My jvc x30 just stopped working. Standby and warning lights are solid red and the lamp light flashes orange twice at a time. Is it just a lamp replacement or is it something worse. Worried it might be something worse as I don't have my spare jvc hd550 anymore as a replacement :(
CAVX
Did you hear a pop or did the lamp just go out?
These are not like DLP where if the lamp explodes it can take out the colour wheel.
No pop, it just suddenly went dark. I do have to mention I hadn't used it for like 2 years and then started to use it again when I had set up my room and that was only like 2 months ago. Also since I had started using it again I did notice a couple of times while watching it that it would go blank or for a second or so then the picture would come back. Does that sound like the lamp was going? I hope it's just the lamp and not anything else.
CAVX
Not sure why you would see a blank or black flash.  Could be a sign, I've never seen that though.  Normally lamps at end of life get yellowish around the edges of the screen.  Most noticeable on full white fields.
If it didn't pop, then you should be OK to plug-n-play a new lamp.  I'd still change the air filter and give any vents a vacuum to rid any built up dust.
I am thinking the black flashes may have been hdcp or hdmi issues. So may not be connected.
So I can use a vacuum on the external air vents? Is it safe?
Bah looks like the bulb from the  hd550 won't fit my x30. I thought they used the same lamp. Where's the best place to buy lamps?
Is it easy to just get the lamp and change it in the housing module? I don't really want to do soldering etc. can you just click it on or something or does it require some wiring and things?
Couldnt decide where to order myprojectorlamps, justprojectorlamps or ozlamps. In the end Ozlamps seemed the cheapest. They all seem to have the option of original lamp in a generic housing which is the option i went with. I noticed that justprojectorlamps seem the only ones that have original lamps and housing straght from JVC? but they are pricey in comparison.
Hopefully ozlamps is reliable and good :). I got too scared of getting just the lamp and using my own housing as the ozlamps guy seemed to think its not recommended unless you are a tech and the warranty they provide if you use your own housing is only 90 days instead of 180 days if i buy the lamp and housing from them.
CAVX
Just open the suction valve on the hose if your cleaner has that or don't make a seal and let the air just take away any dirt, fluff etc.  If you have one of those clip on brushes, use that.  It will prevent you from making a full seal and it also helps reduce scratching the shiny plastic case.
the issue is the dust is actually like inside the vented area on another vent or something. Like its an inch or 2 inside from where i can get at it. I can only see it through the vents on the corners of the projector. Hard to explain, I dont think the vents open so i cant reach through the vents and the vacuum isnt strong enough to suck it with a gap of an inch or 2. I could maybe try poking through a small brush if i can get one to fit through the holes but not sure thats safe and that might distribute the dust internally..
CAVX
Yes the dust tends to build up and pack in tight.  A small brush might be what you need.  However, you will want to have the vacuum cleaner going so it can suck out this dirt rather than let it fall inside somewhere.
Yeah thats what i was worried about, i will try to take a pic of it. I dont think i will be able to reach it either way sadly.
CAVX
Suck out what you can.  If you can reduce the built up dirt, then that has to be an improvement on air flow over you had.
I just replaced the lamp with the new one I bought and no go. Still the same problem. No noise besides the led going from green to the warning lights after 10-15 seconds. Sucks. So now I have to figure out where to take it for repairs
Owen
Its likley the ballast (lamp power supply) has failed.
Hopefully they can get parts quickly :(, I did buy a Epson EH-TW9000W second hand a year or so ago and never used it as i had the JVCs anyway (sadly i gave my older JVC HD550 to my bro so thats no longer available for me to use) but i can use the Epson in the interim period while the JVC is being repaired. Hopefully it works, I never even tried it since buying it second hand...story of my life :(
CAVX
Is that a part of the actual lamp housing or in the projector itself?
I've seen so many people just replace a lamp (only) to a save a few dollars and not replace the entire unit.
Edited by MarkTecher
I replaced the whole unit, so i think the ballast is separate from the lamp housing, I presume its what the lamp housing power connects to.
CAVX
So off to the service agent now.  And I have no idea who is the service techs for these in Sydney.
I was told about this place in Castle Hill called Westview Electronics, so i contacted them and they said its minimum 198$ for them to diagnose the issue and attempt a fix.
I have also contacted JVC directly as i am not sure if this place is the best service centre or if they have others closer to me. But they havent gotten back to me yet.
