zog
active 2 way speaker using FaitalPro HF144 and Lorantz C390X B1 continued...
187 posts in this topic
That's not lots of stuffing IMO  ;)
 they also show exactly the same impedance wrinkles
Yep.  Except the little one at 200hz which is caused by your internal cabinet dimension(s).    More stuffing on the floor and/or roof will make it go away   ;)
Zog,
you will need to cross braced all sides, you can start at just behind the magnet for the vertical, then put the horisontal behind the vert brace, add more if you still see the wrinkles.
as its a big box, inherently you need to have more bracings.
i saw a very different wrinkles between free air and in box.
Edited by henry218
Perhaps you missed the different scales... They are (EDIT: the Z features) identical.
Rough picture is hard to see, but will hopefully help.
post-108814-0-96161400-1395196892_thumb.
Edited by davewantsmoore
wow, Dave you got a very good eyes :D.
yeah the 200hz prob standing waves within the box, the rest could help if there's cross bracing behind the magnets, but i could be wrong.
Yes, you are wrong, because the features also appear in the fee air curve  (as Zog suggested).
They are part of the driver ... and you would expect them for a 15", as it is well outside it's piston range.   EDIT:  but might be fixable my modifying the driver, perhaps by putting something absorbent on the basket frame, etc.
... but I wouldn't stress....    a LR4 slope as low as the CD/horn can take, would be a recommendation to avoid it  (and help in other ways too)
what i meant by putting a bracing behind the magnet is a cross horisontal bracing from the back panel to the woofer's magnet Edited by henry218
Oh, if you mean that more obstructive bracing could help with the 200hz blip... then yes.   It will break up the top/bottom, and side/side dimension some, which will affect the bump.
It won't change the higher frequency blips.   They are part of the driver.    Actually physically bracing the driver itself might affect them  (and is good practice), but I strongly doubt that.
Thanks guys, quite interesting!
So as I understand:
The approx 900hz wiggle in all graphs is part of the driver, and I shouldn’t worry about, as I'm crossing over at 600hz - even in future iterations of the crossover I don't see myself going any higher than 800 anyway.
The 200hz blip that appears (slightly moved around) in both the 90L trap enclosure and 131L "good" enclosure measurements  - is probably not related to the enclosure size or bracing directly as it appears in the graph for 2 completely different enclosures, but may be some resonance or vibration in the driver when it is bolted into a baffle. It might be fixed by extra cabinet bracing or supporting the driver.. but might not.
I do have an approx 211 hz notch in the F.R. for the 50cm graph that might correspond, but a few other F.R. graphs I've done further away at different angles and locations it's "lost in the noise" of other effects or just not there, so right now I won't lose sleep over it, though I might play with chocking something under the driver next time I have the box open and re-run the impedance sweep to see.
Other possible thing: I haven’t used any tape/gasket stuff under the lip of the driver, as it seems snug enough screwing the M6 allen bolts down against the quite flat rebate cutout.
cross bracing is very very important. i hope you will do this the next time you open the box up. i would recommend using 50mm insulation for the stuffing, you dont have to line it, can place on the same spot that you put the egg foam.
will you measure further? if you can post the frd on both drivers and determined the acoustic offset, i can run my sim to give you my version :)
Hi, I had advice that the 3 horizontal braces I've used would be fine so I I'll stick with them for now. Plus the box is glued shut - the only entry point is through the 352mm driver hole. I might paint that bituminous black stuff inside further down the track, seems to be what all the cool kids are doing :cool:
I will be measuring further - but for now I'm only looking at miniDSP crossover/EQ setup if thats what you are going to sim - not a passive crossover. Though notching down the woofer response will surely give me enough HF headroom for the CD waveguide HF rolloff compensation for a passive crossover.
I do need to redo the time alignment stuff though, what I've got in place now is from the old enclosure.
i have sim for active xover :)
pls make sure you measured the phase for the frd.
my recommendation is :
1. measure at tw axis at 120cm distance, gate between 4-8msec for both mid and tw (keep the mic position), so u will have 3 kinds, mid, tw and combined. this is to determined acoustic offset.
2. measure nearfield (max 2cm from dustcap of the woofer)
if you dont have gating function, thats fine also, i will sim baffle step and estimate the woofer farfield response and you can judge if its correct.
