Mat-with-one-t
Thoughts on interconnects for turntables > phono stage > preamp
Hi again everyone, and hope you're enjoying the day! On my current setup journey, I've now got my turntable going in my new system, and it's already sounding great! It certainly needs some tweaking, and I reckon I could improve things greatly with a few small changes (not to mention getting some record cleaner! Suggestions welcome on that topic!).
So, I have:
Pro-ject 6.1 turntable with Ortofon MC10 cart > Creek Audio OBH-9SE phono stage > Wyred4Sound STP-SE pre
I was wondering about experiences with cabling for starters? I had a look here, but I'm interested in silver vs copper, long vs short, RCA vs XLR - that sort of thing.
http://www.stereo.net.au/forums/index.php/topic/58011-great-cheap-phono-interconects-have-to-let-you-guys-know/?hl=interconnects
I will likely soon get some of these (silver interconnects) to go dac>pre and cd>pre
http://stagersound.com/silver/order.htm
So perhaps I should get some for the phono too? I have also started a thread about the "balanced" nature of phono signals. In my setup, I could:
1. Go RCA phono >phono stage> pre
2. RCA phono>phono stage> then RCA to XLR pre
3. Have the tone arm reward and go fully balanced (but would need a new phono stage....
Lastly, as can be seen in pics, I have cheapo cabling with "inbuilt" ground wire. Once a setup is decided upon, what's the best way to do a new ground?
Awesome!
Mat
post-155585-0-93418800-1467507516_thumb.
post-155585-0-50942000-1467507551_thumb.
Guest Muon
Just make sure the table to phono stage ones are shielded, and quality as the lower the signal level the more quality will show through IMO.
Shielded yes. But what defines "quality" in this instance? I assume we need very low impedance given the nature of the signal? So does this mean silver? Also, I can manage very short lengths with the current little phono stage, so should I get super short?
The Aurealis phono cable is a nice bit of kit:
http://www.aurealisaudio.com.au/phono-cables-shielded/
The new entry-level Aurealis 'The Source' cable is shielded and would also do the trick. The use the nice 'Star' RCAs which are the bang-for-buck champs IMHO:
http://www.aurealisaudio.com.au/aurealis-the-source-interconnect-shielded/
If you went for the latter cable, you could use whatever tickles your fancy for the ground wire (eg. a short length of wire with bare twisted ends, or with crimped spade connections on each end).
Guest Muon
Low capacitance is wanted in a phono IC, quality refers to every part of the cable and connectors, the conductors, dielectric and construction, connectors too.
The Aurealis phono cables above are a safe bet, and one I went with.
Edit: Short is good as it means even lower capacitance.
Edited by Muon
I have just recently been trying the Aurealis R3 cables from SUT to phono stage in comparison to the Van Damm  silver plated OFC.
The R3 solid silver cable is very good but the silver litz is a step above.  These both were using the KLEI absolute harmony.
It had wider and deeper sound stage and tighter control of lows and highs.
Unless you are willing to buy on spec or others suggestion you will never know until you have it in your system and spend some time with it.
Once I decide on a SUT I will be implementing the R3 silver litz!  Perhaps hard wired one end into the SUT to avoid one set of plugs and sockets.
P.S. Regards length.  Future proof yourself as if you go short then decide on a SUT or head amp etc you will be limited on positioning them away from sources of interference e.g. transformers, turn table motors etc.
Thanks mates! Some nice food for thought here. Yeah - if only I could manage to buy lots of sets, audition, then move on the losers, but a bit of an expensive undertaking!
I agree on the length - I'm yet to build my final (!) cabinet, and let's face it, stuff moves and changes.....
Why not compare against a LOMC phono stage which will:
  • take the phono cable directly
  • thus doing away with a. a SUT and b. a set of cables?
@@andyr because my MC is only 100 uV output and I only built my valve phono amp at Christmas and don't want to move on.  The MC on my amp does not have enough gain so I use the SUT at 36x and the MM stage.  Is better than the SUT and Graham Slee reflex M and straight into the Graham Slee era gold.
But I understand what you are saying.
Aah, yes - 0.1mV LOMCs are a problem!  ;)
This becomes crucial if you want to run a very low output MC cartridge.
How low is "very low"? It looks like mine is 0.25mV....
I'd say something less than 0.2mV. But 0.25 sounds pretty low too.
How much are they? What did you compare them to?
Compared them to nothing (I'm not made of money!! :P), I just have used them myself (obtained on Ebay cheaper than RRP) and they're great, and know from reviews that they compare well in price to other high end brands......and they're German, a pretty good place to start. :)
Edited by stevoz
Guest Muon
@@Mat-with-one-t
Mat, looking at the pics in ya' original post, could I suggest that you try and keep signal cables well away from power cables :cool:
@@Mat-with-one-t
Nice pickup. Yeah I just moved everything and hadn't got to organising the mess yet! My eventual plan will be to have all power stuff well away, and perhaps add a reconditioner down the track.
