Battery Based Audiophile Beyond
Yes have had sandstone under all my gear, i rate it especially under speakers. A tt plinth wouldn't be hard, i wonder how it would sound?
Sent from my SM-G930F using Tapatalk
I've not seen it used. Every other type of stone except sandstone.
Interesting week.
Getting ready for the lift this week. digger tomorrow, crane Monday, weather dependant
because the containers sit side by side hard up together a gasket of foam, 12mm thick 70 wide builders foam tape has been applied to water tight and not allow resonance between metal to metal and or all the gaps.
painted all the stumps with bond crete and then grey paving paint
cut rubber heavy 10mm conveyor belt to support foot fall of corners and wall support
Starting at 7 am in the morning to core fill the footings and create service adit.
@upfront, will take some pictures tomorrow ::)
Edited by Guest
3 hours ago, TOPSHELF said:
That's a bit bigger around 5t. Sorry i tried to flip the pic.....
That is interesting, stone cutting
Have plans to use acoustic mass loading (to keep some bass in) in the form of an outer wall in timber and stone around the tin box (s)
Good luck with the lift mate
After starting at 6am, early for me, site is ready for the lift so first opportunity all the building will be together :party
Lift will be fine, today we placed an eight x eight meter bay, a foot deep of crushed al in rock road base under the crane, track rolled in ready to go.
Photos shortly if any interest
Notice.
The Mods will probably move this thread back to the showcase forum, which is fine.
Thanks all for interest
Regards
Doesn't look much but some time has gone in here.
The ground in the white stuff is particularly hard, like goats fore head in fact.
The stumps go down 500mm minimum and are at the least 450 x 450mm, center ones are 600 x 450 x 500mm. The quartz was literally chiselled with a jiant petrol jackhammer and grubbed out with the plumbers pot hole shovel. Quite alot of quartz went back into the concrete mix (done in a barrow :)) all 12 of em.
Surface bonded and painted .
Crane pad ready, 40 x 120m flat site almost ready for the big leveling job and top dress with screened blue metal
Existing road to be cut down to level as well as taking down the top perimeter drain about 1200mm for the entire top boundary.
Just booked the 50 ton crane. :)
Might kick back for a couple of hours, catch a nana nap and watch a movie.
The stumps go down 500mm minimum and are at the least 450 x 450mm, center ones are 600 x 450 x 500mm. The quartz was literally chiselled with a jiant petrol jackhammer and grubbed out with the plumbers pot hole shovel. Quite alot of quartz went back into the concrete mix (done in a barrow [emoji4]) all 12 of em.
Just booked the 50 ton crane. [emoji4]
Recon you deserve a beer!
Had a couple last night, thus the nana. Will be ready to go after that tho :)
Nice work! A hole is the only thing i know that gets bigger as you take more away. Enjoy those beers 125db.
Thanks Mate !
Takes more to fill as it gets bigger :) There is 5 full barrows of cement mix in some of those.
... sounds like a lot of work.   I'd be relaxing for a few days rather than hours  (I'm soft)   ;)
:thumb::thumb:
Lookimg forward to the next installment Matt
Me too Mate, big day the crane lift, means roughly a quarter of the work is done. Pull up the gasgets tight with truck ratchet straps and weld the boxes together :party exterior and interior makeover will commence at that point err after I can make a few coins is a 2 sided build
Just out of interest, what do you expect the gap between the two containers to be? Obviously close enough to weld but what are you thinking?
@Upfront
The points on each pf the 8 corners of the containers for lifting or locating are proud of the outer steel box section, they will end up hard together  (weld there inch tac) with a result gap between the top box section steel (50 x 50mm) and the "C" sections at the bottom by 6/8mm. Weld 6 x 25 x 50mm tag at 3m intervals bridging gap. All gasless mig.
Top will seal Ok with the expansion joint foam tape at 10mm thick before compression, which I believe will need more than the weight of the containers side by side to squash it.
Bottom will have a gap between containers of similar 6/8mm and easy to flash over before floor cladding, to keep the spiders out :)
[mention=111049]Upfront[/mention]
Bottom will have a gap between containers of similar 6/8mm and easy to flash over before floor cladding, to keep the spiders out [emoji4]
Sounds like it will be sealed up nicely. Looking forward to seeing the final results.
Will need photos.
But will it keep Matt contained...
Doubt it [emoji13]
Will need photos.