CAVX
$198 just to look at it sounds a bit steep.  I'd hope that includes parts and labor.  And umm, yeah, attempt to fix...
I do hope JVC get back to you soon.
They said when they fix it, the 198$ will go towards that too and if all up it costs more than 198$ then i need to pay the difference but if it costs less than 198$ then i still have to pay 198$ as that is their minimum price to diagnose etc. IT did sound a bit high to me but considering it will need parts and labour to fix anyway then its not as bad unless its just a capacitor.....
CAVX
The local guys I know of here on Brissie south side usually charge $66 and then you pay the balance if you agree to their price to fix quote.
    • By nigybrix
      I have the following below, contact me if interested.
      Benq W1200
      Benq SH960
      Benq SP891
      Canon XEED WUX10 Mark II
      Epson EH-TW5900
      Epson EH-TW9000
      Epson EH-TW5500
      Hitachi CP-X809
      Hitachi CP-WUX645N
      Hitachi CP-SX12000
      JVC DLA-X3
      JVC DLA-RS65
      JVC DLA-RS55
      JVC DLA-F110
      JVC DLA-X7.
      JVC DLA-HD10KELD1
      JVC DLA-X9
      JVC DLA-HD10KELDB2
      JVC DLA-HD10KS
      Mitsubishi FL7000U
      NEC NP4100
      NEC PX800X
      NEC PX700W
      Optoma HD33
      Panasonic PT-DZ12000
      Panasonic PT-AE500E
      Panasonic PT-DZ6700EL
      Panasonic PT-DW5000E
      Panasonic PT-DZ6710EL
      Panasonic PT-DW10000E
      Sanyo PLC-XP100L
      Sanyo PDG-DHT100L
      Sony VPL-VW90ES
      Sony VPL-VW95ES
      Sony VPL-HW30ES
      Sony VPL-FE40
      Sony VPL-VW200
      Vivitek H9080FD
      Vivitek H9080ST
      Vivitek D8300
      Vivitek D6010
      Vivitek D6510
      Vivitek D5500
      Regards,
      [email protected]
    • By jubbing
      Hi Folks,
      So i bought a JVC projector recently, the x90. Had it professionally installed and calibrated as well (at least to the best of my knowledge) and the 2D Blu-ray quality is absolutely stunning. The only issue I have, is with the 3D quality that comes out (played with a Panasonic BWT800 blu-ray player, also have a ps3 but I think the BWT800 has better quality).
      Now what my issues I seem to have is that during a 3D movie (in this case Transformers 3), it seemed really weird on the eyes in that it wasn't as smooth as I expected it to be. Now it's a 3D only blu-ray movie that is being shown, and the BWT800 supports 3d. The projector does have a high speed cable into an integra 50.4 amp, as does the BWT800 player so that's not an issue.
      I can't exactly tell why the image seems a little fuzzy at times. Is that how 3D movies are at home? Is this what they mean by crosstalk? I also read somewhere that the projector doesn't automatically swap to 3D or something (in a review I read) so I'm really just trying to figure out if my eyes need to adjust to the signal, or that's just how it is (I'd hope not).
      Sorry if anyone was confused here, but I was hoping for some input.
      Also, how does the 4K eshift tech work, I can't seem to find anything about it in the manual nor in the projector settings?
    • By HTFan
      Up for sale is my JVC DLA-HD350 projector. I purchased this early 2010. Original RRP for this was $5000. Anyone who know's JVC projectors knows just how good they are, with extraordinary blacks, colours, motion tracking and levels of detail.
      This review by WhatHiFi on Youtube pretty much says it all - http://www.youtube.com/watch?v=z7zJAa8Ffwk
      The DLA-HD350 was WhatHiFi's product of the year for 2009, as they say in the video review nothing else came close.
      Location for pickup is Middle Park Victoria. I will throw in the ceiling mount for this projector.
      Looking for $1000.
    • By :) al
      Well luck would have it with much thanks to matt at TCC I ended up with a JVC x35 to check out over the last queens birthday long weekend.
      As some would know to really appreciate something am a strong believer in checking out for myself and where possible demoing at home to experience in my own system to come to my own conclusions.
