EV Cali
Ultrasonic Record Cleaning with some help from IKEA
Have been considering purchasing a Record cleaning machine for some time but found the cost of commercial machines quite prohibitive.
With the dawn of 3D printers, wands for vacuum machines have become cheaper but after much searching of the web, consensus appears to be that the best result is from Ultrasonic baths.
Ultrasonic baths can now be had for a reasonable price and again consensus appears to be that the 40kh units are ok, with the commercial cleaners using this frequency.
That led me to look at ways to suspend the records over the bath and turn them.
The “Vinyl Stack” http://www.ebay.com.au/itm/161402849405?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT is a really neat solution but the machine plus post is around $500, so my next thought was could I make something as good, cheaper.
My solution was arrived at after looking at what others had done and some trial and error.
The platform for my machine is made out of an IKEA cutting board and I used three more to complete all the other parts.
The motor for turning the records is a BBQ Rotisserie motor.
http://www.ebay.com.au/itm/171563301027?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The rod for suspending the records is an old tent pole and the brass ferule that holds them in position, originally held the spindle for a Turntable, I just drilled it right through so I could slip it on the rod.
The discs were cut with a hole saw and the foam is 6mm, self-adhesive, closed cell from Clark Rubber. All the parts are screwed together.
The Bath came through ebay.
http://www.ebay.com.au/itm/322171248214?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have now cleaned around a dozen LP’s and I am quite happy with the results.
All up the cost has been around $250
Motor $28
Bath   $185
Foam Rubber $15.50
Ikea cutting boards $12
I would probably do some things differently, if I made a second one, find a slightly thicker board for one and I am sure there will be some fine tuning over the next few weeks, plus some experimentation with cleaning solution, time and temperature  but I think it establishes that anyone with a few tools and a bit of time can make a RCM for a reasonable cost.
Edited by EV Cali
added tag
Impressive!!! You should open a biz ;)
My main hope is that this post will encourage people to make one for them selves, as all you need is a jig saw, electric drill and a hole saw.
I am happy to provide any information any one needs and can't pick up from the the pictures and write up.
It is also a presently a work in progress. The first thing I have become aware of is that the spindle needs to be lower ,so the records sit lower in the water.
When I played one of the LP's I had cleaned ,that was particularly in need of a clean, I could hear a distinct differences in the sound quality of the last centimeter or so.
To remedy this I intend to lower the unit so it sits  lower in the bath.
Will post pictures after I have done the alteration tomorrow.
Have now lowered every thing, so records sit lower in the bath, so more of the record is covered by the water and is being cleaned.
Not possible to lower any more than this in a bath this size but records are now fully covered, with out the water being too high.
If I had the skills and access to a lathe I would  like to make the spindle out of  8mm square, stainless steel  bar, so that it locates in the motor recess.It could then be turned down to 6mm round for the records, a thread added to securer the spacers with a wing nut and finally turned down to 4mm to sit on the rest.
Edited by EV Cali
Great job Robin,
I have been thinking about it, but no garage or decent workspace (pretty poor excuse). Looks great.
That was a great idea using the ikea boards like you did.
Go for it
Just wait till you have the place to your self and then use the kitchen table. If you end up with a few holes in it tell your partner it is woodworm.
I have been asked by members what I use for cleaning fluid.
For my machine , in a 6lt bath I use tap water, about 100ml  Isopropyl Alcohol and about 20ml Photo Flow.
It gives a excellence result and is cheap ,so after cleaning 30 or so LP's I just throw it out .
Some use distilled water but I do not feel the need.
I mix it up in the tank and am not too scientific about it. I have now started to  put some cold water in and then a kettle of boiling water. I have mine set at 45 degrees and with out some hot water it takes the machine about an hour to get to this temp.
My records just air dry in a washing up rack at around twenty minutes ,depending on the weather.
I have just ordered 5.750 lt of IPA off of ebay for $35 ,this should last years. The bottle in the picture is just a Lt bottle.  Only a small amount of Photo-flo is used ,so the cost per tank is insignificant.
Photoflow is used in photographic printing and it stops water marks / spots, as the photos are drying. I could not find it on line and purchased mine from a photographic shop in Brisbane.
Well done , time to enjoy the music from clean lp .
