Johnno2017
Leave it to the experts?
I have a pair of old speakers and I want to do a health check on the board. But, I know nothing about electronics.
Hope to get some help here.
Is finding fault and fixing things on this board simple to do, what tools I need and what I need to know...
Some photos of the inside.
It would be helpful to know what the speakers are. 2 way? 3 Way? Brand? Model? Are all the drivers functioning normally? What measurements have you performed to determine what, if any, problems exist? What does the manufacturer say about the issue? Under warranty?
Edited by Zaphod Beeblebrox
VanArn
Indeed, there is very little to go on to be in a position to offer meaningful advice.  A rough  interpretation of the xover network  of the crossover would be that it is a  bi-wired 18 dB /octave type, with an impedance correcting cct. added to the bass output connection ( the green  bi-polar capacitor in series with the // 5w resistors).
Thanks guys.
The makers are no longer around they were made in Australia by The Audio Group. It's a 2 way, focal tweeter and Seas driver. I have not done any measurements only by ear that the balance is not quiet right, abit too much high. I've done some looking around on the net and some says replacing the xovers can help to restore it.
gat474
They look like TAG's work with all that hot glue and Jaycar blue cable.
Nice drivers and no doubt well made boxes by Aranmar Acoustics. TAG are still around, John at Aranmar Acoustics may be able to help.
TAG speakers are generally pretty nice. Have you tried them on different equipment or someone else's system or someone else's ears. Maybe they just aren't for you?
gat474
There are things to pull back the tweeter output a little. You could try adding a resistor to the tweeter input before the crossover. I can't help with values but if you are close to Ascot Vale (ish) I could lend you some various values and even show you how to connect them. They are temporary and do not require any changes to the crossover, it's all done outside the box.
I'm not sure if trying other equipment would help. I thought about a new amp but  it could turn out to be a expensive testing method.
In testing these speakers performed amazing and engaging in a large room. But when I brought them home and positioned in a small room I find the balance isn't quite there. I still enjoy them and I'm trying to find out if there is anything I could do to make the speakers to reach its potential.
I may start with changing the green capacitor and see how that goes.
gat474
Just realised you're in Sydney.   Are you using the same stands as were used in the large room?  I used to think that stands wouldn't make much difference but recently found out with some Usher 520's that stands can make a difference.  On one set of stands the bottom end was missing, change the stands and bingo, more bottom end.   Might be worth looking at all of that too.
The suggestion that you listen to another pair of (known good) speakers in the same room, on your equipment is a good one. It may save you a great deal of heartache. If the green cap is what Van has suggested (impedance equalisation), then don't expect much difference.
I think they we on stands and placed atleast 3 metres apart (which is a luxury).
Now is placed on top of a cabinet. May give the booster stands a go.
VanArn
 Johnno2017. The Focal tweeters'  ( T120 ?) suspension could be breaking down and the roll surround on the SEAS ,if it is rubber,  can go hard. I would suggest that these items  will add to your rework list.
gat474
A cabinet could make a huge difference. Speakers sound crap on my garage bench but if I put them on stands they are much better. If I take the speakers inside using the same stands and equipment they sound much better again.
Also, make sure you have the speaker polarity (positive and negative) the same on each speaker. That's a rookie mistake I've fallen for more times that I care to count over a long time.  Out of phase will suck the bottom end away.
7 minutes ago, gat474 said:
Post some pics of the front of the woofers and tweeters.
Will put some more pictures up, the connections and condition of the drivers.
  Yep, and same position as well.
SS
Edited by Sub Sonic
Thank you all.
I got the balance now. Spot on about the rookie mistake.....
I do think the back is labelled incorrectly.
16 hours ago, gat474 said:
That's good news.    Happy with the sound now?
Very happy with it now.
I'm tempted to change the green capacitor.
Nigel
Caps wear out rather than become 'broke', new ones on a tweeter for example can clean up a "tizzy" treble and your 10yr old can learn how to solder as well.
In my humble opinion there are way too many crossover components there for a simple two-way speaker. One inductor to limit the upper frequency of the woofer, one capacitor to limit the lower frequency of the tweeter, and perhaps a resistor on the tweeter feed if it is too strident compared to the woofer/mid. If designers would take more time to match their drivers (compatability is a wonderful thing) , a lot less interference from crossovers could be achieved, and a better result overall.
P.S. use quality caps - good polypropylene caps should not age.
Edited by Spinnergeoff
extra thoughts
    • By Spinnergeoff
      Item: Quality Sat/Sub combo (note: I have other sat/sub combos at www.homeentertainment.com.au/saleswatch )
      Price: $249
      Item Condition: Used but good - Tantra 1 lack grilles but still look nice - actually nicer - without.
