Mat-with-one-t
Cable lengths for speakers - viva la difference?
Hi all.  I have a weird room that doesn't lend itself to the usual "gear between 2 speakers" layout, but rather would be much better with my gear on a sideboard to the sided the room.  Bigger is that this would take speaker cable across a door, however luckily I have made some allowances in the walls, so I should be able to run cable in conduit under the floor and bring it out through the wall.
What I'm wondering is whether a different cable length for each speaker would matter?  I have one side that would reach (a 2.5m pair is currently in use - Osborn Silverlink cables to Osborn Epitomes), but the other would need to be at least 5.5m!  I scared about the potential price of a matched 6m pair of cables!  Ouch!
Also, are there cable types (copper vs silver for example) which lend themselves to longer lengths in terms of sound quality?
Mat
I would buy unterminated cable. If you bought a terminated pair with mismatched lengths, they would be difficult to sell if you ever moved/swapped things around.  If you bought a 6m (unterminated) length for the longer side then you could always use it as a 3m pair at a later stage, and maybe a 4m length for the other side, so you could make a 2m pair.  Unterminated is usually much better value too.
Edited by seaninbrisbane
9 hours ago, davewantsmoore said:
Even large differences in length do not make any difference
Well, not quite. It really depends on the HF impedance characteristic of the speakers, the length of the cables and the resistance/inductance of the cables.
(Surely) They would need to be very high resistance or inductance.... before big differences in length (say, 3m for L and 12m for R) would make a difference.
Nope. Some ESLs (and other speakers) possess impedance dips to well below 1 Ohm at HF. 'Normal' figure 8 speaker cable possesses an inductance of around 0.75uH/M (regardless of conductor size). Low inductance speaker cables, like Goertz MI-1 exhibits a figure of around 0.012uH/M. Naim speaker cables are around 3uH/M! With the lengths you mention, HF loss with many ESLs would be quite audible. Particularly if using a faulty cable like the Naim NACA5.
Yep, so you mean when the speakers are severe loads or (and) the cable is "faulty".
Just trying to clear up for anyone playing along at home, that there's no big deal for almost everyone who has 3m speaker cable on one side, and 12m on the other.  (You know, like a time difference, or similar)
6 minutes ago, Sime said:
Does electricity travel at light speed?
For all intents, near enough. For (very high frequency) RF purposes, the differences need to be taken into account. For audio work, the difference is inconsequential. For really crappy, PVC coated, figure 8 speaker cable, the velocity is roughly 0.9 c (270,000,00 M/s). For RG213/U, the velocity factor is 0.66 (198,000,000 M/s).
Velocity factor of speaker cable is not an issue.
I believe I was very clear on that matter.
Of course there will be no time difference, but there could be a frequency response difference.
Just trying to sumarise for people playing along at home ;)
1 hour ago, Zaphod Beeblebrox said:
There could be a frequency response difference.
.... if the speakers are a nasty load, and/or the cables are high resistance or inductance.
ALL figure 8 style speaker cables are high inductance. Under most circumstances, less than 10 Metre long cables will not present a problem. SOME figure 8 speaker cables (aka: Naim) are faulty and will result in frequency response problems with much shorter lengths.
Are Naim speaker cables faulty or are they just designed to work with Naim amps?
Faulty. 3uH/M is an example of a faulty cable, which WILL attenuate high frequencies at modest cable runs, with easy speaker loads. That Naim amplifiers cannot use any other type of speaker cable, suggests faulty design on their part as well.
Subjective, but I would tend to agree with ZB.   :)
Thanks guys.  My load (feel free to chuckle) is a pair of Osborn Epitomes (90dB efficiency).  My rearrangement of the room would mean one speaker would need a run of about 2.5 metres or so, but the other about 6.5+.
Ill need to run it under the floor, so will probably put inside plastic conduit to stop rats using it as floss.
If anyone has a long run of Osborn Silverlink (so I can match) let me know!
I read in a sound production magazine (either Sound on Sound or Home and Studio Recording) years ago (before the internet) the recommendation was to have both cables the same length and roll up the excess in the short run; in your instance, you'd have to roll up 2.5 metres
Very bad advice. Rolling up a standard speaker cable will increase it's inductance. Such a problem will not occur with RG213/U however.
if you had to, would it be better to "roll up" in a figure 8 configuration?
Sent from my iPhone using Telepathy
No. The cable should be stretched out as much as possible.
