Item: Musical Fidelity NuVista Preamplifier
Location: Len Wallis Audio HQ - 64 Burns bay Road, Lane Cove NSW
Price: $1200
Item Condition: Very good
Payment Method: Cash, Credit Cards, PayPal
Extra Info:  Launched in 1995. The NuVista Pre-Amplifier was a limited production unit with only 500 made worldwide. Musical Fidelity claimed that it sold out within 3 months. This particular example is number 24 of 500.
Those familiar with Musical Fidelity will know that this pre-amp used the unique 'NuVista' tube – some say ‘the missing link tech’ that was part tube, part transistor and superior to both. This one also provides five line level inputs, which are all gold plated.
In excellent working order, this power supply and pre-amp is a rare find...
Edited by LWA Staff
Sight change to title
Hi al, we have the remote, the manual is downloadable, but we don't have the original carton.
Bill206
PM sent with questions and intention to purchase.
    • By SoundGuy
      Item: Parasound  P5
      Price: $1400  RRP $2195
      Item Condition: Used (9/10)
      Reason for selling: Excess to Need
      Current RRP is $2195 https://www.apollohifi.com.au/parasound-halo-p5-2-1-channel-pre-amplifier-sil.html
      Hard to find in the used market.
      This is the preamp that is not pretentious but does everything exceptionally well. There's not many (none) preamp out there that does all that the P5 does with the sonic quality that it produces.
      Analog inputs: It has Stereo Balanced XLR inputs & regular unbalanced (RCA) inputs, Digital inputs: usb, coax and optical digital inputs which run through a Burr-Brown PCM1798 DAC Excellent Phono stage Home theatre bypass capability so can seamlessly integrate into a multi-channel system Best feature: Dual subwoofer outputs so you can run a two channel system with subwoofers. Remote control
      Read the review here: https://www.stereophile.com/content/parasound-halo-p-5-21-channel-da-preamplifier
      It's in flawless, absolutely as new condition but I don't have the original box. So local pick up preferred.
    • By boogietronics
      Item: Classe CP-60 preamplifier in BLACK
      Price: $1800
      Item Condition: Excellent
      Reason for selling: Saving to purchase preamplifier with USB input
      Payment method: Paypal, COD
      Extra Info:  Reviews:  http://www.audioreview.com/cat/amplification/preamplifiers/classe/cp-60/prd_118234_1591crx.aspx
      Manual and specification details:  http://bwgroupsupport.com/downloads/manuals/classe/CP-60-OM.pdf
      Up for sale is my much loved Classe Audio CP-60 preamplifier.  It's in excellent condition and in perfect working order with a full health check from Chris at Kimil electronics.
      The unit is built like a tank and has MM / MC phono inputs,  remote control and a separate power supply that has been converted to 240 volts as per Classe Audio instructions.
      It's a reluctant sale but I am saving to buy something with USB functionality to support my digital library.
      Local pickup preferred but can arrange shipping if required but this will be at your cost. Please note the unit is approximately 12 Kgs.
      Please feel free to contact me for further information.
      Thank you
      Tony
      Specifications :
      Frequency response.........................20 Hz to 20 KHz, + /- 0.1db
      Sensitivity........................................22V
      Maximum output voltage...................1 Hz to 150kHz, -3dB
      Line................................................120 mV
      ..................................................3 mV (Magnetic Phono)
      ..................................................0.1 mV (Moving coil Phono)
      S/N Ratio, A weighted.......................95 dB (Line)
      ........................85 dB (Magnetic Phono)
      ........................85 dB (Moving Coil Phono)
      Input impedance...............................50 KOhms (Line)
      ................................47 KOhms (Magnetic Phono)
      ................................Adjustable into 47 KOhms (Moving Coil Phono)
      Output impedance.............................Less than 1 Ohm
      Gain................................................18 dB (Line)
      .................................................35 dB (Magnetic Phono)
      .................................................22 dB, Adjustable 20 dB to 40dB (Moving Coil Phono)
      Power requirement............................50 Watts
      Weight.............................................12 kg
      Dimensions(w x d x h).......................48.5 x 36.5 x 8.5 cm
      Power supply
      Dimensions(w x d x h).......................19.5 x 34 x 8 cm
      Miscellaneous :
      Made in...........................................Canada
      Original remote.................................Yes
      XLR.................................................XLR Input & XLR Output Available
    • By GiuseppeBecco
      Item: JC2 Bypass
      Price: $5500
      Item Condition: Used Mint Condition
      Reason for selling: Moving for work and system was too large
      Payment Method: Pickup - Cash, Bank Transfer
      Extra Info: This preamp was in my larger system and the balance of my 2 channel system has been sold (see my other post). This amp retails at close to $9k and is highly sought after by many audiophiles. The links below speak volumes (pardon the pun) of the quality of this unit. If you are in the market for a preamp then this is the one you want. OEM Boxes and manuals available. This JC2 is like new and has only ever been fed clean power from a PS Audio P10 power plant.
      https://www.stereophile.com/solidpreamps/308para/index.html
      http://www.ultraaudio.com/equipment/parasound_halo_jc2.htm
    • By GiuseppeBecco
      Item: PS Audio PWD II with Bridge
      Price: $3750 excl shipping
      Item Condition: As New Mint Condition
      Reason for selling: Was part of a larger system that I have now sold
      Extra Info: This component DAC has been the front end of my system for over 3 years and has provided hours of fatigue-less listening. It provides a stunning sound stage and has the ability to stream music via a DLNA complaint server through the bridge II. I am sorry to see my system go but unfortunately I don't have the flexibility to take this with me interstate. Below are some links to reviews on the product.
      http://www.digitalaudioreview.net/2012/09/psaudio-perfectwave-dac-mkii-review-part-1/
      http://www.audiophilia.com/reviews/2016/1/16/ps-audio-perfectwave-network-bridge-ii
    • By LWA Staff
      Item: Quad 606 Powers Amplifier and Quad 34 Pre-Amplifier
      Location: Len Wallis Audio HQ 64 Burns Bay Road, Lane Cover, NSW
      Price: $1750 (StereoNET special)
      Extra Info: Rare Quad 606 power amp offering a solid 140 watts per channel (8 ohms) and a Quad 34 Pre-Amp which features 'TILT' control which offers sound correction on recordings.
      Sweet combination.
