Inside an Apple charger
that is a great link, will port across to the Does it Comply sticky, as will people some idea the kind of death traps literally you are buying with cheap non compliant sh!te !
  • Like 3
Link to comment
Still amazes me, as with all cheap electronic stuff, how they can make and sell something like that knock-off one for a couple of bucks.
Yes cheap labour, but still....
:wacko:
Link to comment
http://store.apple.com/us/product/MC556LL/B/apple-85w-magsafe-power-adapter-for-15-and-17-inch-macbook-pro?fnode=a4dfd8c7200e678d571cc7aef40a24754a66bba5a47bc3cc11d2efa4e8da5047631055fd28178e6dfb5f4b6780a8a24a203e0a09bd25334b58eabc8c4230f7e1ba073d485e234ea82da5a8ae91dfab73f3da6e9aea23d2a53c3e24110424066b6d98c1a6447934b62f04f1018e6cce73
Not cheap, my daughters failed early and had to be replaced. We got the original from the Apple Store, why would you risk it for a $2k-$4k product that can void warranty if something goes wrong, not to mentioned safety.....
Link to comment
our charger for our 2011 15" macbook pro(looks same as one in the link) failed last year out of warranty. well actually didn't fail as such the cable outer sheath at one end was fraying…took it into the apple store and they replaced the charger and cable at no cost…no questions asked.
Link to comment
To Top