Very nice Robin.
Can you tell me the speed of the motor and how long you rotate the record in the cleaning solution. I certainly plan to build one...
Hi Malcolm
As you can probably imagine ,as it is a BBQ rotisserie motor, it turns quite slow.  Just counted about two RPM.
For the time, the consensus in the postings on the net  is Fifteen minutes. Longer is not a problem as it does not appear possible to do any damage.
So you can do about 16 in an hour. I am normally bored with it after a couple of hours so I just leave it and do some more another day.
I have even used it on brand new records, that had some hiss and it has removed this . I assume there must have been some of the release agent from the press left on it.
It would be good to see your finished machine and any improvements you come up with.
Edited by EV Cali
21 minutes ago, coylum said:
Very nice Robin.
Look forward to another update. I'll eventually get around to trying something.
This is brilliant!  Does the ultrasonic cleaning work?  I'm using a KAB EV1 and Disc Doctor fluid... this seems like a much better idea.
Most of the second hand records I have, have  been cleaned by wiping them with a cloth and some fluid when I first got them and I assumed them to be reasonably clean.
After cleaning around 30 LP's with the Ultrasonic bath  I was amazed at the amount of dirt sitting in the bottom of the bath.
I have never used a vacuum cleaner but consensus across the net,  from people that have them,  is that Ultrasonic is better.
My own thoughts are that the USB does not have any contact with the records and rubbing them with a cleaning pad and then vacuuming them ,just like wiping them with a cloth, must do some damage and get less dirt out.
Plus making up your own fluid is really cheap
Edited by EV Cali
@Ian McP
Hi Ian
Yes I am an IKEA fan.
My records and cd's are all in IKEA units.
I had not seen site you linked to but it was mentioned on this site that I posted a picture of my machine on.
http://thevinylfactory.com/vinyl-factory-releases/ikea-hacks-for-vinyl-lovers/
I especially liked the double bed. If only I could convince my Wife.
Edited by EV Cali
@EV Cali Good job man! Nice and easy does it!
I don't get the bit about the wooden boards though?
Alberto
Oh... wait, disregard that. It's "plastic" cutting boards. Now I see it :thumb:
Been contemplating a RCM for some time, Only just spotted your steampunk model.
Great post, I'm getting a bath, let's see what I come up with.
I like to think of it more as IKEA Modern.
I am very interested to see how yours turns out .
Edited by EV Cali
Inspired by this post im going to have a crack at building one as well. Hoping to incorporate an auto lift feature to raise/lover the records into the bath with will allow them to dry without having to mess around will a separate drying station.
This is what im planning on using for the lift mechanism and the 1 RPM motor (slowest I could find)
@Tubularbells
That is great.
I can't wait to see what you come up with. one of the reasons I posted lots of pictures but not a step by step guide, is to inspire others to come up with some thing different or better that we can all learn from.
Although just copying mine is not a problem either . I am happy to provide information on my build and answer any questions from any one who wants to ask.
Mine is based on a number of others I saw on the net with a bit of inspiration on top.
The rotisserie motor that I have used turns at  about 2 rpm.
6 minutes ago, Upfront said:
Look at this on eBay http://www.ebay.com.au/itm/322304502258
This way your only playing with 12vdc rather than 230/240v
The bath is 240 anyway, I like the BBQ motor for its square drive as I'm planning to do quick release multiple spindles, the engineers have not approved the blueprint yet but all looks good in my head.
contemplating the analog dials on the bath out of respect to the records
@EV Cali
Motor $28
Bath   $185
Foam Rubber $15.50
You can tell a lot by a man's or woman's shed, I was admiring your beat the drum matches when I spied a little J90 bullnose plane and then a fairly expensive record No 4, if I'm not mistaken, not normally found in your home handymans kit.
I'm not a stalker or a CSI agent, just been building timber joinery ++++ for 35
years
my workshop now has a small steel fab section, thinking to do my bath lid / motor mount out of stainless
Thanks @Upfront have just ordered one of those motors as well as that way I can control the motor and actuator for the lift mech of one battery. Also grabbed a couple of speed controls as well.
