x 70 Watts RMS (8 ohm)
      Full discrete Current Feedback amplifier technology
      Toroidal transformer
      Copper plated chassis
      Marantz Original HDAM-SA3
      Power Amp Direct mode
      Here's one of many reviews for both amp and CD player: https://www.techradar.com/au/reviews/audio-visual/hi-fi-and-audio/audio-systems/marantz-ki-pearl-lite-sacd-and-amp-714688/review
      Also for sale Marantz SA-Ki Pearl Lite SACD Player.
      Thanks for looking.
