christopher
New Epson 6700 question
Can anyone tell me if its ok if my Epson tw6700 doesn't leave the fan on when I turn it off. Only bought it and used it for first time tonight, watched it for an hour then turned off via remote. And it just turned off. fan and all. I panicked and turned it on again where the fan kicked in high for a minute before it showed a picture. turned off again with button on projector itself and it just powered off straight away again. I'm used to my Panasonic staying on high fan for a good minute after I turn it off. Not game to turn it on again now.
please help.
obama
my old Epson when I turn it off by remote,   the fan will keep running than it will stop by itself, make sure you don't turn off power or it will damage the PJ.. Once fan stops you can turn off power (power point).
i called epson and they assure me it is normal. I think it's strange.
No other epson owners can chime in? Is mine the only one that doesn't cool down after shutdown?
not having an epson but my 2 pjs fan stays on.. the benq w1070 for a what seems a long time and the old big viewsonic 8100 for what seems a short time... cant see how the fan would not stay on unless the unit is very efficient at cooling while the unit is being used.
Apparent they have a feature called instant off. First I've heard of it.
obama
obama
it should be fine...Hows the PJ performance are you happy with it? iv also just bought one, but wont open till I move in to my new home.
Great for the money. Very bright, whisper quiet, can't see any pixel structure. Blacks  ok for the money. Good amount of lens shift and zoom. Nothing can touch it till you spend nearly twice as much. So yes very happy.
obama
sweet.. cant wait to use mine. How big of a screen are you running and how far are you from the screen..
why I ask because im deciding between 110-120 inch screen from 4m away. will the projector perform well at that distance from your experience
it wont matter if you have entry.. mid (yours) or higher up level pj. at 4m the very minimum will be 120" and in reality/imo should be at least 130" (my 123" is 3m 1st row..4m 2nd row. the 2nd row is too far for immersion reasons )
Edited by hopefullguy
muriwai
Hi Clinton,130 scope screen is good for 3m seating !wouldnt go any smaller
obama
it wont be scope my options with my Epson 6700 are only 16;9 standard..so you think 130 will be fine?
can i siggest you sit at 4m distance and project onto the wall for 2weeks... trying different sizing 120/125/130... then if there is a chance you will move your furniture around in the future do it now to see how it will effect your viewing of those sized screens.. the screen can wait. be sure as trying to re sell a screen is a pain and you will lose too many dollars.
I'm sitting 4m from a 105 inch 16:9.. . 16:9 material looks awesome. scope looks I could use another 20 inches or so. Most of the time I'm happy but maybe wish for 120 especially on scope material. As far as the projector goes, sky is the limit, its very bright.
Edited by christopherjasmes
wheelz
I know my benq has an option in the menu for instant off or cool down.
Had it for a while now. Still turns off straight away which I have come to understand isn't a bad thing, but sometimes it takes forever to turn on. High fan for a good couple of minutes beforeit will power on. Can anyone confirm this is normal or why?
