clunt
Found a beautiful Encel from 1974!! now to get it singing
Hey good work there....and YES of course it worked....:party:popcorn:
Was it the 1mm black rubber cord you used?
The bigger the cord size the faster the speed as I showed in my earlier speed tests.
For quick & easy speed checks, I downloaded "Turntabulator" through iTunes for $2.99 and use this on my iphone....you sit your phone on the spinning platter and in a few seconds it shows you the speed.
And finally, if your new custom made cord belt has some excess glue at the join, I found I can clip off the unwanted glue with nail clippers...they have a nice curve to them which helps too...just try not to clip your belt in half Ha ha!!!
Well done clunt...happy music
PS: I recently used this 1mm clear silicone cord on my JH turntable and it's excellent too....easily glues together with super glue!
Ebay Item No. 271953236807   Only $1.11 with Free post and 6 metres length (sorry I forgot to mention this sooner)
Any other useful mods tp the JH? The superflimsy platter and weak motor limit it a bit.
On the positive side, I've put the Grace F8 from this arm onto my SL-23 and WOW! I havent heard such clean detailed natural sound before. Granted I'm a bit of a newb to quality gear, but still. Im very impressed :)
Sent from my LG-H850 using Tapatalk
The Grace F-8 is a superb cartridge and will sound great on any turntable...certainly far superior to the standard Technics cartridge which comes with the Technics SL-23.
The Technics is a good cartridge mind you...but not in the same league as the F-8.
So your JH is playing now...and your SL-23 is singing.
It's a wonderful year for hi fi....:popcorn:
Its really nice. Thanks again for everyones help.
Don't laugh...
Dental floss works too.
Glad to hear the F8 is singing clunt! :thumb: Try it on the Grace arm......mmmm.:)
    • By Sparmac
      Hi, New to this forum, so hello to you all.
      Just bought a little turntable and can't see any I D
      other than the Encel tag at front.
      It had the usual tape residue on the lid, but cleaned up
      well with alcohol and light polish. It has a Garrard SP 25 MK iv
      table. I just cleaned it all up and works great.
      Hope someone can I D model from photos.  Thank you.
      (Sorry for poor quality photos).
