Perth.hifi
Making muy own acoustic panels
120 posts in this topic
On 5/21/2017 at 2:34 AM, almikel said:
hi Matt,
I'm constantly in awe of your motivation to keep building stuff !!...
...so apologies for being picky, but those panels won't provide diffusion - even with the pegboard involved.
Mike
Opps sorry my bad brain fade
Absorbtion and design targeted to do so
My intention is same as Mike's
I have a smaller concrete (wall and floor) lounge with some framed treatment  already working so taming  mid range and combing  is on going.
Get the bats and stand/position them up in the room for some listening sessions
XD75 works in my lounge ok and they are nice as a raw product except until you have to cut one down to size
I think the pair of panels I am building today are Martini 75mm HD, in white.
Coming along fairly well
Plenty of air driven staples to go
edit and a few internal slats to stiffen up the frame.
Had the pair of bats in the room for a few weeks and they work in my target range for first reflection diffusers well enough to build them into upholstered panels
Sweet... I've just got all my gear today to build the exact sane panels, with martini 75hd, being ordered tomorrow...
What fabric are you using, i still need to purchase fabric.?
Sent from my SM-G935F using Tapatalk
1 person likes this
Using an upholstery weave with a felt backing, can breath through it but is is heavy.
Aim is to reflect HF and absorb mid range. Have had good success with this method of upholstery covering bats of a few types improving focus of the sound generally wherever placed to effect in a small room
1 person likes this
If I use that that name, will the fabric store know?
If using speaker cloth, will the panel absirb too much HF, that's my current concern?
Going to use on the back walls,
Going to use on the ceiling,
And
Going to use on the front sides as front back behind speakers...
Then the next stage is ill need to make some diffusers for rear sides.
Yes felt backed upholstery, wool or cotton or anything
I get it at Spotlight https://www.spotlightstores.com/search?q=upholstery+material%3Arelevance
If using speaker cloth which is very light weight and transparent to sound (mostly) would work for higher frequencies and expose the bat to full range (edit without an outer mass loaded layer)
Just experimenting at the moment with these materials which seem measurably effective
Edited by 125dBmonster
Hi Gi,
you seem to ask the same questions over and over again with good answers provided in between which you don't appear to read/accept
If you make these panels they will not absorb any frequencies much below around 500Hz if placed directly on a wall - I call that too much HF absorption and no LF absorption
Speaker cloth lets all frequencies through - it will depend on where you place the panels as to whether too much HF is absorbed - no LF will be absorbed with these panels if directly on a wall wherever you place them.
Great idea, and will help - but I suggest getting the bass under control first
I'm not sure what this means?
None of the treatment you've discussed targets bass - but this is where you should start...
Apologies if I sound like a broken record - I'm giving up after this post.
All the rooms I've measured benefit from absorption between 100-300Hz - this is not achieved with thin panels.
@125dBmonster has loads of treatment already managing bass - the panels he's making are icing on the cake - not the start of the process.
Feel free to ignore my advice - it's the interweb after all
Mike
1 person likes this
Hi Gi,
[mention=149865]125dBmonster[/mention] has loads of treatment already managing bass - the panels he's making are icing on the cake - not the start of the process.
Mike
All good.
For us novices, sometimes it not clear... we all learn in different ways buddie...
And
Try them out with no covering .....  and it is a really bad idea to decide on where you will use them and how many, before you do this.
1 person likes this
Cheers . Will do.
Worse case ill build them, then sell em. Haha
11 minutes ago, Perth.hifi said:
All good.
Cheers Gi,
I get that, and on an interweb forum you get bombarded with different opinions and who knows what is good advice vs bad.
38 minutes ago, Perth.hifi said:
Cheers . Will do.
I'm a lazy DIYer - I hate building something that doesn't do what I want it to do.
I know we're on the interweb, but trust me, building any number of thin panels will do SFA if the bass in your room isn't under control first - you're just mucking around the edges with an elephant in the room.
Do yourself a favour and reach out to some Perth members to run a measurement of your room currently and post the reverb times.
Ask them to give you the MDAT file (assuming they use REW), and get REW yourself (it's free).
I'd be gobsmacked if your room couldn't do with some treatment focussing on <250Hz - deal with this first before building thin panels.
IME people apply treatment because "rooms need treatment", without understanding what treatment is required.
Don't get me wrong - proper treatment is by far the best possible "bang for buck" improvement to the room sound possible - but thin panels won't achieve this, and just chop out treble.
Mike
1 person likes this
I just built two frames and fitted Some 25mm 48kg/m3 autex batts i had lying around....put two frames on both side walls, would I be crazy if I said I already notice a difference....
1 person likes this
Where is the best place to buy the pine timber to make the frames?
Any timber trade shop sells dressed pine or hard wood
I just went to bunnings. I was going to get Mdf which is much cheaper. But decided on pine, much lighter...
FWIW, the bull-nose skirting/moulding gives a nice rounded edge to the panels, if you want a softer look
151102%20Back%20wall%20wip_zpsxelyta5e.j
5 people like this
Mike
I might be able to lend him a lappy with REW and microphone. Not sure my Mic is behaving at the very top end though.
Here is my MDat I did last night.
Any suggestions on the areas I might target myself?
http://www48.zippyshare.com/v/9Ryu3raw/file.html
Edited by rocky500
1 person likes this
Hi all.
Ok. Materials received. Got a query with the HD batts. One side is more form, than the order, does it make any difference which side faces the sound?
1 hour ago, Perth.hifi said:
Hi all.
The firmer surface I might think could reflect a bit more of the very high end frequency's slightly. Maybe. :)