    • By TuThai
      Item: Kimber Cable 8TC
      Price: $350
      Item Condition: very good condition
      Reason for selling: no more use
      - I bought the cables in a Hifi shop in Botany, 2019 (official Kimber Cables dealer)
      - 2x2.5m
    • By Eagleeyes
      Item: Analysis Plus Solo Crystal Oval 8 speaker cables (6 foot speaker cables bi-wired with spades and banana / spade adaptors )
      Price: Bargain ONLY $1800 for 6 foot ( >2 metre) pair inc postage Australia Wide and donation to SNA ----new price listed in 3 metre lengths new at  Sydney Hifi from $4240
      Item Condition: excellent-9-10 as new.
      Reason for selling:  Updating
      Spades at speaker end and banana at amps but with optional spade adaptors so you can choose your fitting.
      Awesome looking and feeling cables, flexible, and powerful. Available all over Australia and still very current cables. As new condition, serious cables.
      Payment Method: Pickup - Cash, Paypal as friend bank transfer, COD Only
      https://www.sydneyhificastlehill.com.au/shop/cables/speaker-cables/analysis-plus-solo-crystal-oval-8-speaker-cable/
      Description
      The Analysis Plus Solo Crystal Oval 8 speaker cable is handcrafted using four 11 gauge continuous cast copper conductors and is woven using Analysis plus’s proprietary hollow oval geometry with low loss dielectric to produce a very special speaker cable. Solo Crystal Oval 8 is terminated with your choice of gold T1, banana & spade connectors. If you are seeking a cable that delivers superb performance,  Solo Crystal is worth your attention.
      Analysis Plus Solo Crystal Oval 8 key features;
      Available in single run or bi-wire configuration Gold T1, banana & spade connectors available Outer Dimensions – 20mm x 10mm Price indicated is for a 3-meter pair $4,240.00 inc. GST   Please call for pricing on other lengths, available in a single for centre speakers
      Analysis Plus doesn’t just make cables for Hi-Fi and home cinema, the company also manufactures cables for musicians and their equipment, you may recognise some of the artists below that use this fantastic brand of cable;
      JOHN MAYER MARTY FRIEDMAN (OF MEGADETH) BUDDY STRONG (WITH USHER) KENNY LOGGINS JACK CASADY (HOT TUNA) CHRIS RODRIGUEZ (WITH KELLY CLARKSON) JOSHUA FINEBERG PHD (HARVARD SCHOOL OF MUSIC) RICK ROSASA (NEIL YOUNG) BYRON HOUSE (ROBERT PLANT AND THE BAND OF JOY) DANNY RADER (WITH KEITH URBAN) BILL BELL (JASON MRAZ) JIMMY HERMAN (WITH CARRIE UNDERWOOD) JACK SONNI (DIRE STRAITS) PAUL CARRACK & JEREMY MEEK Plus many more! For a full list of artists that use Analysis Plus and their testimonials click HERE To see the entire range of Analysis Plus speaker cable click HERE Additional Information
      Configuration Single Run, Bi-Wire
      Connector Banana Both Ends, Spade Both Ends, Banana one end & Spade the other
    • By Mikety
      Item: Kimber Kable 8TC 3.0m Bi-Wire bare wire
      Price: $268 + postage
      Reason for selling: too much gear
      Payment Method: Bank transfer, PayPal as friend or add 3%
      Kimber Kable 3.0m Bi-Wire bare wire Speaker cable in pair.
      IsoTek EV03 Sold
    • By Unsound
      Item: Chord Epic Reference XL 3m speaker cable pair
      Price: $1,580.00 ONO (RRP $2,750), or swap for 2m pair of similar quality, plus cash. Shipping and Paypal at buyer's expense.
      Item Condition: As new - less the 1 year old.
      Reason for selling: Rearranged room - need shorter cable.
      Original Packaging is supplied.
      Superb cables, but are too long for my current room set up.
    • By deannepal
      Item: Supra Sword 1.5m Speaker Cables
      Price: $500 (pair)
      Item Condition: Very Good
      Reason for selling: NLR
      Extra Info: 1 pair of quality Swedish made Supra Sword 1.5m speaker cables
      These are a bifolar Litz type cables that have a very open, transparent and detailed sound
      Cables are in very good condition except for minor discolouration of the outer sheath in places
      Cables are fitted with banana plugs on both ends and come with original box and paperwork
      Will post to Australia and NZ
