Gieseler Audio
DAC Preamp wish list
Having already had a sneak peak at some higher res photos, I can only repeat - great job @Gieseler Audio (and son).
Looking forward to info on the single screen...hint, hint, nudge, nudge :)
Looks gorgeous Clay.
I'm a bit of a fan of the split screen actually, reminds you of the fact that you have two separate components within one chassis.
Edited by Cafad
Looking fantastic, I'm sure it will sound as good as it looks
what a professional job and its Australian made
well done Clay & to your son
Edited by woadl
This is the 2.4 inch OLED display we have been playing with.
It is much more readable from a distance. Also it is a graphic display (not character) so we can use the whole screen size to display say volume level
Just looked at the images of the prototype!
Holy smokes, that looks so pro!
Well some serious progress today!
Fletcher who handles the programming side of things has finalised the code for the new single larger OLED display. We are now using one much higher capacity micro controller rather than the previous individual micros on the DAC & Preamp boards. The new micro is on a separate PCB (separate PSU as well) so has much better isolation in respect to the audio circuits. Also system integration is far better with one micro in total control of the whole unit. The only down side is the senior solderer (ME) has the daunting task of mounting a hundred pin micro controller chip - 0.5 mm pin pitch so not too bad.
The OLED display works brilliantly, each function uses the entire character display so even I can read it from across the room without binoculars.
All that is left now is to cad up & order the new micro controller PCB.
Bottom line - should have a totally finished (one anyway) product in about two weeks.:party
Hey guys I have just come up with a rather radical idea that may interest the Multibit R2R fans.
I still have a stash of PCM1704U-K chips left from my PDX manufacturing days so I was thinking of a very limited run of digital front end boards using that chip. The DAC/Pre uses a seperate (relatively small) digital front end PCB with a socketed Amanero USB module so easy to swap over. It will be pricey though as genuine PCM1704U-K's from a reliable source are at least a couple a hundred a pop. From memory Element14's last remaining few listed arround $380!!!
Anyway I have ten PCM1704U-K's left, they are mono so I could only do five boards. Just a thought - feedback appreciated!
@Gieseler Audio  Everything okay with the DAC/Pre? I might be interested in giving a PCM 1704U-K chips a try? Let me know the cost relative to regular DAC/Pre
Hi Guys,
sorry for the delay with this. I'm in the process of changing houses so I have taken a bit of time off to get my house ready for sale. ETA on the finished DAC pre is about mid November. It is just waiting on a new controller board.
The PCM1704U-K digital option would be about $500 extra as that would be the extra cost to use those chips vs the AK4490EQ version.
I could also offer a AK4497EQ version at about $350 extra which is the one buy price for one of those chips at the moment. It is a lot less from AKM but they are only doing small runs at the moment & their minimum buy is 160 units! I have built up a AK4497EQ prototype which sounds very good but it is hard to tell is it is actually better than the AK4490EQ.
Understand that, going thru the same thing here. Very stressful.
2 hours ago, Gieseler Audio said:
Hi Guys,
Oh my! That's quite a big change! My family is only just starting to go through that process, still early days yet. Can't imagine the stress level of that so stay well.
On 19/10/2016 at 5:15 PM, Gieseler Audio said:
Hi Guys,
Hi Clay,
How has the house moving gone - hopefully smooth sailing, it's certainly not the least stressful activity one can undertake!
Any progress on the DAC-Pre?
Hi Adam,
my factory is jammed packed with stuff from home - trying to de-clutter a bit & make the house look good for potential buyers.
DAC/Pre  -   we have actually been working on it today & making steady progress.
RE mico controller
The TQFP-100 Atmega2560 chip was proving a bit of a challenge so we have gone back to the DIP Atmega 328P as it is much easier to work with. The 328P has limited digital & analog outputs but it looks as if we will just make it. Preamp section now working nicely with the new OLED display so just need to add in the DAC code.
Hello Clay,
My sympathies with the stress of moving home.
Just a question about using your DAC/Pre (or Klein ll - I need to decide) using USB-2 input: will it run as an ALSA device from an 'Idealish Server" running Snakeoil software without needing Linux drivers? Do you, or any of your clients, do this already?
Edited by BioBrian
got me terms in a twist
Hi Brian,
correct - no need for Linux drivers as the Amanero USB board does not need them with a Linux (or Mac) based server.
The Amanero only needs drivers for Windows which are available from his website.
I have tried Snakeoil with the Klein II using a mini-itx based server & it works fine.
Hey exciting news!
Digikey finally have stock of the new AK4497EQ DAC chip.
$71 US a pop tho. Ouch!
Actually just noticed that was in Aus $ so not too bad.
I have already developed a prototype using this chip so will be offering it as an option with the DAC/Pre for sure.
Edited by Gieseler Audio
Yes please !
20 hours ago, Gieseler Audio said:
Hey exciting news!
Hi Clay,
that is good news. Please offer the AK4497 as an option for your DACs without preamp as well.
Matt
Hi Guys,
well finally we have it all sorted.
The whole unit is controlled with one 28 pin DIL micro controller. It is in a socket so very handy for future firmware upgrades if required. The big OLED display has a home menu showing all info as well as sub menus in a large font which is readable from across the room. The AK4497EQ will be a upgrade option or I may even make it standard issue. Over the next couple of weeks I will machine out a new front panel & build up a fully finished final model. When that is done I will start a new product release thread with lots of info & photos.
Have a great Christmas
Clay
Fantastic new Clay
so looking forward to this, thanks
Nice work Clay!
Hopefully just in time for when I get my tax check back :partythis is my audio funds.
