JSC
Electrostatic speaker repairers
I have own a number of Martin Logan ESL products which I have found reasonably reliable. My current Martin Logan Summit ESL speakers work wonderfully provided that a certain mid range frequency is not present within the music. I have identified that in the top left hand corner of one of the ESL panels the Mylar is slightly warped. This is what is causing the problem as the other ESL panel has no issues. Replacement panels come in pairs and cost north of $2,500. I feel that if the Mylar in the corner of the ESL panel was re-stretched that the panel would work perfectly across all frequencies above the cross over frequency. Do you think I should just replace the panels or is there someone you know that can fix ESL panels in Australia? Any thoughts on the matter would be appreciated. I am required to wait until Christmas before new ESL panels will arrive if ordered immediately. I am based in Brisbane. Thanks in advance. JSC
I can vouch for Rob (ER Audio) as a fantastic help with this stuff.
Thanks, appreciate your recommendations. I spoke with Rob 9 months ago about purchasing a repair kit from him but it requires diy knowledge and tools that I don't have (i.e. a jig). I may contact him again though to get some further advice. I had heard from another stereonet member in QLD a couple of months ago that there is an individual based on the Sunshine Coast who can fix ESL panels but he didn't have any further details, which led to a dead end.
Restretching already warped or stretched mylar is a bad idea because you will be changing the frequency response though slightly of that panel as the mylar tension are very specific. A quick fix using a heat gun to expand the warped out area.
Justin.
You might try Graz at Apogee:-
http://www.apogeeacoustics.com/company.html
He is not far from you on the Sunshine Coast and I can attest he is good at the ESL stuff.
He 'repaired' a supertweeter for a friend and actually made it sound twice as good!
All the best.
Steven.
Thanks Steven. I appreciate you providing me with the above information. I will definitely check out the website and contact Graz.
The Martin Logans have a known issue of mylar sag with time on the larger panels. Have you considered using the hair dryer method to re-tension the mylar?
Suspect you already have been given enough options
You could ring Mc Leans Audio at Gosford where the tech works with Mylar constantly repairing Magnapan panels
Try the hair dryer method, although I wonder if your diaphragm has torn ??
Thanks. I'll read up on the hair dryer method. The diaphragm is definitely intact. The speaker works completely fine as long as a certain frequency/frequency range is not hit. Most music I listen to comes through nicely. Thanks for all the suggestions. I probably have enough to work with now.
I've come across the following information.
There are a couple of possibilities that may be occurring. One would be that the panel is simply resonating because it has perhaps lost a bit of tension. The other possibility is that the clear 'damping strips' have come loose from the backside of the panel. There is a difference in performance between the two.
A resonating panel will only buzz on certain notes and at somewhat higher volumes.
A loose damping strip will buzz at almost any frequency and at any volume.
From your description, I believe that you are hearing a resonance. We fondly refer to the phenomena as "Kazooing" because it sounds like a kazoo. This can usually be improved by heat treatment. All CLS panels are heat treated initially before they leave the factory. Some times with age, they will stretch themselves slightly loose. They need heat to re-tension them. There is a very specific technique to heat treatment. If you wish to try it, Here are the instructions.
CAUTION!!!!
There certainly is the risk of damaging the panels by melting a hole through the membrane. Bad thing. If you are careful however, I think you will do just fine.
The heat can be applied with a strong hair dryer. A heat gun may be too extreme. I recommend starting with the heat source about 12 inches away from the speaker. Complete the entire procedure and if it has no affect, move the heat source about 2 inches closer and repeat the entire process. Patience is required.
The heat must be applied ONLY to the side portions of the panel, never in the center zone indicated by the horizontal spars or ribs. The side sections are the 'bass' sections that are about 6 inches or so wide and run from top to bottom on each side of the panel.
The heat must be applied from a constantly moving heat source but at a very slow steady rate of movement. Specifically, start applying heat from the dryer at the top of the panel along the edge of the wood frame moving toward the bottom. Keep the heat source moving at the rate of 1 foot per 3 seconds. Next start at the top again but this time, move inboard just slightly, about 2 inches and make another slow downward pass. Repeat until you are near the vertical spar defining the beginning of the center section.
If you first treated the left bass zone, now do the right bass zone.
If you have a good light source on the membrane, you may be able to determine if it is receiving enough heat to have a good effect. You should be able to see a slight shimmer of the membrane directly under the heat if light is so that you can see the reflection of the light. As you move the heat past, the area that was shimmering will draw tight. I hope this helps.
The hair dryer treatment appears to have worked. I can't be 100% certain just yet but I am playing a variety of music loud with no issues.
excellent, you may want to do all the panels every year.
as you are in Bris, you could try Garry jacobsen who runs a quad esl webpage. Otherwise there is guy in Sydney- Christian Felaiffe who is excellent, mainly a quad man too.
by the way were you able to track down Graz?
Thanks for the information. I ended up purchasing new ESL panels from ML last year. The speakers sound like new now. Good to know for the future though. Thanks again.
Plus one for the hairdryer method.... I know it might only be a temp fix. But it worked whilst I source some new panels.
