SMK88
FS: THORENS - TD309 Turntable (Red) $1995
Great condition only used a few times - RRP $2799
New standards in analogue replay.FS: THORENS - TD309 Turntable (Red)Item:
Item: Thorens TD309 Red
Price: $1995
Item Condition: Used
Reason for Selling: No room in new place
Extra Info: Used only 2 or 3 times
Fall in love with the stunning Thorens TD309. Awarded European Turntable of the Year 2010-2011, the world's most wanted turntable features sprung suspension, a separately decoupled motor, glass platter, TP92 arm and Thorens' Tri-Balance design.
The TD 309 sets new standards in analogue replay. The turntable's innovative three-point-suspension (Tri-Balance) ensures perfect balance in both mechanical and aesthetic terms. Form and function work in harmony to make the TD 309 a turntable that is guaranteed to reveal the magic of analogue replay.
TD 309 Glossy White
TD 309 Glossy Red
TD 309 Glossy Black
TD 309 Red
The TP 92 tonearm, which was specially designed for Thorens turntables, uses an ultra-low-friction bearing and an innovative magnetic anti-bias system with zero stiction. The arm tube is made from rolled aluminium that is damped using RMR (Reduced Modal Resonance) technology. The brass counterweight at the end of the arm tube is double-decoupled, and the tonearm is so designed that its centre of gravity is level with the stylus.
Features
• New innovative Tri-Balance suspended sub chassis turntable
• New suspension system to make setting up easy
• Low Noise, Low Voltage electronically speed controlled DC Motor
• Adjustable belt tension for best performance
• Aluminium sub platter with single line contact
• Fused silica platter for consistency and sound quality
• New low resonance TP 92 arm with precision Japanese bearings
• Arm adjustable for azimuth and overhang
http://www.qualifi.com.au/index.php?page=shop.product_details&flypage=vmj_genx_SR.tpl&product_id=58211&category_id=985&option=com_virtuemart&Itemid=976
Edited by SMK88
Ok so this is a nice ad but it doesn't quite fit the guidelines of the site.
FYI
@SMK88
Quote
Item:
Price:
Item Condition:
Reason for selling:
Edited by eltech
FYI
Cool sorry, I have just joined
Add has been edited
That is really stunning turntable and GLWTS.
I myself would not put the TT on the same platform as speakers - no matter how many springs there are in the suspension.
Maybe that's why it's being sold ;)
    • By Muzza71
      Item:  Tauris Georgia HiFi Stand 4 Tier Shelf Tempered Glass
      Price: $100
      Item Condition: Very Good
      Reason for selling: NLR
      Some light swirl marks and scratches but nothing to obvious.
      750mm Height 650 Depth 500mm Wide
      470mm between inside posts
      450mm deep to rear frame.
      245mm bottom shelf height
      200mm middle shelf height
      210mm top shelf height
      Shelves be can interchanged.
      The rear frame has been opened up to accommodate different terminal positions on amplifiers and source components on 2 shelves.
      The bottom shelf has 6mm rubber sandwiched between two perspex glass plates to assist with sound absorbsion/isolation.
      Bottom shelf weight limit 45kg, other shelves 25kg.
    • By Muzza71
      Item: Speaker Stands 735mm High - Tempered Glass
      Price: $50
      These can be filled with your preferred sound deadener/Absorber.
      735mm high including spikes, perfect for smallerish bookshelves around 300mm in height
      Top plate D 180mm x W 150mm x 8mm thick
      Bottom plate D 300mm x W 220mm x 8mm thick
    • By bdavis84
      Item: KRIX Phoenix Floorstanding Speakers
      Price: $600
      Item Condition: Like New
      Reason for selling: Downscaling
      Extra Info: 2 small holes in one of the speaker mesh. Otherwise great condition. Barely used over the past 7 years. Also includes quad braided speaker wire valued at $25 pm.
    • By bdavis84
      Item: KRIX Concentrix Centre Speaker
      Price: $220
      Extra Info: Great Australian made centre speaker. Barely used over the past 5 years.
    • By bdavis84
      Price: $220