Henry
1 person likes this
Henry
Google Hilbert Transform ... The hard part of extracting minimum phase response is already implemented in a ACD tools ... Thank Charlie Laub. I believe and python / MATLAB scripts for getting minimum phase magnitude response are done too. PORC has a Hilbert transform step in it too ... I remember seeing that when I submitted a (unrelated) patch or two for that project last year.
Remember to properly gate the impulse response and compensate for baffle step is perhaps equally important ;)
Edited by hochopeper
yeah, i have all the necessary from jeff b and charlie laub, its one of the best gift for diyers from diyers :)
the phase is crucial for detecting anomaly in measurements.
Edited by henry218
1 person likes this
Yep.   You could tinker around and see if you can work out where it's coming from if you're interested.   Prodding and poking drivers while looking at the Z can be interesting.    It will give you an insight into how dynamic impedance is.   We always tend to think about impedance as a fixed 'curve', since it's presented that way...  but in reality it changes a lot  (cone position, surround/spider effects, etc, etc.)
Only some experimentation will tell you for sure...  but my guesstimate is that it is related to your internal enclosure dimension(s).    200hz corresponds quite closely to (half) your height dimension  (which is made slightly longer with stuffing) .... chuck a bunch of stuffing in there (a small blanket or something) as an experiment, and see if it changes the measurement.
Wiggles in the electrical impedance on their own are a concern for passive XOs  (but not for active speakers) ... but when something is reflected in the electrical system like this, it's hard to know if it's a "concern" until we work out the cause.
Yeah I would instinctively say that this is a boundary cancellation  (floor?) ...   but it's weak due to the closeness of the measurement.      You are definitely on the right track that lots of experiments is the way to figure this out.    Do a bunch of crazy things to rule in or out different hypothesis.    Measure at different angles/distances to see if it's an acoustic cancellation outside the box ..... stuff the box, or put something in there to break up the dimensions to see if you can tell if it's an internal acoustic cancellation.    Brace the driver to see what effect that has....  Brace (or damp crudely) the outside of the cabinet temporarily  (large clamps are handy) ... etc. etc.
The beauty of this is they don't have to be anything fancy or permanent  ...... and not only will you (hopefully) track down this issue.... but it can potentially give you insight into what else matters or (just as importantly) what might not matter.
If you are keen, do some of the above experiments before you do.    Clamp big bits of big ugly wood to the outside of your enclosure  (bracing!) .... or, stand mattresses or blankets up against the box  (damping) ....  just do some stuff, so that when you blacktak the inside, you have some data to look at.    It might be obvious, it might show nothing ....  but you'll have a better chance of knowing if the black stuff "makes any difference" ..... and hey! if the blackstuff makes the speaker "sound obviously better", and you measured "no difference".... well at least you have a real life data point which tells you that your measurement procedures need to improve.
Incorrectly gated measurements will give poor results....  as although they normally produce small variations in smoothed frequency response curves, these changes are over a wide bandwidth.    A 0.5dB peak with a very low Q (over a wide bandwidth) may totally transform the tonal character of a speaker.
somehow I missed this.
It's a good quick tool for iterating XOs   :thumb:
OK, here are some .FRD done with Room EQ Wizard (umik-1 calibrated microphone).
I renamed from .frd to .txt so I could attach them here.
CD = compression driver (i.e. tweeter).
all miniDSP config EQ/Xover/gain/delay flattened out before measurements, done on left speaker only, all done with identical mic position, gain etc, except for unmuting/muting the appropriate drivers.
The woofer 2CM from dustcap measured quite loud, I think it was starting to get close to the limits of the mic (distortion a tad high).. but the amplitude and phase info identical on a lower volume measurement so I left it as is.
Didn't do gating as I haven’t figured out Room EQ Wizard gating dialogue yet, this seems something that can be added on afterwards anyway as mentioned..
All done in room.
acd1_woofer_and_CD_at_120cm_onaxis_with_CD.txt
acd1_woofer_only_at_120cm_onaxis_with_CD.txt
acd1_CD_only_at_120cm_onaxis_with_CD.txt
acd1_woofer_only_nearfield_2cm_from_dustcap.txt
Yep.   Gating can be performed later where required.
