Battery Based Audiophile Beyond
New page beyond 100  pages
Link back to the Battey Based Audiophile
http://www.stereo.net.au/forums/topic/75988-a-battery-based-audiophile-story/
Time to start a fresh chapter, or think of it as going from prep to grade 1.
This thread will be similar but will concentrate more on the finer points of
1. Room, listening zone acoustics, in response to the stereo or actual waterfall plotting and explanations
2. Getting to the bottom of testing and applying data to speaker response curves, the outside test and then the inside of the room for the fully active system.
3. Front End of system.
4. Speaker Enclosure and Amplifier construction.
5. Opening a hobby based specialized Audio listening Center on NW Tasmania.
6. Off Grid Power Supplies for AV and why they can be superior. The DC/DC stereo will pop up from time to time as well.
Edited by Guest
  • Replies 1k
Popular Posts
It is with great honor that I have been asked to post details of completion for the following threads: https://www.stereo.net.au/forums/topic/242308-quick-diy-flex-racks/ https://www.stereo.net
A bit off topic but here is a photo of a DC Blocker I am building for a customer. has 4 x 100,000uf caps for the actual blockers and the nice industrial volt and current meters.
Here you go hot off the press!   Rear panel will be fitted soon, so more images to come.
On 12/16/2016 at 3:24 PM, Upfront said:
My what a big battery bank you have!
Big enough to get the Police out for a visit after midnight :D:partyand stayed for an hour watching Star Wars, haha
While thhe Mrs is away
opps
Edited by Guest
New Chapter,
New Gear List, starting with the mains driven system almost completed construction.
Something to be clear about, power and IC cables are either DIY or the 10buck IEC. Personal belief that good fresh connections are of more value than expensive ones.
Design and application
4 way, Floor Standing, active big system capable of over 125dB with frequency response from 10Hz to 20Khz,
Test and Verification
miniDSP usb mic, REW
Audio Control, 3rd Octave real time spectrum analyzer, Calibrated powered mic.
Power supply.
SMA Sunny Island 6, 4.6Kva continuous 10Kva+ transient peak at mains volts of 230vac at less than 3% waveform distortion allowable before supply trip at full peak loading
10, Suntech 270w Mono Solar Modules in a string charging a 15Kwh Absolite AGM Battery
Method of charging battery is via an ac coupling with a SMA Sunny Boy, 2.5Kva grid tie type Inverter, re programmed to run off grid.
2 separate 230vac mains circuits,  4mm2 for amps @ 20A, 2.5mm2 @16A for the front end with 500va isolation transformer as an optional full isolation for the front end of the single ended unballanced system. Conventional MEN to the same earth stake as the rest of home.
All power points are the Clipsal double pole type
All associated protective Switch Gear is NHP Mod 6
Speakers
PSE 144, 2 way Point Source Horns, 250Hz and up to 20Khz
Eminence Magnum 18" mid bass (or)
Acoustic Elegance TD18'+4 (enclosures to be constructed), 32Hz to 250Hz
Exidos Maelstron x 4, 18" subs 10 to 32Hz
Amps (power)
Holton Precision Audio
3 x  250wrms x 2 Dual Monos
1 x  6 channel, 4 x 100wrms and 2 x 150wrms
Total amplification expressed at an 8 ohm impedance, somewhere close to 2.6Kw. into lower impedances such as the subs and mid bass of 4 ohms, 5Kw
Front End and DSP
miniDSP 2 x 8 with miniDSP Dirac, for starters  or whatever comes along like a pair of DEQX units
Burson Conductor  as a pre
The venerable ASUS STX sound card, as stock or heavily modified, highly media oriented customised PC
A choice of TT pre amps, valve or SS
Micro Seiki MR611 Turntable. Clearaudio Beta 1 wood body Cart
Networked via Synology 4K capable NAS,
time to get to work, finishing off the new amps.
Edited by Guest
New Chapter,
Floor Standing big system capable of over 125dB with frequency response from 10Hz to 20Khz, clean undistorted.
Power supply.
Speakers
Amps (power)
Front End
Burson Conductor
Looking forward to hearing the new amps mate
Me too, if I get my act together will get them close to fire up today or later this week
Starting to get on top of building the lounge/shop, power supplies and other wonderful stuff. Life is good.
More panels going on, building Custom ready to install RAPS, test battery and cables/protection, lots of things.
Edited by Guest
On 12/22/2016 at 2:22 AM, Upfront said:
Looks like santa has already been to your place mate!
Should hear em workin.
Yep Santa came early
Nice "plug" Linc, nice
Edited by Guest
50-0-50v transformers 625va x 6, platforms with rubber mounts and blind nuts going together. Closer to done, some power wiring and commissioning mosFET bias from there
Edited by Guest
On 12/24/2016 at 4:02 AM, CryptiK said:
Nice work man. Only 4 output devices per channel? How hard will they be working for the amps output?
Hello, I believe the mosfets are specified carry around 250w into 8 ohms, per side. Dual die Exicon fets.
