scumbag
My Room acoustic measurements
2 hours ago, scumbag said:
That looks a lot better than mine!
Have you got the "before" waterfall by any chance?
No sorry, but before the room was made into a lounge it had a dirt floor and was a concrete box, still is a concrete box but treated :)
marten
At 40Hz wavelengths would be around 8 metres.
If the microphone moved (say) less than 1 centimetre, would that be enough to make a big impact at those frequencies?
The wave peak/trough interference effect distances would also be in the order of metres, so one would think you'd need to move the mic by something like a foot or so to have a big impact that low.
scumbag
On 2nd thoughts, the 8 measurements are sufficiently consistent to lead me to discount any issue of there being anomalies in them.
Jventer
@scumbag
I started with a makeshift tool for the microphone. Then went to the local music shop and bought a microphone stand, less than $30 and really worth the long term effort.
scumbag
7 minutes ago, Jventer said:
@scumbag
I have a mic stand and a reference mic'. I use them to design speakers amongst other things.
niss_man
I can vouch for the quality of speakers scumbag produces.
Sent from my C6903 using Tapatalk
marten
@scumbag
Was electronic EQ part of the treatment you applied between Before and After snaps?
Jventer
Sorry, I thought you said you had the mic in your hand.
scumbag
Only whilst doing Karaoke.
almikel
8 hours ago, scumbag said:
I kept the mic' as still as I could. I guess I might have at some point moved it a tiny amount so that would perhaps account for a small change.
Hi SB,
have just scanned the whole thread
when I do before and after measurements, a bump of the mike trashes the measurement - hard if you're moving treatment in/out of the room - the mike cannot move, or speakers - if you want to compare measurements.
That said, your measurements are very consistent - looks like the mike didn't move :thumb:
Your 1st RT60 graph has far too much change in the before/after for the amount of treatment applied (IMHO) - something funny happening there
Your waterfalls posted 30 July (Once upon a time there used to be numbering on posts @Marc) - show good damping from treatment above 100hz or so - as expected.
I'm assuming there's no sub involved here? The dip between  40 and 90 Hz may be improved with speaker positioning or perhaps adding a sub (or 2) - it won't be fixed by absorption. You could try some eq as a no cost option - just be careful of amp clipping and driver excursion - yes most recommend not attempting to fill dips using EQ, I say try it within the limits of speakers and amps - it can help...but make things worse elsewhere in the room - EQ is like that.
I'm a firm believer that treatment is the best "bang for buck" upgrade possible - especially when applied with measurements along the way.
IMO some more absorption focussing on the low end would help - perhaps cover the existing "bass traps" with a membrane (eg builders plastic) to reflect higher freq - but don't expect much effect < 100Hz
mike
scumbag
Welcome to drop in any time to listen to them fed by my Pass Labs and DirectStream Junior ;)