Cool.  No harm in turning it down some, and noting the level reduction you used.
cool, ill do it tonight. :)
What will you do for the off-axis response of the woofer?     The tweeter?   (I guess you can see it a previous post)
Hmm... Which horn did you end up using Zog?
it will have approximate power response.
if after the xover implemented and somehow doesnt sound right then he can do average response.
in most cases on axis is good enough, he will need to tweak it anyway
hi Zog,
here is my first attempt for the xo, your measurements are hard to work with as no gating applied so im seeing too many reflections :).
please use this on your miniDSP
W : LR2 @ 400hz
Tw : 1st order BW 6db @ 3500hz,
EQ on Tw
-6db @250hz Q:1
INVERTED
the rest of freq shaping should be based on your taste, i hope this helps :)
Henry
Edited by henry218
1 person likes this
here is my sim
Addtional EQ
 3db @2500hz Q:2
-3db @10,000hz Q:2
6db @16,000hz Q:3
post-120534-0-10305900-1395302098_thumb.
post-120534-0-92443900-1395302104_thumb.
1 person likes this
hi Zog,
W : LR2 @ 400hz
EQ on Tw
-6db @250hz Q:1
INVERTED
Henry
Wow thanks! I'll run these up shortly!
Time to get to grips with the gating in REW.. or use arta/holmimpulse... they all have strengths and weaknesses.
the sim was based on LR4 acoustic TF, there are rooms for improvement, but unfortunately with current data, i dont know which one to correct.
if you can, pls do a fresh settings, ignore all EQ in the mean time so you can hear whats going on.
Edited by henry218
    • By logarhythm
      Item: See below
      Price: See below
      Item Condition: New like
      Reason for selling: Analogue dreams
          Gustard U12 USB / SPDIF XMOS convertor 32 bit 384k (New in opened box) $180 posted
      Open DRC DA8 - DAC, room correction and 4 way electronic crossover and by Minidsp (New like, had a fiddle but has not been set up - with original box) $SOLD (will cost you $460 delivered from minidsp)
        Photos from web: OpenDRC DA8
          Gustard U12:
    • By andreasmaaan
      Hi all,
      I'm considering plans for a new DIY project that's a variation on the portable boombox concept, hopefully with a more linear frequency response due to higher quality drivers and equalisation and (possibly) digital crossover using MiniDSP.
      The other major difference would be that the system would be modular, i.e. each driver would be housed in its own box, as would the mimiDSP/battery/PS/amp, and all would slot and fix together making them usable as either a portable boombox, or, at home, a 3 component (2 x speakers + 1 x amp/crossover/psu) system.
      It won't be dirt cheap, but I do want to keep costs down and try to achieve similar sound quality to a similarly priced consumer hifi system, so around 300-350€  (I'm in Germany these days, hence the Euro) or a bit more if I go for a more complex design.
      Similar projects have been written up extensively online as 'DIY boomboxes', but the main differences I'm considering in my build are:
      - the addition of a MiniDSP chip (or two) to improve the frequency response and (possibly) to replace the passive crossover with an active crossover
      - the use of modular boxes, allowing the system to be utilised as separate components
      I've chosen the PC165F because they are coaxial (making them easy to deal with) and relatively sensitive (91.9db @ 2.83V/1m), yet (according to Focal at least) have a reasonably linear frequency response and decent dispersion characteristics, as well as sufficient bass extension. On the other hand, I'm concerned about the high resonant frequency (70hz) and the high magnitude of the resonance peak (over 50 Ohm), especially given this will be powered off a cheap battery. So at this stage I'm also open to other driver suggestions.
      Input will be stereo RCA (or 3.5mm jack) into MiniDSP.
      From there, I am considering the following options:
      (1) MiniDSP as EQ (only) / 12V lead acid battery
      The MiniDSP  would be used simply to create a high pass (maybe 40hz) filter, compensate for baffle step, and iron out frequency response problems in the mid and (particularly) high range.
      I would house the coaxial drivers in well constructed 10-15 litre MDF boxes, and use either sealed boxes or more likely ported boxes, tuned (hopefully) to around 50hz. The MiniDSP would provide a quite steep high pass filter at 40hz-ish, and some EQ to compensate for baffle step and iron out irregularities in the response.
      This is the concept in a microsoft paint drawing:
      The basic equipment I have in mind for this is as follows:
      1 x MiniDSP 2 x Focal PC165F 1 x Hifimediy T1-M TK2050  1 x 12V UPS lead acid battery 1 x switching PSU
      With this configuration, I have these questions:
      Power
      Is it a good idea to use a 12V UPS lead acid battery for something like this? The basic reason I have it in mind is that it's cheap (around 10-15€) and easily replaceable. Are there better ideas for the battery?