I'm using the MIT5 interconnect RCA cables and from my turntable > Pre Phono > Preamp
As Muon mentioned, power away from RCA/Signal cables, I was trying hard to keep my cables organised also. Only just plugged everything back up on Sunday. It was a long day...
    • By 81Vintage
      Item: Custom Rega Style Turntable, AudioMods Tonearm, IsoDrive PSU
      Price: $3300 including shipping Australia wide - Price Drop $3100
      Item Condition: Excellent, but used
      Reason for selling: New Project/Custom Build
      This is a complete custom build from the ground up based on a Rega P series design. Raw cost of materials and items was over $6000.
      Plynth milled from single block of billet alloy on CNC router (around 15kg) Finished in red automotive paint Followed same dimmensions as a Rega P3 plynth. 5x Maglev feet (tried with 3, 4 and 5 configurations and 5 was the best) IsoKinetic IsoDrive Power Supply with 33/45 speed selection IsoKinetic 25mm Acrylic Platter IsoKinetic IsoSub Groovetracer Machined Subplatter IsoKinetic Phosphor Bronze Bearing Sleeve IsoKinetic Ruby Bearing + Spindle Oil (lifetime supply left in bottle) IsoKinetic Puck/Stabiliser IsoKinetic Red Thing Silicone Belt + Spare New One in Packet IsoKinetic MTB-D Motor Thrust Bearing + Motor Isolation Mod for Premotec Motor Premotec 50hz Synchronous Motor Audiomods Series 4 Tonearm with Series 5 bearing, lift and arm hold. Full VTA Adjustment - no VTA adjuster.  All original weights and headshell weights/spacers included to adjust to any cart. Custom Acrylic Dust Cover to accomodate arm height No cart included, but I did have an Ortofon MC25e on it and it was stunning.
      *I have covered the hole bottom left corner where a power button would have gone if I didnt use the motor PSU with a samurai silver coin from WA mint. So the turntable is dubbed The Samurai.
      For interstate buyers, it will be professionally crated and foam lined for shipping with tonearm back in original transport box. Shipping Australia wide with insurance included.
      For those that want to know where to from here - my next build will be in the similar vein...but using the MK6 Audiomods tonearm for primary, 200mm monster delrin platter,  ceramic bearing sleeve, larger billet plynth with 2 armboards for future arm addition and external motor and controller.
    • By jonnyadelaide
      Item: Pioneer plx-1000 turntable
      Price: $485
      Item Condition:9/10
      Reason for selling:Upgrading
       Great sounding turntable in very good condition. Lid has very light scratches but body is flawless. No play whatsoever in tonearm bearings.
      Cartridge not included but has upgraded Ortofon headshell.
      Happy to demo.
      Local buyers only please.
    • By krakatana
      Item: RJM Audio VSPS Moving Magnet DIY Phono Stage
      Price: $180 + $25 postage
      Item Condition: Working perfectly, some scratches on cases
      Reason for selling: Now using MC
      Extra Info: Excellent sounding phono, used for six months, built about two years ago. The cases are thin Aluminium, but have brass or Titanium plates at connector points.
      Materials used: RJM VSPS and Dual-Bridge Rectifier kits, Dueland wiring for signal paths, Arizona Blue Cactus 2.2uF 200VDC output capacitors (with bypass caps), Altronics transformer, Furutech Rhodium FI-03 IEC inlet with fuse, 2 x Aluminium cases, Stillpoint ERS tape around power cable (light blue) in phono case, Gold coated pure Copper RCA plugs, 2 cm slate pieces under circuit boards and transformer, brass (front) and Titanium plates (rear). Well over $200 of materials used.
      http://phonoclone.com/diy-pho5.html
      http://phonoclone.com/pcb.html
      http://phonoclone.com/diy-guide.html
      ELECTRICAL DISCLAIMER
      This product has not been manufactured by a qualified individual or company, therefore contains electrical circuits that do not necessarily comply with Australian Standards. I understand that as the seller, I may be liable to repercussions in the event of equipment failure. By advertising and selling this product, as the seller I also agree that I am solely liable, and the publisher of this website takes no responsibility for any injury or death resulting from, whether directly or indirectly, any accident that may happen as a result of the failure of the product being sold. If in doubt, seek the services of a qualified electrician to inspect the product to ensure it is safe for use.
    • By baker1234
      Item: PRO-JECT DEBUT CARBON DC IN YELLOW
      Price: 400 ONO
      Item Condition: NEAR NEW
      Reason for selling: NO LONGER REQUIRED
      Extra Info: IMMACULATE CONDITION WITH ORIGINAL PACKAGING WITH INSTRUCTION MANUAL ETC.
