josh8140
Can anyone clarify if there would be any visual advantages/disadvantages to using MDF, melamine or plywood as a screen material.
I will be using a base primer coat and 5 coats of the black widow mix so would there be any noticeable difference depending on which material I use? I would think they would end up looking the same after this many coats of paint but some forums have said melamine can cause hot spots, the plywood texture may show, etc.
I'm not sure if it matters but I will be using a BenQ w1090 at 2.8m so around a 90" screen.
Thank you for any help.
Quark
I definitely wouldn't use plywood - the grain is likely to be visible even if you use marine grade (the smoothest). Not sure how you would go getting paint adhesion and a consistent finish on melamine - expect MDF is your best bet.
hmm is there a reason you want a big piece of board? mobility maybe? a wall would be just as good.
the other thing with that pj to consider is the colour of your ceiling, wall behind the screen and other walls.. in that order.
Edited by hopefullguy
josh8140
Thanks, that's true, i'll go for MDF which also works out the cheapest. Bunnings stocks 3mm to 16mm thickness sheets so I might get the 3mm to keep the weight down. It does bend a fair bit though so would that will affect the paint?
I'm currently renting so I'm looking to build a board and stand I can take from house to house. The back wall is white but sides are grey.
Edited by josh8140
Quark
If you use 3mm you'll probably need a decent frame with multiple bracing to reinforce it.
agree.. 3mm is very thin so a frame would be needed. but having made 2 screens my self portability using material is a problem as easily damaged.. a board wont suffer this.
just an idea about the wood. as you are going to paint it anyway when you go to bunnings and look at the mdf area you will see what is called "cover sheets" these are used on the top and bottom stack of sheeting to keep the main pieces undamaged in transit. if you ask they normally sell them for $10.. it is the same as the good mdf sheets just a little dirty. could save some money this way.
i would think 9mm would be ok i dont think 3mm will be worth the trouble
josh8140
Awesome! Cover sheets sound like a smart idea. I'll go for the 9mm so hopefully it lasts longer. I think I'll prime the edges too in case any liquid ever gets spilt on it.
CAVX
If DIYing a screen, try and track down "FOAMEX".  I used this for while unpainted and it generally was pretty good.
Owen
Is there a reason why you want to DIY? Chinese projector screens are really cheap and will almost certainly be better than what you are proposing.
The fixed vinyl screens have a super smooth surface and will be much better and weigh much less that a sheet of board.
josh8140
Yeah I have sourced a PVC foam sheet which I'll try painting, it should be super smooth! I haven't been able to find any cheap screens with a grey tint like black widow. I may buy a cheap white one to compare when I'm done though but from what I've read the black widow paint will have much nicer blacks and contrast compared to a white screen.
Owen
A grey screen will have a lower gain then white and provide a dimmer picture, but since black and white are dimmed by the same amount contrast is unaffected.
I have never seen PVC foam that I would call smooth, and even it there is you will need to spray the paint on in a dust free environment and be talented with a spray gun  to have any chance of getting a surface any where near as smooth as a vinyl screen material, its REALLY smooth.
The cheap Chinese fixed screens typically have no gain and I have seen grey ones with gains below 1.
There is a link to some grey vinyl material for cheap. Don't know how smooth it is.
http://roundupreviewsau.com/au/gray-projector-screen-material
http://www.ebay.com.au/itm/Carl-s-FlexiGray-16-9-71x126-Projector-Screen-Material-High-Contrast-Gray-/231018415694?hash=item35c9c5464e:g:lcgAAMXQysxR8CxV
If you want a screen for a non dark room that actually works you need a high tech ambient light rejecting screen, they are angular reflective, complicated to maufacture and normally VERY expensive, although small sizes have been available for not too much in the past.
Even then you need to understand how they work and manage their limitations. They typically only reject light coming from above or below, not from the sides or from the projector end of the room.
josh8140
Cheers for the links Owen, I'm going to pickup some of the material so I can do a comparison to the paint.
I'm aware using a low nap roller is the cheapest way to get an almost smooth paint surface but if it doesn't come out smooth enough I'll be renting a sprayer and painting the other side. The PVC is insanely smooth which is why it's used for sign printing so I don't think that will be an issue.