      Thought I'd post here as my impressions and experience with it might be of interest to some and also some comparisons I can make to my own epson 9000w
      the x35 is pretty much out of box and with 4 hours on the clock. when I picked up from the store the quick spin they gave it for me had good contrast, sharpness and brightness but the colour balance and skin tones to my eyes looked a bit over ripe ! not that bothered me too much as was sure at home could give it a bit of a tweak. Plus also keen to check out what might be like in my own setup with your typical lounge room with white walls and ceilings light carpet and furniture/furnishings vs say the blacked out surrounds of the TCC demo room
      screen size is a 92" 16:9 so not massive but and am viewing from 2.9m which is bang on thx recommendation for immersion and is well within the distance for visual acuity to resolve 1080p so should do justice in appreciating the detail and immersion with a projector.
      so without further ado lets get on with it... JVC in da house
      ofcourse wife noticed it straight away it is a big projector and BLACK unlike the lounge room friendly white epson. But yeah I reassured her it was just a loaner and just for the long weekend
      I use the peerless mount PRG-EXA wall mount and to mount the jvc you need to remove its feet meaning long screws m5x25mm are required to secure to the mount bracket. this is unlike with the epson where dont have to take off its feet and can use the surface mount screws the peerless comes with. but anyways a quick trip to buntings soon had that sorted. It is a narrower but deeper projector than the epson meaning I had to use full extension on the prg-exa to make sure it had clearance on the back. But yeah was soon easily mounted squared / leveled up with the peerless no probs. Hook up was pretty simple just the same as with the epson.
      I downloaded the jvc manual for a quick peak to familiarise myself, but the remote and everything appeared pretty intuitive so off I went with switch on.
      Easy enough in use, the menus on the jvc and remote pretty straight forward. In alignment with vertical/horizontal shift and zooming these beign motorised is pretty handy on the jvc vs the manual controls on the epson. the focus for instance can pretty much stand at the screen and get just right in adjusting vs with the manual control on the epson have to stand at the projector and try and do it manually. The controls for focus zoom and image shift are quite fine in resolution so easy to use, however strangely I did notice just in one direction ie in upwards vertical shift the jvc is a little coarse in movement ie jumps/steps upwards but coming downwards is quite smooth. odd just meant took a few goes to get just right
      OK on to watching something onscreen !
    • By Swift1
      JVC 2014 range officially announced at CEDIA 2013
      http://www.twice.com...r-lines/108501#
      The new JVC projectors now have a Dynamic Iris!
      JVC DLA-X900R
      1300 lumens
      150,000:1 Native Contrast (1,500,000:1 Dynamic)
      Hand-selected, hand-tested components
      ISF certification
      THX 2D and 3D Cinema viewing modes
      Adobe RGB picture mode
      Included two pairs of PK-AG3 RF 3D glasses and a PK-EM2 3D signal emitter
      Three-year warranty
      November for $11,999 USD
      JVC DLA-X700R
      1300 lumens
      120,000:1 Native Contrast (1,200,000:1 Dynamic)
      ISF certification
      Two-year warranty
      November for $7,999 USD
      JVC DLA-X500R
      1300 lumens
      60,000:1 Native Contrast (600,000:1 Dynamic)
      Two-year warranty
      November for $4,999 USD
      JVC DLA-X35 to remain in the 2014 line up
      New across the range for 2014
      All of the new units now are compatible with native Ultra HD signal sources and can process 4K signals for a smoother, more detailed image (Support 4K/60p Input)
      User-selectable Intelligent Lens Aperture (Dynamic Iris)
      Sixth-generation JVC D-ILA imaging devices that feature a pixel gap that’s 40 percent narrower than the previous chip for a smoother picture; a 10 percent improvement in light efficiency for a light output of 1,300 lumens; and improved native contrast
      Third-generation wire grid optical engine
      Two memory settings for pixel convergence to store correction settings for external lenses
      Smartphone app that provides remote control functionality
      RF rather than IR connected active-shutter glasses to limit interference
      Clear Black feature that provides local area contrast enhancement
      Improved Clear Motion Drive (CMD 3), which uses a new LSI and algorithm to clean up motion artifacts on diagonal lines on 4K and 2K 2D content and 2K 3D content.
      Multiple Pixel Control (MPC) processor with eight-band detection. The MPC processor offers four presets plus an Auto setting that automatically selects the best up-conversion process by detecting the frequency of each pixel
      E-shift3
      Well the big reveal is the Dynamic Iris and thats a huge announcement for JVC and long time coming for some. So no native 4K model by the looks of it, though they all must have HDMI 2.0 to accept a 4K/60p input. THX 3D mode for the top two; maybe another nice boost for 3D in this range.