Will be a slow build, but around Christmas, might have something to show after putting a years earnings in and a few overtime hours and weekends, same as the last one.
Yep sure will.
Last lounge build unless someone wants to pay me to build another :)
Lift of boxes Completed, inc travel less than 2 hours.
Single biggest part of the task done., except for probably the tin roof.
:party5000 nth post
1 hour ago, 125dBmonster said:
:party5000 nth post
Pretty neat 5k post.     Here's a crane building my new listening room.      <boom>
New lounge, looks peaceful, quiet and a great place to explore lots of media.
Fair way to go though :) but this is it so far
Boom tish @davewantsmoore Mate.
What is @Upfront doing to his Azura Horns ? Making another set ? Or tart up ?
Just out of interest, I dont like trees and flammable materials around Building protecting its contents This one will be particularly fire proof  Tee Tree Bush line, may as well be turps impregnated fire wood, will take a brick home at 20m if a blaze.
    • By Josh83
      Item: In the market for a turntable. Have my heart set on a Clearaudio Concept. I live in Sunshine Coast Qld though I’m open to pay for delivery if the table is right.
      Price Range: $1000-$1500
      Item Condition: New or Used
    • By tachi
      Item Condition: Good condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Huntingdale State: Western Australia Payment Method: Paypal, EFT Reason for selling: Moving on Further information: This is a MMF 9.1, bought in Singapore. The main difference between this model and the Australia model is the motor. It uses a 16V ac motor. I  have been using it for the past 6 years' without any issue.
      Specifications
      Triple Plinth
      Drive method: belt drive
      Motor: 16 V ac motor
      Platter: 1" Acrylic
      Speeds: 33 and 45rpm
      Tonearm: Project 9cc (carbon fibre)
      Price includes a fully functionable turntable with dust cover and please note that no cartridge is included. For a detail review, please refer to:
      http://www.stereomojo.com/MusicHallMMF9.1Turntable Review/MusicHallMMF9.1TurntableReview.htm
    • By thejt
      Item Condition: General is good, cover has scuffs and crack Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: noranda State: Western Australia Payment Method: Cash, EFT Reason for selling: Trying a Thorens Further information:
      A great sounding turntable (preferred this to the Technics SL-7 I had) and just a fantastic piece of design. Like you would expect from a direct drive unit gives great energy to the music. I got a lot of joy from this turntable and as a dad found the auto functions very helpful allowing me to use a turntable while handling dad activities either with repeat or auto stop. The motor starts up instantly and holds speed without issue. Stylus still good but with unknown hours, will throw in a fresh stylus though with the purchase. The cover is cracked and scuffed but would improve with some headlight polish. The fit and finish on this is exemplary and build quality high, motor is dead silent. A toroidal is used for example, check out the vintage knobs page for more details: http://www.thevintageknob.org/jvc-LE-5.html
    • By CorzaMoon
      Item Condition: Very good. Just missing 2 rubber feat pads. Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Reservoir 3073 State: Victoria Payment Method: Paypal, Cash on Pickup, PayID Reason for selling: No longer needed Further information:
      Excellent condition. Small but powerful. Comes with special banana plug connectors and AC power cable. Tested and in perfect working order. No manual (can be downloaded online). Missing 2 of the rubber feet underneath (see photo).
      SPECS: 2x50w stereo power amplifier
      Bi-amping possible
      Input: RCA Output: Banana plug (4 included)
      Power supply: 230v, 50/60Hz, 200w
      Power consumption (2x50w): 185w
      Dimensions: 21x7x36cm
      Weight: 4.3kg
    • By hugo_wilco
      Item Condition: Excellent just a bit of dust Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: Victoria Payment Method: Eft Paypal Cash on pickup Reason for selling: Funds required Further information:
      Unfortunately due to Pandemic I am forced to sell my gear. This is my favourite TT and has been the longest I’ve had. This TT is phenomenal and I don’t  I want to let this go but don’t have a choice.
      The Ref2 is the latest with the updated power supply.
      Purchased from the wonderful guys at Sonic Purity.
      Will be selling  Phono stage separately
      Your chance to get an endgame TT package at nearly Half  price!!!!
      RRP: $14,900
      Buyer to pay out of pocket Paypal fees.
      Will be boxed so can arrange freight to interstate.
      TURNTABLE ONLY FOR SALE
      Have all boxes and packaging. Will be boxing them in the next few days Nd will post photos.