The power supplies could be pushed to 4 amp modules easily and may modify one of these to make a 4 x 250w
Hiding the subs works. seems to have instantly lost the "intimating look"
Treating those with black carpet, some baffle plates and grills will work there me thinks although, getting the "thing" working should proceed before the deconstruction of the subs.
Where did you hide them?
Under the looms of material. Taking those off is like unveiling 2 statues of the school playground bully's . :( but ugly
Will work on some cosmetic intergration
Under the looms of material. Taking those off is like unveiling 2 statues of the school playground bully's . [emoji20] but ugly
Just looked back on the last few photos. Got ya now! Not exactly "hidden"!
Have been known to hide things in plain view before.
Experimenting with the looks of everything, I may settle for this.
I wouldn't worry about hiding them mate. Own it!!!
Will start with this lot,  almost ready for power up.
Holton 6 x 100w and 2 x 250w, miniDSP 2x8, miniDSP Dirac DDRC-22D, the Retrothermonic valve pre.
Bring the other amps in later.
Start with records and analogue in to get a feel for what is going on with the rig.
The new face plate on the 6 channel blinged it a bit.
Edited by Guest
Always good to start simple with so many new toys to play with mate. You need to fight the urge to throw everything at it!
Bet there will be another year or so fiddling about in this one Linc.
Going to start fresh with field measurements, want to hear it playing music again first though, has been 6 months.
(just in the motions of getting the front end up and singing).
Interestingly enough there is well over 1000w RMS in that pile of gear, let alone the rest of it.
Edited by Guest
It's the type of system that you want to get out of bed early like a kid on Christmas day (weekends or holidays) so as to get the tunes rolling.
Nice to have the big system going again. The horns exude resolve, feelings and emotion. Revelation of content with authority
The journey is over, made it home.
Just another few enclosures/baffles to build for fun and some details with amplification to sort out and the job is done, with this one.
    • By DomS
      Item Condition: Good used Shipping Options: Pickup available and you can audition. Suburb or Town: Mawson State: ACT Payment Method: Paypal / Cash on pickup Reason for selling: Upgraded Further information:
      I've had these speakers from new for just over 2 years, and they still look and sound great.
      Perfect for an entry-level home theater setup that goes beyond the basic packages available for. By buying without a sub, you can also choose a sub separately that best suits your room.
      The NS-555s are also good for listening to music in 2.0, with a reasonably full range for their pricepoint and an easygoing, natural sound signature.
      The NS-555 speaker grills have never even been taken out of their packaging. Original feet all included and in good condition.
      Package on offer:
      - Yamaha NS-555 Floorstanding Speakers (pair)
      - Yamaha NS-C444 Centre speaker
      - Yamaha NS-333 Bookshelf Speakers (pair)
      Package can be split, PM me if interested in individual item prices.
      Limited audition available (I can show each speaker works using a spare mini-amp - Topping MX3).
      Please PM me if you have any questions.
      Pick-up only - As I don't have appropriate packaging to send by post.
      See attached.
    • By W47ty
      Item: Heed Orbit 2 PSU
      Price Range: neg
      Item Condition: New or Used
      Extra Info: looking for one of these for my TD150mk2 give me a shout if you have one or have an alternative psu to offer. Cheers chris
    • By audioaddict78
      Item: Genuine Technics 6mm rubber mat for SL 1200 series
      Price Range: $60 - $100
      Extra Info: Looking for genuine Technics 6mm rubber turntable mat. Must be in excellent condition. The part number is on the mat's flipside -  RGS0010
      Sydney local is ideal, but happy to pay for shipping.
      Thanks!
    • By Shane Stephenson
      Item Condition: Excellent Shipping Options: Pickup available and you can audition. Suburb or Town: Herne Hill Geelong State: VIC Payment Method: Cash or Bank Transfer Reason for selling: Too many turntables. Further information:
      Up for sale is my much loved Linn Axis turntable with Ortofon Super OM 40 cartridge. The super OM 40 cartridge is one of the best moving magnet cartridge Ortofon make. The turntable has just been completely overhauled and serviced with a small repair to the motor motherboard. The cartridge is new and just set up professionally. It has played one album. Works perfectly and sounds amazing. There is 2 scratches on the dust cover which can be seen in the picture. Other than that, the turntable is in as new condition with no other marks or damage.
      This is truly an audiophile top flight deck.
      PLEASE READ
    • By Toby1991
      Item Condition: Near new, unit purchased new in August 2020. Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Chelsea State: VIC Payment Method: Paypal, Cash on pickup. Reason for selling: Freeing capital. Today, we have for sale an immaculate Pro-Ject The Classic turntable in the Eucalyptus finish, with an Ortofon 2M Black installed.
       Unit is working perfectly and sounds incredible, I'm just looking to simplify my system and free up a bit of capital, rather than having the vinyl section of my system be underutilised, as the rest of my system is not at all up to this turntable's spec. Purchased new in August 2020, still under warranty. I also have a Pro-Ject Phono Box DS2 for sale, that I'd be willing to look bundle pricing with.