The black widow mix is a little different to grey as it uses aluminum to tint it which gives it better whites, blacks and dynamic range. There's some good info on it here:
https://en.wikipedia.org/wiki/Black_Widow_(paint_mix)#A_very_brief_history_of_DIY_painted_screens_and_some_of_the_more_popular_methods_and_mindsets
I've got a very dark room for the projector so I'm hoping it looks amazing.
Owen
Don't get sucked in mate, no screen can improve contrast in a dark room, its simply not possible. The screen reflects light equally for white and black so the ratio of black to white (contrast ratio) is ALWAYS the same. The amount of light that is reflecting is determined by the screen gain, low (negative) gain gives a dimmer picture for both black and white. Higher (positive) gain screens give a brighter picture for both black and white.
There is no way to reflect low light levels (projected black) and high light levels (projected white) differently.
If you really want to improve ANSI contrast you need to reduce or elimiante light coloured surfaces in the viewing environment that will reflect light back at the screen and degrade contrast in brighter scenes, that means black walls, ceiling, floor and furnishings. This makes a MUCH greater deference than any screen can.
If you have a blacked out and dark room a white screen (gain of 1) is normally the go because it will have the best screen uniformity. Even the very expensive angular reflective screens are pointless in a black out and dark room, and slightly degrade picture quality compared to a white screen.
josh8140
Thanks for the explanation, I had the same thoughts but I'm not sure if the aluminum somehow improves whites. Either way it should still be a good mix as it's supposed to do good with ambient light and dark rooms so it sounds like a good all rounder.
https://simplehomecinema.com/2014/10/12/how-to-build-a-300-screen-that-performs-like-a-2000-one/
Wish I could paint my walls darker lol but I'm renting at the moment.
Owen
Aluminium typically reflects more light than white, it has a gain of more than one. This will make whites brighter, BUT it will make blacks greyer (brighter) by exactly the same amount. Is that what you want?
For a not dark room extra gain is useful, but for a dark room its counter productive.
If you are renting and cant paint the room black, create an alcove out of black velvet stretched over a home made frame that is free standing and doesn't damage the room surfaces in any way. The "tent" is relatively close fitting and extends out about a meter from the screen at top and both sides. This blocks much of the light from the screen from shinning onto the ceiling and walls close to the screen and lighting them up. Its really effective and makes a very notice improvement to contrast in bright scenes, plus it keeps the area in your peripheral vision black or very dark which is very helpful for immersion
If the floor is not a dark colour a dark coloured rug or more black velvet covers that angle. A dark curtain can be used to cover the wall opposite the screen, supported by a floor standing frame if you cant hang it on the wal.l
This approach works better than a multi thousand dollar angular reflective screen and eats a painted screen.
josh8140
Interesting I haven't seen that done before, I will look into it if I'm not happy with the contrast. The aluminum has a grey tint too so I'm not sure if it's going to make things brighter or darker. Hopefully it defies the laws of refraction and I get darker blacks and lighter whites lol.
As long as the plywood is sanded super smooth and primed+smoothed, it'll be as smooth as you make it.
Melamine is glossy/hotspot-y when used unpainted, but coating it with flat/matte paint or primer will make it just as flat/matte/non-hotspotty as any other flat/matte surface.
josh8140
True, I ended up buying the PVC foam and painting it with 4 coats of black widow with a low nap roller. Even with a low nap roller there's a texture and I tried sanding the primer but the scratched texture looks even worse. The guy at the paint shop said there's no point sanding primer with higher than 240 grit as rolling the paint will always leave a texture. The black widow paint seems to hotspot with a torch so it will be interesting to see if it does with the projector.
Hey guys,
Since I got fed up with having to explain to people how to mix cinema paint over the years, I am selling pre-mixed versions of N7.5 darkness starting from today if anyone is interested. The first batches are limited to 10litres at this point and there's a lead-time of 1 to 2 weeks dependent on stock but things will speed up considerably over the next month. Direct your friends to it, especially if you are just as tired of explaining as I have become.
https://wordpress.com/page/simplehomecinema.com/1187
http://www.ebay.com.au/itm/122690754801?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Thanks,
Roland
    • By mttel
      Hi All,
      thought that I would post my activities over the last few days.