Rob from ER Audio has been very helpful. He has some excellent instructions and supplies the parts to fix panels. He has been very prompt via email as well.
jsc, where did you order the panels from? I am in Brisbane.
thanks all for sharing your knowledge!
    • By NoCoder
      Hi All,
      Revisiting the vinyl scene after many years away and have started out with a Pioneer LP30 turntable and I already had a Yamaha HTR-6130 receiver. Down the track  I would like to upgrade eveything, but my budget will not allow that for a fair while.
      I would like to add better speakers than the ones that came with the receiver and was looking at a few bookshelf speaker options. I have seen a few Edifier model and also a Pioneer SP-BS22-LR Bookshelf Speaker. I only have up to $300 to spend.
      I know nothing will blow me away with my current set up and budget, but it's a start to listen to what I have.
      Does anyone have any suggestions?
    • By Tobiwan
      Item Condition: Very Good Used Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Taylors lakes State: Victoria Payment Method: paypal, EFT, cash on pick up Reason for selling: upgraded Further information:
      I am selling my old Chrono series floor standers and center ~ 6 years old very well looked after.
      I think it's a bargain of a price
      Pair of Canton Chrono 509.2 DC floor stand speakers
      Canton Chrono 505CM Centre Channel Speaker
    • By viper87
      Item Condition: Used - all drivers work perfectly but there is cosmetic damage. Shipping Options: Pickup is available Suburb or Town: Camden State: New South Wales Payment Method: Cash Reason for selling: They've been collecting dust for too long. Hi,
      I've had these beauties tested and all drivers are functioning perfectly, they sound incredible.
      Matching serial numbers as indicated in the photos and they also come with a stand for each speaker. There is some cosmetic damage so please refer to the photos.
      Local pick up in Sydney region. I don't have an amp, i had them tested at a hifi store so you'll need to byo if you want to test, my appologies.
      They were left to me from a family member who has passed away, I know theres someone out there who will appreciate them.
      Edit: I'm no longer accepting PayPal I'm only accepting cash, my apologies to anyone wishing to use this service but there are too many scammers. Still happy to prove they're fully functional to those who are serious about the purchase.
      Edit 2: I'd also like to mention that I've included the speaker stands in the purchase price to offset the cosmetic damage. I know their valuable and I believe that's a fair trade.
    • By Rori
      Item Condition: 8.5/10 Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact,I can ship this item Suburb or Town: Emerald State: Victoria Payment Method: Cash, EFT, Paypal Reason for selling: NLR Further information:
      2 years old, purchased from Big Picture People Narre Warren.
      Plenty of reviews online about this subwoofer. It has 2 x 12" drivers opposing each other to cancel out vibrations. The outcome is clear, low distortion and clean bass.
      The customization for best in room response from the amp is second to none with low pass filtering, phase alignment, gain and when measuring with the PBK kit (supplied) can give close to perfectly flat frequency response.
      This sub looks amazing especially in piano gloss black. Can ship however it does weigh 65kg's... I have all boxes and accessories for it.
      See specs and pics below.
      Specs:
      BalancedForce 212
      System Frequency Response 18–120 Hz ±3dB; Anechoic through LFE effects input 20–120 Hz ±3dB;
      Low Pass Filter Frequencies 30 - 80Hz
      Phase 0°, 90°, 180°, 270° 0°
      25Hz Level Control ±10dB at 25Hz ±10dB at 25Hz
      Power Control On, Auto (12V Trigger), Off On, Auto (12V Trigger), Off
      Room Correction Perfect Bass Kit (PBK) Ready (Sold Separately)
      Woofers Two 12" (30.5cm) cast-basket, highexcursion, aluminum cone with extended throw driver assembly, sealed non-resonant asymmetrical chamber format
      Amplifiers 2 x 850 watts
      (3,400 watts peak system total) 850 watts
      (1,700 watts peak)
      Inputs RCA: Left, Right and LFE.
      XLR: Left, Right and LFE.
      Speaker Level: Left and Right banana jacks.
      12V Trigger: 3.5mm
      Mini USB (for PBK)
      USB (for crossover & firmware updates) RCA: Left, Right and LFE.
      12V Trigger: 3.5mm
      Mini USB (for PBK)
      Output (RCA) Multi Out (for multi-sub connection) Multi Out (for multi-sub connection)
      Input Impedance RCA: 10,000 Ohms
      XLR: 15,000 Ohms per phase
      Speaker Level: 10,000 Ohms per phase (20,000 Ohms red to black)
      Power Draw Typical: 250 Watts
      Idle: 30 Watts Typical: 125 Watts
      Idle: 15 Watts
      Weight 140lbs. (63.5kg) each 96lbs. (43.5kg) each
      Overall Dimensions
      HxWxD  ( 57.4cm x 57.4cm x 58.2cm)
    • By ViVa
      Having tried a couple of couriers in the past with limited success. I need another pair of speakers (total 70kgs) moved from Melbourne to Sydney.
      Recent quotes from e-go (cheapest $), Pack & Send ($$$), Smart Send ($$$),  Interparcel (via TNT - road were affordable) - any other recommendations?
      So far, only PackSend and Smart Send offer Insurance of amounts over 2k.
