Gieseler Audio
Klein DAC owners thread
Hi Alberto,
9v AC is fine but 12v AC is probably a bit high. With 12v there would quite a bit of heat disaption within the the Klein causing it to run quite hot which is not good. All Klein's DAC's now use a 9v AC 2A external transformer as the 10v unit you have is no longer available. The 10v unit was very nice but unfortunately it was discontinued.
betocool
Thanks Clay, that works for me very well!
Alberto
Wiffle
Can anyone tell me the output voltage of the klein dac?
Sent from my SM-G900I using Tapatalk
betocool
If I remember correctly, it's 5V or so P-P at full blast.
But don't take my word for it, Clay know better....
Wiffle
Thanks@betocool I'll double check with Clay. Thinking of running it straight into a power amp with no pre; suggested voltage was 2-4v...
betocool
5V peak to peak is 2.5V to -2.5V, which is about (roughly) 2V RMS. Check out what the amp says, RMS or P-P or what.
All Klein DAC's have maxium output 2 v RMS except for some of the very early ones which were higher at 3 v RMS.
Edited by Gieseler Audio
Wiffle
Thanks Clay; FWIW checked my manual when i got home and it says output voltage is 2.7v rms. So do you think it'll be able to drive a power amp directly when fed from the sbt?
Yes the Klein will drive a power amp directly. I used to use mine like that using JRiver in variable out mode. You just need to be a bit careful with initial setup & testing. Try & find a track that has a very low level at the start that way if you get it wrong you won't damage your speakers.
powerav
I'll be in the market for a new dac soon (3 months) for my Aries Mini, the Klein dac is the perfect choice but just wondering is there a newer or updated model planned?
Jonny
There's talk of it in the Konverter thread on page 8-9.
powerav
Yes well that's what I'm after, bang for buck and no bling.
well maybe some pretty lights for sampling rates.:)
Edited by powerav
Hi Dan,
the standard Klein at $750 is probably the best bang for buck but no DSD or sample rate display.
The Klein II at $1000 adds DSD, remote control & display showing sample rate, filter setting ect.
It had a small update in March this year with a new pcb but the same functions.
Johnny is talking about a brand new higher specked DAC which I will be releasing soon.
Seperate from the Klein range & around $2k.
powerav
Ok this is what I'll be looking at then, I had a second hand Klein and was the biggest regret sale ever but it was for a reason. Will probably look at the Klein 2 next time for the display and remote options.
Thanks Clay, hopefully my tax accountant does a good job this year.:thumb:
zypr
I've noticed this inconvenience with my Klein DAC where if I turn it on in the morning I need to keep turning it off and on for it to work, it's weird since the light is on when it's not working.
Now it's started it happen a lot more and sometimes I have to sit there flicking it off and on for longer if it doesn't start after 5 minutes or so, any ideas on this?
Edited by zypr
scumbag
Best to talk to Clay. When you say it doesn't work, do you mean the source reports that it is no longer there or does the source "see" the DAC and no sound comes out?
zypr
By the looks of it it's just not outputting anything to my amp, but my computer recognises the device.
Hi Thomas,
that is an unusual problem that I have not struck before. If you would like to send it back to me I will sort it out & it is certainly covered under warranty. PM me & I will give you the shipping address.
Cheers Clay
scumbag
12 minutes ago, Gieseler Audio said:
Hi Thomas,
Cheers Clay
Result.
