Full Range
Camera Bags - What suits you best
As a topic starter I would like to inform readers that -
I am now overstimulated in the pursuit of finding a camera bag that suits me
Many choices and styles are available - and it can make ones head spin
So I will break down my preferences
As an avid Cruising the Seas tragic with my better half - I see that as a lifetime pastime
So I need a multi purpose and multi carry camera bag
Help me find the ideal bag for me - or Should I design one ?
List of what is ideal for me
A bag that can fit a medium bit of kit - DSLR and a min of 3 lenses, iPad and nick nacks
A bag that can be carried in 3 ways
1) Back Pack, Front Pack & Over the shoulder
I will explain the reason - When Ocean cruising one is often in motion in and out of port
Also in and out of tender boats and tour busses - The front pack is for this reason as one does not want to sit down and lean back on the gear
For the back pack part of the equation - is for walking long distances with comfort
The over the shoulder option is for the purpose of moving short distances or when stopping / starting / sitting ect
Is my search in vain ?
I have a couple...
one where all my lenses etc sit for storage... its this canon one
https://www.bhphotovideo.com/c/product/248295-REG/Canon_6229A003_Deluxe_Backpack_200_EG.html
i got mine very cheap off the web. eBay I think.
the other one I have for on the go is a sling. the lowepro passport sling,
http://store.lowepro.com/passport-sling-iii
this thing is amazing good ! as can see in the photo it will take my largest zoom on the canon 70-200 f2.8L IS on my canon 5D4 full frame..with room to spare...and I can pack another lens in there usually as well which typically if going a combo it will be a wide lens.
and still leaves room for some other knick knacks and things i.e. it make and ideal day bag...can walk around all day and not notice it. do also at times sling over the shoulder and take with me when bike riding.
cost me about $15 from good guys I think i got the v2 on run out.
If you're a tourist overseas best to avoid ones that look like camera bags and certainly ones that are branded with a camera make. Over the shoulder bags get real tiring real quick. I have one. Don't use it anymore. My current "camera" bag.
http://www.blackwolf.com.au/product/Woody-30/280/category/1
Edited by KenTripp
Those backpacks in the links are great and I'm sure they can be worn as a front-pack
However they are to bulky looking
I need bag that is more slimline
I reckon they're stuffed as much as they can in that Woody for those pics. Here's the specs.
Capacity 30L
Weight 0.9kg
Dimension 42 x 34 x 23cm
full range i have a slightly different take on this I guess. while I have taken the back pack out at times... I wouldnt personally recommend it .... it tends for me anyways be more of somewhere safe to keep it all. and can mean I can take the entire kit somewhere with me if I want...though that would be very rare.
I've moved away from infield lens swaps... and want to keep myself away form temptation as much of doing that. so hence almost I will only ever take a lens on a body and one other. and if do a lens swap in the confines indoors rather than in the field. in field swaps best way I think is getting chunks of stuff in the sensor mirror/prism and viewings screen. stuff if manage on a trip will mean either stuffing all your shots and without even realising or then needing camera service which kind of thing wont really want to do on the move
so hence what I've suggested is probably in that case maybe not what you want.
there are probably slimmer options out there but probably not in what I suggested :)
Sell all of your gear, and buy either a bridge camera with 2000mm zoom, or m4/3 system so you can carry everything you need in a small bag. (J/k)
You should consider what you really need for each part of your trip and only carry a body and lens in a small bag to suit. The reason I do this is so I can put the camera away when we go for something to eat etc, plus to carry some water, otherwise I wouldn't bother taking a bag with me.
Thats exactly what I do now
I take a large shoulder bag with all the gear on the ship
Then I choose a lens for the tour and take that camera / lens setup in a camera case
My camera case will accomodate all my lenses up to the 300 mm ( one at a time of course ;) )
The small point and shot canon cameras are also packed and my wife uses them
At times she takes a superior photo
We use the small cameras for food photos
Apon our return I make a photo movie with titles and music as a momento and if we go as a group of friends they all get a photo movie
Because I have operated with an equipment bag as the main transport for the camera gear
And chosen a lens to use for the day to be carried in a small fitting camera case
I am drawn to the Canon 2400 Gadget bag and possibly a more modern and more comfortable triangle camera case to use on tours and shore trips
Get a proper case. Red velvet lined, leather clad and can take a knock;).