      Reason for selling: Clearing excess items
      Extra Info: Velodyne VX-10se Powered Subwoofer + Soundcraft Tantra 1 Speakers $249 (new rrp was around $1200 for this combination) - lovely sounding full-range speaker system. Can be used with most amplifiers, sub has both line level and speaker lead inputs, and the usual adjustments for phase, crossover, volume. The Tantra 1 are quite efficient and use very good drivers so this is way above your usual run-of-the-mill inexpensive sat/sub system. It's got some cred. The Tantras can be wall mounted as they're threaded at rear for mounting brackets and also have front reflex port.
    • By Spinnergeoff
      Item: A pair of speakers built by me (my main retirement hobby) using quality Coral 12" and 6" drivers plus a cameo appearance by a nice little paper cone twin magnet Pioneer tweeter.
      Price: $399
      Item Condition: good used condition
      Reason for selling: cost recovery and make space for next project. No profit in my sales.
      Payment Method: cash on pickup or delivery.
      Extra Info: These speakers are rich in sound with excellent detail through the midrange and treble. The 6" Coral broad-range mid/woofer (6A-25) are almost impossible to source any more. They'll run happily on most amplifiers so no need to invest in a mega amp to enjoy them, but they will show the benefit of a good amplifier. The midrange is running bipolar to give some rear reflection and add to soundstage depth. which the wide dispersion also helps. Dimensions approx. 92x36x37 (hwd). Crossover is minimalist to achieve speedy response. Impedance 7 ohms, efficiency around 90dB. Overall response approx. 45Hz - 16kHz. Finish is not cabinetmaker quality but presentable enough, and for the price they deliver an excellent result. Connections are three-way binding posts. Not biwirable, probably not necessary for this model. That's a mod that could be done, but will only make a difference if they are bi-amped as well. So for most users this will not be an issue.
      Pictures: apologies - I edited those photos and rotated then saved, but they have still come out sideways! Damn. Update - Fixed now!
    • By werdnafaz
      Hi guys,
      The Australian second hand market seems to be a little lack lustre imo unless I'm looking in the wrong areas but I'm honestly finding more interesting listings in the USA/Europe and some of the prices are ridiculously cheaper than Australia.
      Has anyone imported speakers from USA/Europe/Asia and what was your experience like?
      I am aware of import taxes etc and I understand that would also be an issue as well as cost for the shipping which could reach a high amount as well.
      I would love love to hear some ideas or stories or even best practice sharing and further more to that if you used a certain carrier to handle the full shipping expedition that you found to be excellent in thier delivery as it can be one thing finding a deal and another enduring I would receive the speakers in an acceptable manner and not destroyed.
      Also would there be any issies other than obviously power eg 110 volt vs 240 volt. For eg are the speakers set up differently over seas. I don't think this would be something but you never know.
      Regards
      Andrew.
    • By Spinnergeoff
      Item: Retro JVC amplifier JA-S44 (50w x 2) with VU meters and inbuilt SEA graphic instead of tone controls - yes, I know these things can be abused, but they are actually useful in correcting for room acoustics! The Yamaha T-460 tuner has that nice green glowing tuner scale. The speakers are my own build, using Foster SLE 8" drivers which have a fairly broad range, plus paper cone mid/treble and a Motorola supertweeter for a bit of extra sparkle.
      Price: $269
      Item Condition: used but very good
      Reason for selling: reducing clutter, making room for more speaker building
      Extra Info: As with all my speakers, these are a well-balanced and detailed presentation. The Foster SLE woofers are hard to get, and use a unique combination of rigid cone, double spider suspension, and a small air gap instead of a conventional roll-surround. I have kept a spare pair of these for possible future use! The amplifier has been serviced not long ago and is working well. The tuner does a great job too, while looking very cute. Nice system for beginner or student, or anyone really!
      My other ad here for speakers is: My build - Coral three-way floor standing speakers.
      (Other items I have for sale can be found at http://homeentertainment.com.au/saleswatch.html )
    • By jenno5
      Item: Bowers & Wilkins 803 D2 speakers
      Price: $8000
      Item Condition: Like new
      Reason for selling: Would like to try another speaker
      Extra Info: Fantastic speakers in like new condition with no marks. All original packaging supplied, would prefer local pick up due to the size and weight. Cherry finish
      http://www.soundstagehifi.com/index.php?option=com_content&view=article&id=176:bowers-a-wilkins-803-diamond-loudspeakers
      Also have a PS Audio Directstream for sale in another add on stereonet for $5500
