KenTripp
Joe Rasmussen, Custom Analogue Audio, JLTi
8pm Wednesday 17th May, visitors welcome.
Willis Room, City of Whitehorse Offices
Maroondah Highway (Whitehorse Road), Nunawading
Melway Map 48 Ref G9
Contact: 9437 1249
This month the club is very privileged to have an audio enthusiast travel all the way from Sydney to present at the club. Joe Rasmussen is known among the DIY audio fraternity as the "Father of the Buffered Gainclone" His collaboration with the late Allen Wright, led him to develop several projects starting back in 1975 with a "hybrid tube amplifier" In 2001 their work saw them develop upgrade modules for the first generation Sony SACD players.
Joe will be presenting at the club his latest upgrade projects. The JLTi Oppo level 4.2+ACB, is a highly modified Oppo-105D fitted with no less than eight modules. Each having a specific task - Master Clock - DAC Clock - Terra Firma power supply - all designed and developed by Joe at Custom Analogue Audio. "Ultimate Digital playback deserves Ultimate Stability! This is about the importance of clocking CD players and digital playback, a new standard of performance. How to make digital sound more like good vinyl".
His collection of equipment that will fill the room with sound, will include two amplifiers, a prototype "Beyond Triode" amplifier - A New Type of Tube Amplifier, and a DIY 40 Watt "Transconductance Amplifier" This solid state unit will be brought along for a bit of fun. Designed to output 'current' it will be demonstrated with his Elsinore Mk6 speakers. Compatible with this amplifier they can be driven from any source impedance and hence does not rely on the 'damping factor' of the amplifier. The "Beyond Triode" amplifier encompasses thirty years of experience and developments rolled into one design. The prototype unit a Yaqin MC-100B, has been upgraded to give a great boost in the 'Permeability' of the output transformers, which then translates into an extreme level of resolution.
To round off the equipment list for the night, two versions of the JLTi Phono Stage will be presented, a single box unit, and the new Deluxe Phono Stage. The Deluxe version is a two-box unit with a 'beefed up' design in the gain and buffer stages plus a massive separate power supply with extreme filtering that reduces power supply noise.
What Joe Rasmussen has achieved by taking a good quality product, amp or CD player, and lifting its performance to more than just one level, but several, makes music sound just lovely - Just Listen To it.
Nick Karayanis
Program Co-ordinator
Ken Tripp
Wise and Wonderful Webmaster
Melbourne Audio Club, Inc.
http://www.melbourneaudioclub.org.au
Edited by KenTripp
KenTripp
20 hours ago, Whites said:
This should be a great meeting.
@KenTripp let us know how it goes.
It should be indeed. I'll keep you posted.
evil c
Any updates on this meeting?
Joe gave us a detailed intro on his design philosophy, refreshingly different to conventional audio rules and let his system do the talking.
Sounded incredibly detailed and dynamic, and his Elsinore speakers produced predigious bass far exceeding that expected for such a compact bass driver.
I, and many others were excited by what we heard and Joe was very much in demand at the end of his demonstration.
He does sell those speakers in a kit form with drivers etc. requiring sourcing of a cabinet build.
Sent from my SM-G900I using Tapatalk
Keith_W
I was seated next to Evil C in this meeting. When Joe said that "damping factor is a myth", I looked at Evil C with raised eyebrows. He said, "open your mind!!". I have to admit that Joe's explanation made a lot of sense. But damping factor is so entrenched in the hifi world that I have a problem changing my thinking. He's probably right though.
evil c
I have the benefit of ignorance compared to guys like you Keith, makes it easier to be more open minded .
One of the most important things I've learned all these years - how little we really know !
KenTripp
Damping factor is not so much a myth but more or less irrelevant for any speaker system with a passive crossover network.
Some pics from the night (not my pics)...
Edited by KenTripp
Damping factor is not irrelevant for the vast majority of loudspeakers available today. The amount of damping factor required varies considerably, but, with an 'easy' 8 Ohm speaker, a damping factor or around 20 is usually plenty adequate. It has always been possible to design a speaker that can be current driven, it's just that, since the year dot, every speaker made has been designed to be driven by a Voltage source. IE: A low output impedance.
The difficulty with using a speaker designed to be driven by a current source, is that it may perform sub-optimally with a Voltage source. Same deal with the amplifier. Since the vast majority of speakers are designed to be driven by Voltage sources, then most of those speakers will perform sub-optimally with a current source. ESLs would be one of the worst choices for a current source amplifier.
KenTripp
By irrelevant I meant the ever increasing values for quoted amplifier DF because the great equalizer is the series resistance of the sizable inductor in series with the bass driver, hence the passive reference. So it doesn't matter if the quoted DF is 80, 800 or even 8000 as the actual DF will in all cases be lucky to make double digits.
Well I still belive in dampening factor between amp and speakers but I also understand once it gets above 100 there is little change in effect. I felt that Joe's system (Melbourne Audio Club demo) was electrically under-damped but accusticly properly damped. That's just my impression of the sound.
