Gee Emm
Tivoli Model one radio hum, driving me nuts
G'day all
I have a Tivoli Audio Model One B1 radio, that is ~18months old.
It has developed a most-annoying-hum.
It is so annoying, i cant stand to listen to the radio.
I have been to the Tivoli website, with no info there about the problem existing.
So, has anyone else had this problem and know how to fix it, or is it another situation where it costs more to have a service agent repair than replace. :(
If you know, should I contact Tivoli direct, or via the retailer?
Things should last MUCH MUCH longer than this. :(
No warranty?
Assuming that you purchased this new? If so, warranty or not, you are correct that it should last longer than this. Australian Consumer laws protect you in this very situation. Take it back to where you bought it from and ask for it to be repaired or replaced.
No warranty?
12 months from purchase
@@Telecine , I'll get in touch with the retailer
Does the acl provide a compulsory 2 yr warranty tho?
My mistake, I think it is actually 2 1/2 years old.
Time flies when you're having fun in the sun!
So, I now may need to know how to fix the hummy little bugger!
No idea as to what may have caused it?
My guess is a design flaw or the failure of a cheap component
Edited by Gee Emm
Hi G
As far as simple radios go these might be considered a premium product and  don't think it's unreasonable to expect them to last a lot longer than this one has.  I have a couple that are working perfectly after about 10 years of use and I wouldn't have expected otherwise.
So, I think you should see if the retailer will take care of it under Australian consumer legislation, the weakness of which is of course that it doesn't specify how long a product or class of products is expected to last.  So, it's all a matter of what people consider a reasonable expected lifespan until it's tested in court, which is unlikely to happen with cheap consumer goods.
But, I think I could keep a straight face while asserting that this is a premature failure.
A premium radio that promotes quality as an attribute would reasonable be expected to last for five years or more.
"You can claim a remedy from the retailer if the products do not meet any one or more of the consumer guarantees, with the exception of availability of spare parts and repair facilities.
The remedies you can seek from the retailer who sold you the product include a repair, replacement, or refund and in some cases compensation for damages and loss.
The retailer can’t refuse to help you by sending you to the manufacturer or importer."
https://www.accc.gov.au/consumers/consumer-rights-guarantees/consumer-guarantees
    • By Primare Knob
      Not sure if this is the right place to post this.
      I have two identical amps that are humming, which can be (faintly) heard at the speakers as well.
      My setup is PC, into USB DAC, out via Shielded Balanced Cables, into (4x) Power Amps.
      All equipment is fed from a single 2GPO power point using 2 extensions boards.
      I have done the following testing:
      Only Amp turned on, no input cables; humming amp and speakers
      Only Amp turned on using 2 lead cable, no input cables; humming amp and speakers
      Only Amp turned on using different power point, no input cables; humming amp and speakers
      Only Amp turned on, with input cables connected (to switched off DAC); humming amp and speakers
      Wholes system turned on, with input cables connected; humming amp and speakers
      Only Amp turned on, with cables connected, but disconnected from DAC and freely hanging in space; humming on amp and speakers intensify and changes in rhythm and tonality by introducing some buzzing.
      Different Amp, with input cables connected; no humming amp or speaker
      Both identical amp produce the same problems, and my other 2 amp are fine .
      Can someone help me understand what is going on? Is there some kind of ground loop, DC offset, or are my amps starting to fail?
      Edit: Different setup in the house with a tube amplifier, same kind of problem. Buzzing can be heard on the speaker, but not on the amp.
    • By Max Headroom
      "Audio Music's R-T1 TVC valve preamp belongs in the top echelon of performance as do its assembly and finish quality."
      Item: AM Audio Music RT-2 Silver preamp
      Price: $4400 (RRP is $7,650 saving over $3000)
      Item Condition: 8/10
      Reason for selling: Upgrade/change of direction
      Extra Info: Well I never thought that I would come to this point, but as we all know, this hobby is a cruel mistress...
      Yes I am selling my wonderful AM RT-2 preamp. For those of you who have been fortunate enough to hear/use AM amps in their system, you'll know what this amp is all about. It's one step down from the 3 box RT-3 flagship, but if you've had the pleasure of hearing it you'll know its quite stunning in it's ability to bring music into your room if the rest of your system is up to it.
      The build is amazing. Inside and out, its a work of art. The one thing you'll notice straight away is this amp is not one that will look old or dated in a few years. It also feels like a truck could drive over it and wouldn't even scratch it - the workmanship and quality is absolutely amazing.
      The power supply is huge, making some power amps look puny. Internally it's wired up with silver wire, which is a step up from its brother the RT-1 which uses copper wiring. And no before you ask I don't hear any shrillness, brightness or dryness. Just a detailed, smooth, dynamic and open sound.
      And the sound emerges from a black background... I don't know, I could start spouting superlatives...
      I’ve compared it with well respected preamps around the same price, but what you notice with this AM preamp is that it is sooooo quiet. You don't realise that amps are noisy till you (don't) hear a really great amp. Then the sound just appears in front of you unhindered without any noise or grain... and the dynamics are tremendous. They're unforced, just amazing. Hard to explain till you really hear it. It's a huge step up from anything I had used previously.
      Another huge benefit is that I can play my music at low volume and it fills the room, it doesn’t shrink away. So late night listening is totally doable and you’ll still feel/hear the energy in the music - not many preamps will give you this consistency throughout the volume range, most just shrink the soundstage and dynamics as you turn the volume down.
      This preamp can mix it with some very lofty company - Audio Note M8, Esoteric C-03, Nagra Jazz...
