Magenta
FS: Lenehan Audio ML2 Reference Passive Loudspeakers
1 post in this topic
Item: Lenehan Audio ML2 Reference Passive Loudspeakers
Price: $8995 (plus shipping, contact us for a quote). $1500 RRP Stands are included for free, made by Lenehan Audio specifically for the ML2 loudspeakers
Item Condition: Ex-Demo (Used once for demonstration at trade show), Excellent condition
Payment Method: Credit Card, PayPal, Direct Deposit
Cabinet Composite 18 to 36mm HDF laminated to 4mm sprung steel plate. Plus additional 4mm steel plate composite baffle.
Differential Cancellation bracing utilising 25mm hardwood dowel, 13mm steel rod and 18mm Birch Plywood.
Crossover construction: Full hardwire hand build, all joints are high Pressure low contact area cold weld sealed with Teflon amalgamated wrap.
12awg aircored inductors, low tension handwound double stabilised.
Duelund VSF copper foil capacitors in low and high pass crossover filters.
Duelund Carbon Phenolic 15 watt resistors throughout.
Proprietary integration of enclosure substrate steel plate with Crossover network groundplanes.
Tweeter 1 inch chambered textile dome
Mid-bass driver 6.5 inch Nomex Diaphram
Wiring Handmade 25mm and 13mm Copper Ribbon with proprietary dialectric
Input connection Eichmann cablepods
Frequency Response 35 – 25Khz +/- 1.5db (in room)
Sensitivity 86.5dB @ 2.83V/m
Impedance 8 ohms nominal
Reccomended amplifier wattage 20 – 700W
Cabinet dimensions (HxWxD) 420 x 215 x 400mm (16.5 x 8.4 x 15.7?)
Weight (1 speaker) 27kg (60 lbs)
Each pair of ML2 Reference are stringently tested, run in for 200 Hrs on music signal, then hand tuned and supplied with their own frequency, phase and impedance plots.
The ML2 is the next generation of highend two way monitors from Lenehan Audio. Designed for absolute no compromise music systems.
Construction is handbuilt and meticulous in every sense of the word. The composite enclosure panels are first handbuilt piece by piece starting with the 36mm HDF 4mm steel plate composite baffle. After all composite panels are individually constructed the enclosure is assembled using probably the worlds strongest epoxy adhesive.
Steel rod, 25mm hardwood dowel and Birch Ply differential bracing are incorporated to produce an enclosure with phenomenally low energy storage.
A single ML2 enclosure takes 6 hours of hand sanding before being painted. The finished Loudspeaker looks like it has been machined from a solid billet.
In rooms of smaller to average size, ie 50cubic mtrs 1700CuFt to 120cubic mtrs an ML2 will produce authoritive bass down to 35hz and produce resolution smoothness and speed akin to the very best full range electrostatic transducers.
When mounted to it’s own dedicated stand the ML2 will weigh approximately 65kg’s (143 lbs) each.
20170327_101643.thumb.jpg.0be0dc2cfecf403eecb4877ad6d3a042.jpg20170327_101502.thumb.jpg.446befe6334728659ce0b98ed4030866.jpg20170327_101600.thumb.jpg.f2d8bd5dd67a7e28d2a0f78957103666.jpg20170327_101713.thumb.jpg.010f0103f7c423537382550a8bdbfaa8.jpg20170327_101741.thumb.jpg.93146726631a3ce8638095d0a9f3446a.jpg
Edited by Magenta
2 people like this
