Battery Based Audiophile Beyond
@Upfront
Have the total compliment (team) of Amps heavily biased and tweaked ready for action, test and tune by Anthony and I today. [emoji4] Was great to see Anthony.
GTG will be announced tomorrow for the "weekend after next" if you are keen.
On the menu for the GTG.
  • Mystery Monster amp from Launceston, with potted and shielded 2Kva Transformer/ billeted machined plate case. running 4 Exidos Maelstrom 18's
  • 2 off 2 x 50w, bilet case amps, bi amping a set of nice bookshelf speakers with carbon Seas Drivers and tweaked crossovers
  • the Horn Rig with 6 x 18" drivers and 2200wRMS into 8 ohms on tap.
  • Battery Rig with Rasberry PI/HiFi Berry DAC front end
  • Record swap/trade
The whole thing totally off grid, merits of power supply, with the big(er) gear
If you are interested Mate.
TBA, Tassie Lounge, tomorrow
Very interested mate. But wont be able to make it that weekend.
Name a weekend except this one coming and we'll try for that @Aussieamps
Edited by Guest
punctuation :)
Should be fine anytime after the 14th mate. I'm happy to do the driving so there are 4 spare seats if anyone wants a ride up when the date is set.
See if Anthony is available and I'll post a date, should be fun.
Would be cool to fill the car Man.
Would be! We're talkimg about filling it with amps on the way home right! ?!??!?!?!?[emoji13]
Hi Guys
Lets make it for the 21st Jan, I am pretty flexible. Would be better that way, Have a longer time to prepare the new amplifiers.
Hope to have at least 2 new Holton Zero-Five-Zero amps as well as a new never seen before 500 watt x 2 dual mono block stereo amp.
Basically a cut down version of the Ex-Nihilo Mono Blocks that we had at the last GTG at Matt's Sound lounge. :)
44 minutes ago, Aussieamps said:
Hi Guys
Should be a great weekend Anthony, plenty of systems to listen to and look at.
Since
@Darren69 was at the lounge 6 months ago development of the lounge and systems have come a long way.. The 11 square meter mass loaded 3D bass trap on the rear wall fixed the last of the acoustic issues within the Lounge.
The room must be bloody pressurised by now then! :D
Interestingly Daz, I have a slightly different approach to room measurements than the norm. Use my ears, a clap tests + take video of the system and sound recordings (in a rudimentary fashion). Play back the recordings at every step or change, listen and compare results.
The concrete lounge has lost its "toilet block echo" this is evident in the systems performance on comparison to earlier recordings.
There is roughly 70% more RMS available to the horn rig, which does rule the 18's with the silk glove clad iron fist, to well over double the SPL you experienced Daz.
Last little job is to replace the Eminence Magnum 18's and enclosures with something better. A new pair of enclosures and the pair of Acoustic Elegance TD18"s. Nothing wrong with the Eminence, is just that they have an X Max of 5mm compared to 15mm of the Acoustic Elegance, vast power handling difference there.
Ok, but you will be needing extra power headroom?
Or just a 'nice to have in case'?
Head room for classical music and other music with wide dynamic range.
Dynamics/authority.
Detail of presentation, following a theory from the old 5500w battery rig "more amplification is better"
Reduction of noise floor.
It's fully active and may go to 7.1 in future
This system won't reside in that lounge for all that much longer, it's on the move to another local, much bigger room
Am sure it will shine more in a larger area, really looking forward to hearing it again, maybe 2018.
Yep, you can never have too much power.
Is a different beast to what it was, thanks to the power supply and the bass trap, but to do it justice, yea, bigger lounge.
@davewantsmoore
Are you thinking of grabbing a lift with Linc, Dave ?
Would be great to catch up again.
Always welcome Mate.
This is quite a good approach for a subjective analysis.   A neat torture test is to, set up the microphone and record the playback.
Then, play the recording through the system, while you record it again.      The repeat this 9 times.
So now you have 10 recordings each one a more degraded generation.
Once you've done this for multiple systems (must be in the same room) .... the test is how many generations can you tolerate before the recording sounds terrible.    The results can be quite surprising.
Yes, you are dead right Dave. Havent done that particular test, but I can understand the theory behind it.
Listening to the lounge/system via some pre bass trap installation recordings on (the Canon 7D) is revealing to say the least
I try use the same track on a particular album, boring as mud but works.
EDIT, forgot to say I always measure at the same SPL of about 85dB, so as not to saturate and clip the mic output
Edited by Guest
Better photo.
Might get this going tomorrow.  Looks fantastic, will be quite a lot of fun.
1 hour ago, Aussieamps said:
Wow! That arrived quick.:)
Was like Christmas all over again when my little Guy came down to the Lounge last night with a cardboard box.
Myself and some Mates carefully opened, examined and marvelled at the contents. Looks like everything is Ok, no shipping damage and very well packed
Is lovely Mate, thanks, will be a proud moment to fire it up, just have to mow the yard first. There is a blackberry vine invasion as well that needs attention before it literally walks over the fence, never seen one grow so fast in all my days and will be making Jam soon.
I have the same blackberry issue to deal with today .... although won't be making jam
Ran the hedge trimmer over this "thing" last week, but didn't even slow it down
@davewantsmoore would have 10Kg's of green fruit on at the moment, the plumb tree under it didn't fruit this year :) which is Ok, as there will be blackberrys lots of em.