      12 months ago I went from a 100 inch 16x9 to 130 inch scope screen with a mk3+c and now a mk4 aussiemorphic lens.
      There a well know comprimises with A-lens, prisms (ie mke 3+c) will exhibit minor non uniformity and CA particularly at the left and right edges and cylindical (mk4) whilst providing clear and sharp focus across the whole image generally suffer minor pin cushioning. (note trying to start a war here just stating the facts and note I did say minor)
      Anyway in my setup the pin cushining is approximately 25 to 30 mm (top and bottom) at the centre for approx 3100 mm screen width. Not a lot but like all these things when you know its there is bugs the hell out of you. You can see the impact on the attached image which is a grid pattern, the top and bottom lines drift off the screen half way between the centre and the edge of the screen.
      On way of dealing with the pin cushioning is to curve the screen. I discussed this with Mark Techer for CAVX and Richard at OzTheatre about 6 to 8 months ago, and with a bit of spare time in the holidays thought I'd give it a go.
      First work out how much to bend the screen, after much searching of the internet for maths formulaes to work it out (never lose that engineering approach) I fell back to Marks tried and simple method which is simply to use something (in my case a length of stiff paper) to measure and mark the height at the centre of the screen, then move to the edge and move the paper out from the screen until the image from the projector is the same as the distance measured in the middle. In my case the distance out from the screen was 100 mm.
      So a quick sketch and off to bunnings to buy some supplies. I ended up deciding on using a 140mm width MDF to make a box which would then be attached to the wall.
      Couple of photos of the construction showing
      - the raw materials laid out on the floor
      - frame made up and trial put together on the floor
      - all painted up (blocks at the ends set to hold the ends of the screen 100mm out from the centre) and test of the curvature using some scraps of timber
      So the next day into the theatre room and pull everything off the from wall and mount the frame to the wall.
      Brace the back of the screen (good tip from Mark) as due to the cross sectional shape or profile of the screens frame, the screen will try to pinch in the middle as the pressure is put on the screen frame to force it to curve. I used 20x12x1.4mm aluminimum angle.
      I drilled a hole through the screen frame at the centre and then used a tek screw to pull the centre of the screen back against the box mounted on the wall.
      So after all that effort did it work?
      In short yes I think so. The attached grid pattern shows that almost all of the image is now on the screen, there is a slight drift off in the top left corner but compared to the before shot much better.
      Measurements of the grid rectangles using a tape measure are
      1. width is 296mm at centre and 301mm at either side (1.7% increase)
      2.height is 207/208mm at the centre and 210mm top and bottom
      Issue/lessons learnt/things I'd do different
      1. use heavyduty/mor bracing to the back of the screen, even with the bracing that I used the screen still pinces about 5 mm in the middle (note however that this is over a height of 1280mm so relatively minor) and
      2. the screen material bows out towards the room in the centre (top to bottom) about 25mm due to the tension from each ends. I might need to look at more tension to the top and bottom and letting the edges go a bit on the left and right ends.
      3. I now need to adjust the A-lens again to try and fix up the top left corner
      4. the A-lens expansion ratio and the screen ratio are slightly different, on the finished product photo the top and bottom grid lines are right on the edge of the viewable area but the left and right sides still have about 50mm before the grid line hits the screen frame. Not much I can do about that except to overscan the image onto the frame top and bottom
      5. It takes a reasonalbe push to curve the screen frame, it doesn't do it under its own weight that is for sure.
      Anyway alls well to far, I might have a play around over the next couple of weeks and provide any updates.
      regards
      Michael
    • By tacky
      Hello All!
      Long time reader, seldom poster
      Looking to sell the following gear ASAP - make me an offer on anything. All located in Brisbane or Sunshine Coast, QLD. Everything boxed up and ready to go for postage or contact me for pick up.