This one to slow the record rotational speed even further (not sure if required)
http://www.ebay.com.au/itm/322224371896?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
And this is a neat solution for the lifting mech at it ha a switch for up/down along with a dial to control the speed (which I thought might be handy when lowering the disks into the fluid as it gives some fine tuning so that you can stop just below the label ensuring full cleaning coverage)
http://www.ebay.com.au/itm/322321358004
    • By ThroneofGame
      Item: Original Vintage Knosti Disco-Antistat Record Washing Device
      Price: $70
      Item Condition:  Like new - hardly used - except for the box - it was made about 20 years ago!
      Reason for selling:  I have a VPI record cleaning machine
      Extra Info:  This is the German-made - pre-unification (says Made in W. Germany) - original version of probably the most economical record cleaning device on the market!
      Cleans 7", 10" and 12" Records  All fluids etc are supplied in the box. Manual Record Cleaner. This is a very cost effective wet cleaning system for LP’s. Supplied with Full instructions and 1.0 Litres of Cleaning Fluid Easy To Use Excellent Value Extra Cleaning Fluid Easily obtainable
      Submerges a record in a bath of cleaning fluid.
      The principle is simple, two discs with a 100mm diameter, clamp each side of the record's label, thus protecting it during cleaning, this then rests in a groove at the top of the rectangular cleaning bath, the bath is topped up with supplied cleaning fluid, the record is then rotated around its central axis. As the record passes through the bath, two sets of brushes clean each side of the album. Once you’re happy with the results simply remove the record and centre clamps, and place your clean album on the rack to dry. Because the cleaning solution contains wetting agent, records dry without smears. When cleaning is complete, pour your used cleaning fluid from the bath through a filtering funnel back into you cleaning fluid bottle for re-use.
      Read Marc Rushton's reveiw here:  https://www.stereo.net.au/reviews/review-knosti-disco-antistat-record-cleaner
    • By mrf0ster
      tem: Pro-Ject Spin-Clean Record Washer System
      Price: Price Reduction, 50 bucks. Any one?
      Item Condition: Excellent
      Reason for selling: NLR
      Payment Method: Pickup - Cash, COD Only
      I have used this on all my old and new records and I am quite happy with its result. I have always used distilled water for cleaning and the brushes are in as new soft and unworn condition. There is not much cleaning liquid left (Around 10% or less) and the two provided drying cloths are no longer available. These items can be bought separately on line. I would not worry too much about the drying cloths as any soft cotton or soft microfiber cloth would do the job.
      The full kit, which includes a full bottle of washer and two drying cloths, is available on line for $135.  Pick up only at this stage but if you want it delivered, I would estimate the postage cost to be around $20 to $40 due to its size?
    • By mrf0ster
      Item: Pro-Ject Spin-Clean Record Washer System
      Price: 80.00
    • By Maggie
      Item: Ultrasonic Record Cleaner
      Price: $300  - Ultrasonic Cleaner kit /  $ 165 - Ultrasonic Cleanr 6L tub
      Item Condition: New
      Reason for selling: Need Cash
      Payment Method: EFT, Pickup - Cash, Paypal +3%, COD Only
      Local pick-up or interstate shipment is possible for extra postage fee.
      Please PM me for more details.
      1.Ultrasonic Record Cleaner rotatory kit
      Specs
      Single low speed mode for motor, powered by 2-pin powercord 6 acrylic spacers
      2.Ultrasonic Record Cleaner 6L
      Easily sourced from Ebay for the same price
      http://www.stereo.net.au/forums/topic/118628-fs-ultrasonic-record-cleaner-kit/
    • Guest
      By Guest
      I'm floating an idea here for like minding vinyl lovers. Not sure if its workable or not but here goes …….
      I had a set of records cleaned by the Audio Desk Systeme Vinyl Cleaner and the results were amazing. Better than any of my various routines before including vacuum machines.
      http://www.stereophile.com/content/audio-desk-systeme-vinyl-cleaner
      Now one of these machines would set you back 4K. I personally don’t have that kind of money. But, I am just wondering, would there be people out there that would possibly consider going 1/2 1/3 or 1/4? Again not sure how to work out the details of how this would work, but hey I'm putting the idea out there.
      Maybe someone else had done a share arrangement on other equipment and could share there experiences? Any thoughts, pitfalls advice appreciated!
      Cheers, Mark