Yes this is a set up for stereo the amount of cabling blows me away in comparison with a single pair of passive full range speakers. Surprised there is no cable born cross talk or induced noise with this lot :) so happy with what is there, now to make it look Ok.
Will be spending a full day behind that (and mowing lawn) to tidy it right up re terminating some and heat shrinking, attempt to get  rid of the birds nest, also re stacking into 2  piles will post another photo before days end
Rough but ready for the GTG on the coming weekend. Platform for gear is a large 50mm thick 1.6m long blackwood slab on rubber feet so the 2400w of amps can breathe
Edited by Guest
    • By Wilde
      Item Condition: Used Shipping Options: Pickup available but audition is not available. Suburb or Town: Peakhurst State: New South Wales Payment Method: Cash on pickup Reason for selling: No room for it Further information:
      I purchased this turntable new less than a week ago. I intended to keep it but there is no space to set it up properly in the area I keep my system. I’m selling it because it is unfortunately too impractical for me to set it up elsewhere or change the furniture around.
      The turntable was used once on the first day I got it. Everything is in working order and in as new condition. I also have the box, manuals etc.
    • By thorpef1
      HI all.
      I have a stereo Setup (Denon DRA-375RD and Wharfedale Diamond 9.5) which i am relatively happy with for the time being (with the little one running around).
      It is mainly used for music but is also plugged into the TV for when we watch movies. The room is around 20sqm
      I was thinking of adding a smallish sub to compliment the system using high level inputs as the amp does not have a sub out.
      What would people recommend for a sub $500 sub, i dont mind purchasing second hand as i will eventually do proper HT when the little one grows up a bit.
      I would predominantly want it for music but also be able to perform when watching movies (that is more important than sounding good with movies and poor with music)
      Luke
    • By JimmyDee
      Item Condition: 3 yrs old - Perfect working order Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Perth State: Western Australia Payment Method: Paypal, EFT, Cash Reason for selling: No longer required Further information:
      70W/channel Stereo Amp and DAC. Great for hook-up to a digital source (ie computer, tablet, pod, CD player) and bypass their inbuilt DAC to utilise this far superior one.
      The USB D/A converter is the 32-bit high-performance SABRE 32 from ESS Technology, and its USB device controller IC is the latest product from XMOS, the semiconductor firm. It is compatible with native playback of the DSD 5.6MHz (DSD128) format or 384kHz/32-bit playback. Supported formats are:
      MP3, WMA, MPEG4, AAC, WAV, FLAC, AIFF, ALAC, DSD – 192 kHz / 24bit; 96 kHz / 24 bit; 5.6 MHz
      Few minor scratches on top cover.
    • By bigears
      Item Condition: Excellent (one small scratch) Shipping Options: Pickup available but audition is not available. Suburb or Town: PASCOE VALE State: Victoria Payment Method: PayPal, cash on pick up Reason for selling: Need to raise funds for family expenses Further information:
      Purchased in 2013 from Audio Fidelity as Ex Display, (Came with a small scratch on crystal platter).  Low hours of use and well taken care of, Perfect working order with no damage. This is a stunning piece of German engineering with the audio quality just as good.
      Unfortunately not original packaging is available with this turntable, (so not to keen to ship)  But i do have the tools and perspex dust cover for it.
      Drive Mechanism: Direct Drive, Platter driven by a proprietary, magnetic field motor Power supply: External, solid-state power supply Bearing: Hydrostatic, zero-maintenance bearing Platter: Resonance-optimized, anodized aluminum alloy; crystal-glass platter mat / clamp Plinth Oasis: Resonance-optimized anodized aluminum alloy, wood frame Chassis  Oasis: Movable (rotating) without play for simple and precise tonearm adjustment. Accepts all tonearms between 9” and 10.5“ effective length Connectors: RCA, or feed-through for tonearms with 5-pin DIN connectors RPM: 33 1/3 and 45, selectable by a switch LED indicator for speed (33 1/3 = green, 45 = red) Deviation from nominal speed: 0.0% (adjustable) Fine adjustment of speed: ± 10% with trim pot Wow & Flutter: 0.07% linear, 0.035% weighted DIN 45507 Speed-up time: 12 / 16 seconds (33 1/3 / 45 rpm) Rumble (noise): -64 dB (test record DIN 45544); -68 dB (measuring adapter) Weight Oasis: Total 26 kg (Plinth 15 kg, Platter 10 kg, Power Supply 1 kg)
    • By Brian_S
      Hi all.
      Hoping some of you gurus may want to weigh in with some advice / direction please;
      I have an RP6 with Exact cart, upgraded with Groovetracer sub platter and Little Belter blue belt. I love it - rhythmic, engaging, detailed - so much so that my LP12 has been relegated to the soon to be sold shelf in my storeroom (controversial, I agree).
      So, now considering upgrade paths for the RP6 I'm considering one / some of the the following;
      Groovetracer Delrin plater (approx $700),
      RB 330 tonearm (also approx $700),
      NEO PSU $449
      Fono MC preamp $449
      Ania MC Cart $999
      Alternatively, I could sell my existing RP6 for (say) $1000 and pick up a new P6 TT w no cart (that already includes the NEO + RB330) for 2K, or with a new exact fitted $2399. or with the Ania MC for $2799. So basically I could have a new P6 for a cost delta of a grand.
      I have my own ideas on what would give the best improvements / cost but would really appreciate recommendations from you all on what path would provide the greatest sonic benefits.
      FYI - the RP6 plays directly through my Plinus 9200 in-built phono stage.
      Thanks in advance.
      Brian
