Maggie
FS: Ultrasonic Record Cleaner Kit
Item: Ultrasonic Record Cleaner Kit
Price: $300 + shipment
Item Condition: Like new
Reason for selling: Selling for a friend to recoup fund
Payment Method: EFT, Pickup - Cash, Paypal +3%, COD Only
I've been using a few Ultrasonic record cleaner kits, so far none impresses me until I come across this aesthetically pleasing piece  !
Superb high quality built with thick machined acrylic, easy to install and operate, it's certainly a clear step-up from the previous ones that I owned.
The ultrasonic 6L tank can be easily sourced cheaply from ebay which isn't sold with the kit.
The kit can be mounted firmly on top on any tank so far.  The device comes with the oz 2pin power cable.
2 units available, please grab 'em before they're gone.
Local pick-up is welcomed, shipment should cost around $20.
Note : The motor apparently hides in the black box, powered by the 2-pin power cable, it doesn't have a speed selection but the switch allows normal/reverse rotation.
Edited by Maggie
Add photo
4 minutes ago, BLAH BLAH said:
if it is 240v i'll take the 2nd unit please if available...
I'm not very sure, I reckon it's 220v-240v, have been using it for a couple of months w/o a single hiccup, so far so good.
I just got an ultrasonic bath, along with vari speed motor. Like others have said they are good. They dont get fingerprints/grime off but they can do good things to old records
Good luck:thumb:
Looks like a nice simple design.
Would you mind taking a picture of the back of the tank so we can see how it is attached.
Robin
Robin
    • By Maggie
      Item: Ultrasonic Record Cleaner Kit ( Motorised )
      Item Condition: New
      Reason for selling: Need Cash
      You know what you're looking for !
      You deserve a better quality ultrasonic cleaner kit, some low cost cleaners on the market may be compromised in term of overall built quality components and knotty problems.
      The kit is robust, practical and easy to setup/operate, not to mention it's an aesthetically pleasing piece !  The bracket is constructed with thick machined acrylic material.
      Local pick-up or interstate shipment ( $21-ish ) are the options. 2 units available. The motor is 'concealed' in the black box.
      Specs
      Single low speed mode for motor, powered by 2-pin OZ powercable 6 acrylic spacers
      Note :  The Ultrasonic record cleaner kit isn't bundled with the deal, you may need to source it separately on Ebay.
                 Any commercialised 6L record cleaner is fully compatible to use with the kit, costs around $150 with drainage tap & heating feature.
      PM me directly for further details.