sorry I should have mentioned and I dont know if you mean this as comfortable triangle camera case. but I do also use a lowepro TZ1
https://www.amazon.co.uk/Lowepro-Topload-Standard-Canon-1000D/dp/B00004TX71
have had it for eternity 10+ years am pretty sure. down think can still get it but probably something else there.
its just your typical padded camera case and with a pouch in front which is handy for spare battery and a filter and the little tiny canon flash I carry - just in case :D
So I have just had a relaxing spa and made an espresso and started reading replies
My current camera case is more a traditional snug fitting T case
The triangle case I noted in my post is a little more generous and more comfortable on the shoulder ( see photo )
Edited by Full Range
Personally I like this...
https://www.bhphotovideo.com/c/product/672943-REG/Lowepro_LP36135_0EU_Exchange_Messenger_Bag_Black.html
I go against conventional wisdom and don't like heavy padding in my bags... the gear is heavy enough to lug around without adding more weight.  Unfortunately they are discontinued... I think they were about $30
" Lowepro "make a good range of bags, this one zips out from the back  which works well and has plenty of places to put things. 3 lenses in the bag + one on the body. Been convenient and easy to cart around all day working out of it and taking photos.
God I've gone through some over the years. The last and best "bag" I've owned was made by F-Stop.
I use a Rapid Strap for walking around, no tripod.
I use a military chest rig when hiking - so full pack of some kind on the back and the camera and 2-3 lenses on the front. I have a hydration sleeve on the back of the chest rig. The backpack goes on over that. Some people think this is odd, but it works surprisingly well and frees up a heap of space in your main pack. Surplus lenses and gear goes in the main pack...or in the case of the photos below, my daughter.
I dont have a decent photo of this, but here are a couple to give you the idea:
150217%20Hauy%20AK%20LK%20PK_zpsmuyc5gqp
150217%20AK%20PK%20Hauy%20Macpac_zpsir1c
The chest rig is fully adjustable and made by Platatac. There are a few parts to it, this is the main bit:
http://www.platatac.com/platatac-chicom-y-harness.html
Hazard4 make the molle bags which are customisable to suit what you carry. Camera in middle and two jelly rolls I think they call them on each side for the lenses:
https://www.hazard4.com/forward-observer.html
I used to hate carrying a back pack, see something. Stop. Take it off. Unpack the camera, blah blah...
...with this set up I can whip out the camera in seconds. I have a rain cover in the front pocket and it goes straight on if it starts raining hard. I keep the spare lenses in their own waterproof bags, inside the padded cases.
I developed this set up as I couldn't find a satisfactory camera bag to go on an Aarn Pack, which I dont currently own, but would buy in an instant if I was doing another big trip. I had a large F-Stop bag on that tassie trip and it wasn't good with a heavy load of gear. As least for me. So I sold it, but kept their excellent inserts.
Edited by Peter the Greek
@Peter the Greek  That setup is a little to full on for me - Don't forget I am on holiday Ocean cruising and trying to have a nice time and taking about 1000 photos
Rapid strap all the way. One lens, a few cards.
http://blackrapid.com/Straps/
They make one that can go on a small pack too
one of the reasons I like the sling I have as it can stay at the back like a messenger style bag, but if needed can slide around to pull out the camera.@WhoRu?  the sling I use without its padding, its a removable insert. and yeah the gear is rugged enough :)
my little TLZ1 is padded though and it with camera can fit in the sling if I want to keep some padding in the equation.
I'd find a small pack that fits you - find a good hiking shop near you. An independent, one with lots of brands and stock. Everyone is different.
I've had a lot of the various bags that you can swing round the front etc. I find them uncomfortable both front and back, so you get a shitting result all the time. At least if you have a great back pack, you'll not mind carrying and you can have the camera on the strap. I keep spare lenses in my pack in these things - https://www.hazard4.com/accessories/pouches/jelly-roll.html
and get one of these from black rapid
media.nl?id=219910&c=3398231&h=34304face
10 minutes ago, Full Range said:
No promises though
LOL, its not like I sell them!
