Citroen
Bluesound Vault 2 DISAPPEARED! :(
Citroen
I've happily had the Bluesound Vault 2 connected to my network  since I bought it months ago. But recently it doesn't appear on the network , so I can't play my files, or do any streaming.
Any ideas on how I can get it to connect and therefore play my files and stream my Tidal?
No wonder I prefer vinyl!
Sime
Also, Bluesound stuff does on very rare occasions , do this kind of thing.
I should note that you may need to go though several updates
Thats what I had to do on the Bluesound Node 1 - but a vault 2 may be easier ?
srms
My B+W A7 does this as well, so maybe not just limited to Bluesound devices!
Citroen
Thanks.
Just tried this twice but still no connection...:(
Have you reconfigured the wifi and room name ect
Edit
Also switch off and back on your modem / router and while you are at it check for a software update on the modem / router
Edited by Full Range
Citroen
You are speaking another language! :)
When  first got this all I did was power it up and entered some password and it has worked fine ever since.
Until now.
I'm going back to playing vinyl....
See you over on the Vinyl / Records spinning thread :thumb:
Citroen
This is so frigging frustrating! :emot-bang:
I just want to hit something right now...
Sime
if you can, plug it in via a network cable, and see if it pops up. if it does, then go back to wifi and cross your fingers.
I second that - as I think I had to do that at one time and it worked until all the updates went through the system
Then all worked perfectly
Sime
I've always used a network cable full time with bluesound stuff, my first gens wifi was flakey, so I got into the habit.
Citroen
Thanks for the tips everyone.
I turned everything off, including router and left it for a while.
Turned everything back on and yay its back, apart from needing to be  re-indexed. So far, so good :)
In the print world, we call that a Japanese reset!  :P
powerav
It's a funny thing, I don't want to get into vinyl because of all the mucking around with cleaning, stylus's etc but networking and digital is probably 20 times harder.
Citroen
11 hours ago, powerav said:
It's a modem/Router thing, you really need a smart hub network switch, ever since I this I have never had an issue with anything dropping off the network.
https://www.netgear.com/business/products/switches/smart/GS724TPv2.aspx
If you are spending big bucks on digital audio and streaming products then these are vital.
I've had it for about 6 months with not one drop out, until yesterday,  and this is when connected to the network wirelessly via the ethernet port.
I've no idea what a smart hub network switch is and hopefully I don't need one. :)
The fewer the boxes the better, which is why I got the Vault, in the first place, to replace a Squeezebox +laptop+ext hard drive+iFi USB power+LPS (and +/-DAC and headphone amp).
9 hours ago, Full Range said:
A good result -
Hope you don't abandon vinyl
Not likely!
I use the Vault mainly for checking out and discovering new music, or background music. 99% of my listening is vinyl.
Only 20!!!? ;)
Sime
Mine dropped out for 1/2 hour today, came back as usual.
JukKluk2
I just went to that website and read everything the overview had to say, but you know what? I have absolutely no idea of what's being said, not a clue. Would it kill them to explain in simple English what the product does and how that would be of benefit?