      My Converter on Fleabay with all the details:
      http://www.ebay.com....984.m1423.l2649
      My processor on fleabay with all the details:
      MAIN item is my CRT Projector on fleabay:
      Runco DTV991 (NEC XG75) CRT Projector with HDMI input
      AMERICAN VOLTAGE 110V - AMERICAN VOLTAGE 110V - US VOLTAGE 110V
      Specialised Item - please only bid if you know what this is and how to use it, thank you.
      WORKING SET (see images in link below):
      Approx build date 1999/2000. Minimal wear on tubes. NEW PSU installed ~3yrs ago by me at time of purchase. Hours unknown probably ~2000hours put on since unit purchased 3yrs ago.
      Works well with HD 720p (60hz or 50hz) sources such as PS3, XBOX360, Popcorn Hour, FTA Digital TV STB, etc
      N.B. set is 110V and will require ~1000W step down transformer (not included)
      Obviously will require re-convergence once relocated.
      Purchase Includes:
      ceiling mount (heavy steel post and plate with some but not all bolts)
      serial control cable (for calibration with PC - useful!)
      backlit full function IR remote for set
      IR remote for moome HDMI card
      batteries for remotes
      PAYMENT:
      Contact me.
      I accept Paypal, Cash (only for pickup), and direct deposit
      POSTAGE:
      Available for pick up (preferred and cheapest option)
      Current location = QLD, Brisbane, 4122
      Item securely packaged to a pallet and ready for immediate dispatch if shipping required
      Dimensions = 120 x 78 x 48 cm x ~60-70kg
      Pallet delivery service required (most major couriers offer such a service)
      Specifications:
      http://www.curtpalme...pecs_Runco.shtm
      High resolution images of set taken 2 Jan 2012:
      http://members.iinet...d.com.au/CRTPJ/
      Thanks to one and all for considering my items for sale
      Regards,
      Tristan
    • By jakc
      I raised
      a post awhile back on Whirlpool, on getting some advice for buying a new projector.
      I was very close to ordering a
      BenQ W1100, but feel that I have not considered other projectors, and also a little worried that I am spending more than I need based on my requirements.
      So, this new post is just to try and spark some comments/advice into alternate models or perhaps confirm that the W1100 is a good choice for my needs.
      The other cheaper model I have just been considering, is the
      BenQ W1060. I think this makes more sense, but seen less talk of this one. I see OfficeWorks have it for $999 which seems good (Which is another Q, wheres a good place to get one?)
      My Needs...
      - Do not currently have a TV, and do not have Foxtel.
      - I DL typically 1-2 shows a day to watch in the evening on my 27' monitor.
      - I DL 2 movies a week usually watched at weekend,
      - I only watch DVDRips but will DL BluRayRips if a film.
      - Im 30, with no kids but watch all the above with my gf.
      - Also like the idea of having friends over to watch movies.
      - Would use either my a Asus 1201N netbook (ION graphics/HDMI output) or my girlfriends iMac. May consider a HTPC build in the future.
      - Not fussed about 3D or onboard sound, and will use my AudioEngine A5s for audio.
      - Budget wise 1400 is really the top end. Because of bulbs, prob not going to be looking at 2nd hand.
      - Bulb life scares me. I want something that lasts.
      - I may watch some TV on it, therefore an aerial in would be nice (but not essential)
      - Now the big one. I will mostly use it in my living room, but really like the idea of using it outdoors at night. I was thinking of having it on my window sill (will create a stand, but the projector remains indoors, window open) and then project out to a screen about 13-14ft away. This is still all under cover, and there is not too much lighting to interfere with picture.
      So with all that said, what should I be looking at?
      Was also looking at the
      W1200 and something a bit cheaper a with the MX511
      Are these along with the W1100 overkill? Ideally would be great to find a good model nearer the 1k mark, but one thats still bright and considered a HT-projector.
      Would really appreciate your advice. I am not a video-phile, but still want something that will look good and last. N
    • By Yacano
      In this section please post any comments, suggestions, solutions, issues you have with Benq Projectors. This brand has many models out there. Hopefully this topic will help with anything related to this Brand.
