Aussieamps
Holton Zero Five Zero Introductory Offer!
43 posts in this topic
I have available one Holton NX050 stereo power amplifier for sale at an introductory price $1090.00AUD Normal Retail price is $1599.00AUD
Email: [email protected] for details or PM for more details.
  • Power output: 2 x 50 watts/8 Ohms and 80 watts/4 Ohms
  • Class A/B
  • 2 Ohm permissible for short periods
  • XLR balanced inputs with the option of RCA inputs.
  • Great sounding circuit topology that Holton amplifiers are known for.
  • 80,000uf of DC supply filtering in the standard model
  • Up-gradable to higher performance 100 watt model.
  • Bridgeable into a high power mono block amplifier 160 watts/8 Ohms
  • On board AC power controller with Inrush current limiting soft start.
  • Lightning fast loudspeaker protection.
  • Super quiet turn on and turn off.
  • 12 volt trigger remote power on/off option.
  • Precision full aluminum chassis with CNC milled AL front panel.
1 person likes this
Beautiful craftsmanship and a bargain! I have a larger Holton kit built amp that cost about the same and absolutely love it.
This amp would be a match made in heaven driving KEF LS50's in a normal sized listening room.
Edited by robmid
3 people like this
I heard this last week sounding great. It's so quiet it give me a fright when the music started. The finish is very high quality. It's a bargain at this price. Apparently it paired very well with my wyred 4 sound stp se preamp that was in Anthony's workshop for a checkup.
2 people like this
Any chance of a pic under the hood?
Hi Simon
Here you go!
I hope this helps you?
Cheers Anthony
Holton Audio
@Aussieamps wow, if I was in tassie, I'd def come and try that, especially at the price point.
There is only one available at this price, why not just buy it!
1 person likes this
Simply because I'll never ever buy before I try.
I've heard the prototype of this mate. It would be a nice match for the sexy little KEFs.
1 person likes this
@Aussieamps
Looks great. Do you do a pre and/or an integrated also?
This is highly evolved advanced power amplifier cutting edge stuff, with more than 25 years of power amplifier design put in by a pro amp builder that is normally involved in building mega monster amps for the Audiophiles of Europe. I personally wouldn't underestimate the hifi character of such a beautiful well presented piece from the Holton Foundry where this was struck
The amp is built of milled aluminium plate the thinnest is 3 mm for top and bottom covers, billet mass loaded feet
The center mezzanine the 7mm front and 5mm back acts like a mass damping heat sinking structure to eliminate physical noise from the transformer and keep operating temperature low
It has on board speaker protection and soft start that is processor controlled with solid state relays at the speaker outputs to protect those very expensive drivers and dividing networks
It has 80 000 uf of capacitors on board which is normally reserved for amps 3 times it's size
Australian Made Harbuch 225va Transformer which is engineered to run at 100% of its nominal rating  100% surge ability
It does run a pair of Martin Logan CLS's in an addictive way meaning if dinner is on the table and you want to finish the track, you will leave the dinner a min to finish the track, inviting and transfixing detail, soundstage and 3D image.
It sounds warm and timbred on the ML's like a very good 300B tube amp.
The circuit board quality is normally reserved for only the World's best, 2 ounce copper through plated with gold and has SMD and through hole components of exceptionally high grade and accuracy, the best one can get actually
It's designed for a lifetime of enjoyment and ultimate reliability on any speaker system, for me personally a keeper as I have built 2 and have 2 more to do, which will replace some monster amps on a highly efficient PSE144, 4 way stereo rig that has been under development for a year or so. The thing is, they are just, better, quieter on 107dB horns and desirable after a taste
The amp has the most minimal noise floor, no physical transformer hum and has been well vetted by it's maker and myself as a quality piece of loved hifi kit in a 300 x 200 x 100mm package.
THere is plenty more I can say about this Holton 050 Rev 1.5, 50w x 2, as in it can be upgraded easily to 100w x 2 and already has an add on update for the driver stage  the Maker has been playing about with
BARGAIN, cost me more to actually have the parts made/purchase, even the transformer is small batch custom and not available off the shelf
GLWS Anthony
44 minutes ago, rantan said:
@Aussieamps
Just to help out, there is almost literally no more room in the amp for "integration stage" or quality pre amplifier to suit the myriad of cartridge loadings,
its a power amp and the final stage from your other quality seperate compontery
Fair enough. I do get it that space maybe at a premium, but finding a synergy with a pre amp is time consuming and not always successful
2 people like this
There is only one way to find out :)
Indeed. The thing is, I have zero interest in trying to borrow and audition a dozen suitable pre amps that may work well with it:)
Edited by rantan
1 person likes this
Hi Rantan
Feel free to ask all the questions you want:)
@Aussieamps
I will just wait for a special on a - HPA-NXA50L R2 Pure Class-A
Hi Fullrange
I can do a special on the Class A modules for you now if you want?