Just a hard lesson learnt for me, if the bag is uncomfortable it ruins the trip. Camera bags, by and large, in my opinion are a farce. Hold the gear great, but comfort is secondary.....god I've dropped about as much on bags as I have bodies in the past 15 years.
If you're comfortable, you're happy and will enjoy taking photos more. If the bag is swinging around, digging in, slipping off etc etc it'll **** you no end.
That's my experience, others will have different perspectives. But they're not fashion items, you want to be comfortable (and functional)
 @Peter the Greek I have to take into concideration that I am traveling on weird and crowded transport - sometimes with 80 odd people
So I need to protect the equipment especially when jumping on and off rocking tender boats
Avoid hard sides and salty water spray
Now I have lost a few lenses to salt humidity when a few months on when they develop a growth inside the lens surface
Now I use inside my camera bags those silica crystal satchels to avoid a repeat
I'm a bit more anal about water protection. I put the lenses in the 1L verson of these things and then they go in those massively padded jelly rolls
Always take them out at night/when back someone safe and dry
Because I use a bum bag in my work on a daily basis I decided to look for a hip waist pack style camara bag
Low and behold I found one - http://clikelite.com/product/uncategorized/seeker/
Has a nice video description
I will look more closely into hip bags - as they suit me and the intended use
What about Think Tank bags I have street walker pro also have their digital holster 50. Both are versatile and reasonably priced.
Perhaps street walker hard drive would suit you better
heres a link to their website
https://www.thinktankphoto.com/pages/backpacks
i believe Digidirect sell this brand
Neo
Edited by Neo
    • By palexsia
      Item: Leica CL , 18-56mm Elmar, 23mm Summicron
      Price: $5500 neg ( rrp$8600)
      Item Condition: like new
      Reason for selling: bought for wife but she like cooking class in japan than photography .
      Payment Method: Pickup - Cash, Bank deposit
      Extra Info: bought this system for my wife in Australia for 3 weeks travel to Japan , she doesn’t like to learn photography instead cooking class . plenty review on you tube , google , Flickr .... will consider to swap with Fujifilm GFX /LENS or Xt3 /lenses cash adjust either way .
    • By jupiterzhao
      Item: Fujifilm X-T1 with 18-55mm Lens
      Price: $699 plus shipping
      Item Condition: Great
      Reason for selling: Move to Sony
      Full set of X-t1 and 18-55mm lens.
      Basically come with everything as it was purchased, even every single paper.   The list: ●X-t1 Body: some signs of use (please refer to the second photo), one-two tiny dust on the CMOS.  A protect glass on the screen since it was purchased.  The eyecup is a little bit wind up which definitely not affect usage. ●Brand new Fujifilm original camera strap. ●Brand new Fujifilm Flash ●An Original Fujifilm charger ●A third-party charger ●2 x Fujifilm Batteries & 1 brand new third party battery ●18-55mm lens: a Hoya UV has been installed since the lens has been purchased, Never removed.  Tiny dust inside the lens, which absolutely not affect the image.  NO scratch, NO fogs, No haze, No separation. ●Original lens hood ●A Hoya UV as described. ●A High Quality Leica M to Fuji mount Adapter ●A Viltrox Nikon F mount to Fuji mount Adapter ●Brand New Meike AutoFocus 10mm + 16mm Micro Extension tube. ●All of the body and lens caps ●All of the receipts, manuals, other papers everything inside the box.
    • By EdgyGrimDark
      Item: Olympus OM-D E-M10 II + EZ-M1240 M. Zuiko Digital ED 12-40mm f/2.8 PRO Lens + EXTRAS (64gb SD, Carry Bag, Spare Battery)
      Price: $700
      Item Condition: 9/10 like new
      Reason for selling: medical expenses/ no longer into photography
      Extra Info:  shutter count is 1821 actuations
      Comes with a SanDisk Extreme 64 gb Card, LowePro Carry Bag and a spare battery (used once)
    • By EdgyGrimDark
      Price: $750
      Reason for selling: No longer interested in photography
    • By EdgyGrimDark
      Item:
      Price: $1000 $900*
      Item Condition: 9/10 like new, well looked after