      If I do use such a battery, how do I set up the system to: (1) run off the PSU when plugged in and switched on, (2) charge the battery when plugged in and switched off, and (3) run off the battery when unplugged?
      I'm an electronics novice but a patient learner. Is this something I can realistically and safely achieve?
      Is there a simpler way of doing this that I'm missing? For example, is there a ready-made battery/psu that I could choose that would recharge and provide power to the system at the same time, so that I don't need the PSU or any kind of switch?
      The miniDSP also needs to draw a small amount of power from somewhere. Where would this come from and how would I make it work?
      Speakers
      These drivers have slightly odd parameters as I mentioned before:
      Will that very high magnitude resonance peak be a problem for a relatively low powered amp like the Hifimediy T1-M running off a 12V battery?
      The amp is 57w into 4Ohm with a 24V DC supply, but where the resonance peak is it would be running off a 12V DC supply into probably at least 40 Ohm (I am assuming that the heavily damped ported box will move the resonance up a bit from 70hz and reduce its magnitude somewhat).
      My understanding of how this amp works is that it might struggle to produce much power in this frequency region, is that right?
      Boxes
      The driver parameters suggest a ported box will work better, and since these are going to be midwoofers, ports would make sense from the point of view of efficiency. Can anyone see a problem with using a 10-15L box with damping material, with a 5cm diameter port tuned to quite a bit below the Fs (hopefully 50hz), and a digital high pass filter just below the port tuning frequency?
      (2) Extra amp and sub
      This would involve adding an additional monoblock chip amp and a small high-efficiency sub, which would most likely be housed in the central unit with the battery and amps etc. This would change my power supply needs, but I'm not sure I understand how. Assuming I found an efficient D-class monoblack 50w or 100w change amp, how would I calculate my power requirements? Would there be any chance of sticking with the 12V lead acid battery or would I simply need to abandon this idea?
      And does anyone have any suggestions for a decent, small (ideally 8 inch) and efficient subwoofer and amp for this arrangement?
      (3) MiniDSP as crossover
      This design idea would be very similar to (1), but in this case the miniDSP would split the input between the woofers and tweeters and replace the passive crossover in the driver unit. There would be an additional Hifimediy T1M amp giving a total of 4 channels.
      My question here would again be about the battery and PSU. If I were now powering two Hifimediy T1-M's off one PSU or battery, how would that change my power requirements?
      Would I need a more powerful battery? If so, how powerful would it need to be, and does anyone have any idea what I might use?
      (4) Extra amp and sub / 2 x MiniDSP
      This would be the most complex setup and would involve housing an additional sub in the central unit, adding a MiniDSP to create a 2.1-way crossover, and adding an additional sub amp.
      My question about power supply / battery is similar to my question about the extra amp in design (2) and (3). How would I calculate my power requirements? Are there any suggestions for batteries / PSUs?
      (5) 2 x sub / 2 x MiniDSP
      This is basically like design (3), but there are 2 subs instead of one and an additional stereo amp (rather than a mono amp) to power them. The subs would either both sit in the central unit or would have their own boxes, ideally also not much bigger than 10-15L in size. I guess my questions about this design are basically the same as for design (3).
      Many thanks in advance.
    • By Bunno77
      Hi all,
      There are endless forums on miniDSP products and as such I'm hoping to save a few hours reading.
      I am thinking about integrating my SVS SB13 Ultra into my 2 channel set up and if I do i was considering giving my amp and speakers an easier time by filtering lower frequencies.
      All I want is to put a xover between my DAC and integrated (not interested in doing room correction with miniDSP. I am considering room correction with either acourate > HQplayer > microrendu/ SOtM) So either the 2x4 or 2x4HD is what I am looking at but open to other considerations being models or other brands/solutions. The sub has a lot of DSP processing too so I don't need miniDSP to handle any of that.
      My question is.... is adding this going to be detrimental to sound quality by the introduction of noise or anything else audible that will outweigh the gains of the amp and speakers having an easier time?
      Are there other solutions or crossover devices I could use instead of miniDSP? Maybe Behringer?
      I know there is DEQX but it is a bit of overkill if I am happy with my pre, DAC and streaming.
      Any help would be greatly appreciated
      Dan