      But I'll stop waxing lyrical about this preamp, and refer you to these reviews... (and yes, donation to SNA upon successful sale of this beautiful pre-amp)
      Oh and before I go, I recently purchased a pair of Sovtek 6H30Pi EB Cryo Matched Pair tubes. I've put only a couple of hours on them, but honestly couldn't hear a difference, so would suggest the original valves still have plenty of life in them. Will throw them in to sweeten the deal.
      And for interstate shoppers - yes I have the original boxes so will arrive safely, but may cost a bit to ship as this 2 box preamp literally will come in 2 boxes, and its damn heavy.
      Hifi Wigwam
      https://www.hifiwigwam.com/audio-music-805s-monoblocks-and-rt-2-preamplifier/
      "The build quality of the AM 805Ss and the RT-2 is right up there among the best... With the lids of the RT-2 and its companion power supply removed, and the base plates of the monoblocks set aside it’s evident that the quality is more than simply skin deep. In addition to the own-build transformers Audio Music has copper foil capacitors of its own design manufactured in its own factory in Mexico. Am Fang and his colleagues liked what Jensen, Audio Note and a few others were producing, but didn’t like the prices, so decided to set up in competition. Audio Music U-Caps are the result...
      Internally, the RT-2 especially is a work of art. It is properly dual mono from power chord onwards... Signal path capacitors are AM’s own U-Caps. The point to point wiring, all silver, is neatly executed. In all, it’s a joy to behold..
      From that very personal perspective though, I think the RT-2 is a veritable blinder, able to mix it with some very illustrious and expensive company indeed. I tell you, it pushed my own Audio Note M8 hard into a corner. Nose to nose it asked: “You really worth that much, big boy?” Of course, and ultimately given the law of diminishing returns, the question is not so much one of £££s worth, but of sonic satisfaction. In others words eight point five tenths versus ten tenths – but for a lot, lot less money, if you want to characterise it that way.
      The RT-2 is genuinely that good sonically, in my view."
      6moons (reviewing the copper based RT-1 which is one step down in the range:
      http://www.6moons.com/audioreviews/audiomusic/1.html
      "In my 11 years at this helm, I've never before come across a component this deserving of being called built like a tank. Think Burson squared. The canned TVCs are braced in massively machined aluminum retainers. So are the output and power transformers. The vertical tube board mounts its super-tight sockets to a massive aluminum plate whose back side doubles as mount for the associated circuit board. The grooved heavy-duty top cover locks into rabbeted place with eight long bolts passing with perfect fit through the overkill corner blocks...
      Whilst one might rightly question whether this type of build is necessary—I don't think that Jeff Rowland shoppers would though—there's no question that Audio Music's designer is an extremist when it comes to mechanical construction...
      The first sonic surprise was just how loud the R-T1 sounded at micro volumes. We're all familiar with hifi's mandate that escalating volumes ought to only go louder, not change with band-specific compression, stridency, brightness, hardness or other nonlinearities. Hardly anyone talks about the inverse. Things shouldn't collapse, shrink or disappear as volumes fade. It's probably a fortuitous combo of current drive, overall system resolution and speaker responsiveness that delays the inevitable sonic shrinkage which accompanies counter clockwise on the dial. Old-fashioned loudness controls were meant to compensate for HF/LF loss at pianissimo levels but none of today's high-end gear has them. Here the R-T1 set a new high in low. It maintained truly phenomenal intelligibility and substance all the way down into the very ambient noise floor of the room itself...
      If you think on it, there's something very wrong with being held hostage by systems which only satisfy when played loud. Sometimes loud isn't appropriate or possible. Sometimes you're not in the mood for it. Should you settle for a lesser experience then or, worse, opt to not listen at all? If you relate, the Audio Music preamp up-ends such silliness (obviously your particular amp/speaker interface must be capable of transferring massive signal cut into proper fullness and detail - and many speakers just aren't). Very likely Fang's magnetic volume controls had something to do with this due to how effective their lot get as one turns them down. The upshot is that contrary to popular lore where tube circuits are inherently noisier than transistor equivalents to come second on resolving power, on low-down intelligibility with body the R-T1 thoroughly whupped ass on my Esoteric C-03 preamp and even outweighed my Nagra Jazz in the bass...
      Conclusion. The R-T1 should be of particular interest to people of either hi-eff systems where deep attenuation is the order of the day; or those who routinely listen quietly but presently belabour a significant loss of substance whenever they do. Here the transformer-based volume controls excel at maximizing drive at very low signal voltages. It really was just a matter of time. Reference Chi-Fi has arrived. Audio Music's R-T1 TVC valve preamp belongs in the top echelon of performance as do its assembly and finish quality. It might take a few more years for this new reality to sink in. The few adventurous souls open-minded enough to already give this machine an audition should simply agree that this future is here now!..."
    • By Soul Superfly
      Item: Yamaha TD500
      Price Range: $250
      Item Condition: New or Used
      Extra Info: Unable to get DAB where I am so looking for an AM FM Tuner only
    • By Soul Superfly
      Item:Yamaha or Pioneer AM/ FM Tuner
      Price Range:
      Please let me know what you have for sale. Thanks, Nick
    • By Eagleeyes
      Hello, i have a wonderful set of Weston Acoustics hand made by Earle and they are stunning, a combo of the time machine and the 300b's mono blocks but i really have an earth hum or noise that i need to try to eradicate. Any thoughts. I might need a sparky to put in a clean circuit to the hi-fi, i tried a Thor and also an Isotek but still mildly noisy at a metre or so from the speakers, thanks Adam
