Trough Lolly
7.1 Ht Receiver
ok this is gunna be my first HT setup so im just starting out basic, nothing awesomely expensive please. my amp budget is $1200 MAX.
its going to run a pair of towers,pair of bookshelfs and "maybe" a 12' sub (self amped)
so far im leaning towards the Marantz SR5600, i can get this for $999 (rrp 1399)
any suggestions helpful.
thanks guys :blush:
Cambridge Audio 540R. -> should be able to get for $800
if HDMI is needed then Denon 2607 -> should be able to get for $1500 or so
[/b]
great thanks drizt, where in aus is a cheap retail outlet?
do you think the marantz sr5600 would be good for my needs also?
reading a few writeups on the cambridge, they say its difficult to set up and its not n00b friendly :angry:
[/b]
The Cambridge is considerably better performing than similar priced AVR's however, due to it's substantial power supply and no frills approach.
Rick.
wat do i need to run 2 towers, 2 rears, and a sub?
5.1??
[/b]
Correct, but I would go 6.1 to add some sort of future proofing.
Granted only a few DVD's are in this format....but this will change.
I'm fairly sure that the Cambridge is a 6.1 receiver and not a 7.1 though.
[/b]
That's correct, it's 6.1.
Rick.
5.1??
[/b]
what you describe is 4.1 (four speakers + 1 sub)
you will also need a centre speaker to make it 5.1
AND
a rear centre to make it 6.1 OR a pair of side effects speakers to make it 7.1
AND
[/b]
ok, but a 7.1 receiver will still use the 5 speakers no problems tho?
a bit like having a 5 channel car amp and only using 2 channels if u will?
a bit like having a 5 channel car amp and only using 2 channels if u will? [/b]
definately.
