brenden
Marantz CD12
13 posts in this topic
Hooked up the  beautiful Marantz CD12/DA12  up and guess what ?
   It's still got it .  Sounds superb.   The very best of the tda1541a , and was  reminded why this player is considered a  legend  still today.
  Here is a photo  of two legends in my view .
    Stax CA-X  pro  and  Marantz CD 12
6 people like this
And my super modified CD94 Mk2
   With very rare ( unobtainium ) copper foil PPS Audio  capacitors around the TDA1541A s1  single crown  chips  . This player will never be recreated .
1 person likes this
And clock with all copper foils including Jupiters and Silmic 2 Super Gold caps
3 people like this
The capacitors are PPS as in polyphenylene sulfide? What value are they Brendan?
Chris
Hi Brenden,
The CD12 pairing looks very nice, a Ken Kessler HiFi News favourite. Does the modded CD94 sound as good ...just curious?
Steve.
Edited by Steve M
Ones got 2 x single crowns, the other got 1 X double crown
MARANTZ CD-94 Mk II
2 x TDA1541A-S1 (Single Crown)
CDM-1
MARANTZ CD-12
It's a Transport
CDM-1
MARANTZ DA-12
TDA1541A-S1 (Single / Double Crown)
It's a DAC
Hi Steve M and George .
  Georgehifi is perfectly correct regarding the chips used in these machines . I have owned and modified Marantz cd94 mk1 and mk2  machines since I bought my first new mk2  in  around 1990.
  Only in the past year or so have I had the pleasure  of  owning  a CD12 /DA12 .
       My modified CD94 mk2 is in a different ball park to a stock one. and wasnt expecting  the CD12 to be any where near as good  to be honest .
     This particular  CD12  had issues from new , believe  it or not , so the previous  owners never really  heard what it is capable of . I was able to  rectify  those issues  and get it  up to  like new status  .
   Once fixed , it sounded glorious  and very close to my modded Cd94 mk2 .  To my surprise  the cd12 more than held its own in most areas    in some  areas even better . This really surprised me  having come so far with the modded machine . In some areas the modded machine  gets a slight nod . Dont ask me to pick a favourite.
  So  its important  to  realise  the chips used are only one consideration  to the sound quality  of a particular  machine .
  The power supplies  are critical .  For example the CD 12  Supplies use a total of four massive toroidal  transformers   and totally separate power supplies  for each section.
    The clocking arrangement  in the CD12 is also  superior using a dual clocking system  with 2 different frequencies .
   Then there are the decoupling  caps around the  tda1541 a .
  Almost every  commercial machine made used cheap polyester   caps around the tda1541 .These caps are critical to the sound quality of a CD player .The  DA12 uses custom made film foil  caps   which are vastly better than  usual .These are much larger and a lot more  expensive. There are lots of other refinements in the CD12 that are not cheap to incorporate  like extensive copper plated shielding  and  transformer outputs etc .
   The CD12 is the best stock player  I have heard  and currently   its a close call between  my pride and joy CD94 mk2   and the CD12 .
1 person likes this
Hi Unclekanus .Yes these are polyphenylene sulphide .They are not metallised  but superior   ofc  copper foil . PPS is very close to the quality of polypropylene  but much thinner . Much better than mylar .
  They are also non inductive .  The leads are copper and not soldered  but either crimped by the foil or  spot welded in come way .
    They are not made any more unfortunately as they are the only copper foil  caps  small enough to fit around the dacs on the cd 94
    mk2    and even then it was tight .
   These are 0.1uf   but there are a couple of rows that are  0.082 uf    which are close enough  as  I could not get any more  0.1uf
       I did score a bunch of smaller sizes  from a guy in Japan ,ideal for digital boards lke the decoder board on the 94 .
Edited by brenden
1 person likes this
Hi Brenden,
They sound like great caps for the job. And just a nice size also. I believe it's worth having the smaller value caps furthest away from the MSB pin on the dac chip. George would know about that for sure.
Did you try any of these little copper foils anywhere else in the digital section? Like on the digital input... .01uf or so?
Brenden, thanks for the long explanation of the differences between your CD12 and modded CD94. As with all good hifi, the differences are subtle and the players are more similar than not.
Steve.
1 person likes this
  Hi Unclekanus.
                             You are correct  about the sizing  of the caps toward the msb
   I did experiment  a bit  and did each row  separately  starting  with the msb .  The furthest from the msb affected more of the top end  .
   The msb and the next couple seemed to affect the whole range and those in the middle seemed more sensitive to the mid range.
    These  middle ones are critical to get right as vocal warmth can be swayed depending on cap size and quality .
   So I found I could get away with smaller sizes on at least the two rows furthest from the msb  (most significant bit )
   These caps are fabulous on the decoder board .I did one at a time replacing the metallised mylar  and every one made a difference .
   Most striking was the blacker back grounds and reduction in hash .Yo dont even know its there until its gone .
   A nice copper film polystyrene  on the tda1541a    usually the 680pf  or 470 pf also works a treat .
1 person likes this
Good to see some love still out there for the old Philips chip. It's definitely still my cup of tea.
I've gone up to 4.7uf on the msb, followed by a couple at 1uf and then down to .22/.1uf from there with great results.
The caps around the chip all play a part in the sound, that's for sure. The 15v supply pin decoupling cap especially.
Try a 22uf k73-16 there with the shortest leads you can manage.
Thanks Uncle .
        Its still a work in progress atm .  I have a huge array of  the best parts available but still keep an open mind . Will have a look at the k73
       I love the 1500v auricaps .I have Duelund vsf  on the outputs
    Big size  Elna audios where I can fit them .
  All these changes together make for a  very large degree of musical satisfaction.
   I also prefer  non oversampling .
   The trick is to build this around great gear to start with .
  The CDM1 transport  TDA1541A chips . So for me the best  start point   to do an all out mod  are the cd94 cd95 cd99 cd12 etc .
   If ever you want any small copper caps to try let me know.
  I have more parts than some shops lol .
1 person likes this