I would personally like to thank Joe for going to such a huge effort for that demo night. He brought down a pile of gear, went to a lot of trouble and got us all thinking about well established dogmas. He certainly rattled the cages but like unlike Bond I'm stirred but not shaken.
KenTripp
It was a good night, one of the better ones we've had. The industry would be a lot better if there were more guys like Joe.
You have just opened a big ole can of worms. I have a great deal to say about this matter and will be doing so very soon. Stay tuned.
KenTripp
No worms. Just facts. Awaiting with bated breath for the great deal.
He is.
The "myth" part is around increased damping factor leading to generally increased performance....    increasing damping factor leads to the response of the speaker/amplifier combination being independent of the speaker impedance.....  and this might seem like increased performance, depending on the specific situation.
Edited by davewantsmoore
joz
Lucky you, everyone else had worked it out.
Must have been the last seat yea?
Martykt
Well it is the second closest seat to the sweet spot so in a way a smart move by @Keith_W...... :P
Who has done the test in reference to dampening factor with the same speaker and using similar spec amps but with different dampening factor?
Lots of people. Including me. Like many things in life, it really does depend greatly on the speaker. Try it yourself. Insert a 1 Ohm resistor in series with your speakers. With 8 Ohms speakers, that means your damping factor is 8. Now try the same thing with an 8.2 Ohm resistor. Now you have a damping factor of 1. With certain speakers, the effect is not huge, whilst with others, the difference can be very substantial. A bunch of VERY BIG generalisations follow:
* ESL speakers will show a falling HF response, with increasing damping factor.
* Those speakers with a very resistive impedance (Maggies, for instance) will show very little difference from the mids to the highs. Bass will be affected (flabby). Speakers with conjugate networks in the crossovers should fare better than those that do not.
* Sealed enclosures will be less affected than bass reflex.
Again, these are generalisations. They may not be true for all instances. That said, I will state again, that the vast majority of speakers are designed to operate from a Voltage source (aka: a damping factor of greater than 20 or so).
Yes.
Above a certain 'damping factor' the speaker will be driven the same.   As you lower DF the response of the speaker changes.    You'll get various results depending on the particular speaker....  which is part of the reason why amplifiers with a reasonably low output impedance (high damping factor) are the standard.
If the speaker driver/crossover is made to be immune to the change in response due to low damping factor....   or if the speaker is designed with the changed response as an integral part ....  then there's no problem, quite the opposite.
KenTripp
People using valve power amps must have a very limited range of speakers to choose from.
Nope. Not all valve amps possess very high output impedance figures. Earle Weston's beauties possess commendably low output impedance figures. It's all down to the output transformers and there's none better than Earle's. Don't forget: Most valve amps utilise a tapped output transformer, enabling the user to select a lower impedance tap, which means a lower output impedance. Check out this baby:
http://www.westonacoustics.com/service5.html
A damping factor of greater than 10, whilst not spectacular, is probably adequate for most loudspeakers. However, MOST importantly, that damping factor is specified from 20Hz ~ 20kHz. Very few solid state amp manufacturers cite such a figure, because it is likely they cannot offer such a damping factor at high frequencies. Impressive stuff.
Edited by Zaphod Beeblebrox
gemini07
So.
What was the actual sound like?
    • By KenTripp
      Avantgarde Acoustic Zero TA XD
      8pm Wednesday 19th July, visitors welcome.
      Contact: 9437 1249
      This month we welcome to the club a local importer of High End audio equipment Cameron Keating from Maxmedia, who will be presenting a selection of European Hi-Fi brands, one of which Avantgarde Acoustic from Germany, would be a very familiar name with horn speaker enthusiasts.
      Cameron will be demonstrating the newest model in the Avantgarde range, the Zero TA XD. This entry-level speaker encompasses Avantgarde's 25 years of know how in hybrid horn loudspeakers. Up until now, Avantgarde fans have had to choose between one of the company's bigger, more expensive hybrid horns. Standing just over a meter tall, this new three way model is described as a semiactive horn system. The objective was to accomplish the clarity and power of its 'bigger' brothers, in a significantly reduced enclosure.
      Employing Avantgarde's CDC technology, the midrange driver has no passive filter components in the signal path. This results in a sound characterized with an effortless clarity and explosive vitality. The 400 mm spherical midrange horn crosses over at 300hz to a DSP-controlled 10-band parametric subwoofer. This 12 inch long throw driver is powered by a 500Watt amplifier.
      Partnering the speakers for the night, will be the LAB 12 Mighty Power Amplifier. This single ended class A valve amp, will be driving the mids and tweeters with only 10 Watts. Matched to its pre-amp, the LAB 12 TRUE is a Passive Attenuator / Input Selector. The LAB 12 DAC 1 will be taking care of the digital to analogue duties, with classic non oversampling (Phillips TDA 1543) and a tube based output stage. Not forgetting a second DAC from iFi the Micro iDSD BL will be taking a turn. The font end source will be a music sever from INNUOS, the Zeneth Mk II.
      With a system sensitivity of 104 dB, the ZERO TA is 32 times the dynamic range of a conventional 87 dB box speaker. I think we're in for some fireworks for the night.
        Nick Karayanis
      Ken Tripp
    • By KenTripp
      The Camel Audio Action Project
      8pm Wednesday 21st June, visitors welcome.
      Contact: 9437 1249
      Once again the Annual General Meeting has come around for another year. It is always the intention to keep business dealings at the meeting to a minimum, with nominations for Committee positions and Music Convenors.
      After the club business, we will be entertained for the night by the guys from the Audio Action group. No, this isn't a cabaret act, but a group of MAC members who have been lead by Ron Newbound in developing a speaker project. Over the past twelve months, the group has been collaborating in designing and building a 'Camel', well that's what Ron calls it. The 'Camel' in question is actually a three way Transmission Line speaker, but not in the usual tall rectangular box shape.
      Well what do you expect when you get a dozen MAC members together to design a speaker?
      This unique looking speaker is based around a cylindrical enclosure that houses the transmission line, while the front baffle presents to the listener a 'surfboard shape' that seems to float off the floor. You could even say the selection of drivers is unconventional. The tweeter is an air motion transformer (AMT), while the mid and bass cones are made from aluminium.
      Ron will start the presentation with a short explanation on some of the technical issues with building such a speaker. How some of the challenges were resolved as well as why the group chose to develop this type of speaker.
      Then each member from the group will get to play a piece of music to the club. Ron assures me that the group will have a good selection of music that will demonstrate the best performance out of the speakers.
      Sounds like we will have an interesting and enjoyable night. Not to be missed.
        Nick Karayanis
      Ken Tripp
    • By Cafad
      Item:  One JLTI EL34 Integrated Amp
      Price: $900 (plus postage)
      Item Condition:  Excellent, looks almost new.  Fully functional as well.
      Reason for selling:  Tube amps have yet to convert me.
      Extra Info:  One of Joe Rasmussen's modified Yaqin amps.  Comes with original tubes, original bias screwdriver, original manual and the JLTI leaflet.  I don't have the original box (thanks cyclone Debbie) so will have to use much packaging if it comes to prepping for long distance postage.
      For more info check out the link below.
      http://www.customanalogue.com/jlti_el34.htm
    • By KenTripp
      Mark Dohmann of Audio Union
      8pm Wednesday 19th April, visitors welcome.
      Contact: 9437 1249
      Back in October 2013, the club was very privileged to have one of the most influential audio engineers of the analogue world present at the Melbourne Audio Club. He is Mark Dohmann and since then Mark has formed Audio Union.
      Another first at the MAC, will be a new addition to the Thrax portfolio of equipment. The LYRA loudspeaker will make their debut at the club partnered with a pair of HEROS 100W class A mono blocks and the matching DIONYSOS pre-amp. The Lyra is a two-way, three driver monitor sporting a vented enclosure that is made of aluminium plates, screwed together.
      The D'Appolito array on the front panel, incorporate two 6.5" woofers with magnesium membranes and copper phase plugs. The tweeter is a ring diaphragm compression driver crossed over at 1.5 kHz. Its shape was developed by Spherovox with specific directivity and frequency response.
        Nick Karayanis
      Ken Tripp
    • By KenTripp
      A Night with Hugh Dean, Aspen Amplifier Designer
      8pm Wednesday 15th March, visitors welcome.
      Contact: 9437 1249
      The name Hugh Dean is synonymous with the Aspen amplifier range. His kit form amplifiers have won many hearts among audio enthusiasts who appreciate a very high standard of sound.
      The Maya 200 and the SAKSA 85 amplifiers are a culmination of over twenty years innovative design, starting in 1974 with the Glass Harmony. The Maya was conceived in 2015 with a topology breakthrough, which Hugh will attest has brought huge improvements in speed, bandwidth and clarity. This 200W per channel amplifier comprises four discrete stages: Input stage including a feedback node, Voltage Amp stage, Driver stage, and the Output stage which uses a pair of very large 480 watt MOSFETS.
      Hugh's primary aim in his amplifier design is very low odd order harmonics. The MAYA avoids phase issues with extremely linear first and second stages. With very low THD, less than 0.025% into 200W and very low noise, the Aspen amplifiers have none of that solid state glare.
      The amplifiers can be bought as a DIY build from a pair of tested and assembled PCB modules, starting at $930 plus GST for the SAKSA 85, and $2200 plus GST for the MAYA 200. Both units can now also be purchased with purpose built full enclosures.
      An OPPO 105 multi-disc player will be playing the music, while a pair of classic KEF 105/3s will entertain us with their sound. The 105/3 was the first Reference Series Loudspeaker from KEF to incorporate Uni-Q technology. This four way floor-standing speaker embodies several advanced and unconventional design features for its time. Its bass section drivers are mounted within the cabinet in a double coupled-cavity configuration. The combined output of the two woofers is radiated through a front mounted 6" inch diameter port. The D'Appolito array on the front panel is shared with a pair of midrange drivers and a KEF Uni-Q driver, with a concentric 6-1/2" inch cone and a 1" inch tweeter.
      Midrange bloom, solid state glare, lifeless sound? None of that with Aspen Amplifiers.
        Nick Karayanis
      Ken Tripp