Edited by Aussieamps
1 person likes this
Lovely looking bit of kit.
I had a yarn and a quiet beer last year with Anthony in the lounge/bar at Marc's show and he had his big amps on display and didn't want to take them back to Tassie and offered them at a  really keen price. And yes he was tired and worn out at the time. If I could of knocked a 0 off them I'd of grabbed them:love
But alas still way out of my league but I think Marc has them now in his system so perhaps they never went back over Bass Strait.
@Aussieamps  Anthony, what are it's dimensions and weight?
6 minutes ago, Aussieamps said:
Hi Fullrange
We can discuss after Easter
While everyone is on holiday - it's the opposite for me
FR
@Aussieamps
I have a spare integrated that I want to use as a pre amp. It has pre out facility so with your Zero Five Zero , would this be a straightforward input to your power amp?
This could make for a nice combination if so:)
1 person likes this
Hi Rantan
The 050 amp can be configured for balanced and RCA inputs so it would match nicely with your existing Preamp outputs.:)
1 minute ago, Aussieamps said:
Hi Rantan
Cheers for that.
A couple of other things if I may. What is involved in the upgrade to the higher performance amp and what would be the approximate cost?
Thanks.
It a fairly straightforward up grade requires a larger power transformer and higher supply rails.
the higher power version is additional $300.00
1 person likes this
    • By dralj
      Item: Parasound Halo A21 Power Amplifier 3.5 Years Old
      Price: $2500
      Item Condition: Excellent
      Reason for selling: Not required , system active
      Payment Method: Pickup - Cash, Paypal, COD, EFT
      Extra Info: I  purchased this wonderful amplifier to drive some Lenehan ML2 References which I have now sold. I am just using one active system now so it is surplus to my requirements. Purchased brand new from Sunnybank Hi Fi in October 2013. They retail for $4995 from the same store.
      http://sunnybankhifi.com.au/catalog/product_info.php?manufacturers_id=59&products_id=1268
      Circuitry designed by legendary John Curl THX Ultra2 certified High bias Class A/AB operation 250W per channel @ 8ohm Balanced inputs with discrete circuits and XLR connectors Direct Coupled - no capacitors or inductors in signal path Complementary MOSFET driver stage and JFET input stage 16 beta-matched 15 amp, 60 MHz bipolar output transistors 1.2 kVA encapsulated toroid power transformer with independent secondary windings for each channel 100,000 µF power supply filter capacitance DC Servo and relay protection circuits AC present, channel status, high temperature indicators Heavy-duty 24k gold-plated 5-way speaker terminals Gold-plated RCA input jacks; ground lift switch Auto turn-on by 12v trigger or audio signal, 12v trigger out 4u Chassis, carry handles, rack mounting adapter included
    • By Aussieamps
      A month or so ago I purchased a fully built Holton Five Zero Zero power amplifier, and I feel compelled to share my thoughts on it. For reference, it replaced another relatively high power, high current amplifier of similar value, albeit an integrated with a passive pre-amp stage.
      First up, it looks stunning! The finishing quality is impeccable, and even my wife, who is normally a bit ho-hum with HiFi gear, commented on how much she liked the look. It's also got some serious weight to it, partly due to the solid case, thick machined fascia, and large heat sinks, but also no doubt thanks to the huge transformer and capacitor banks; no scrimping on the important stuff here!
      I was very happy with my previous amplifier, but in all honesty I can say the Holton has taken the sound of my setup to another, altogether superior level. My previous amp was renowned for having good bottom end, but the impact of both drums and double/electric bass with the Holton is just phenomenal! Everyone who's heard it has remarked that it sounds like there's actually a drum kit in my lounge room! There's a track I'm infinitely familiar with where the bass guitarist slides between notes; with this amplifier I can not only hear the changing pitch, but actually pinpoint the moments when the bassists fingers slide over the frets. I can clearly discern whether they're playing with a pick or with fingers, and sometimes even how close to the bridge they're playing! Ultra low bass punches you in the face and then "blooms" outwards like an explosion from the impact zone; pretty spooky stuff!
      Mid-range is also incredibly detailed and precise; there are subtle background "noises" which have suddenly turned into easily recognizable instruments. Guitars, woodwind, whispered vocals, suddenly revealed in crystal clarity despite being many layers back in the mix. Everyone who's heard the amp has also commented on how "black" the background is; one friend said "wow, now I can actually hear the notes that they're not playing". Instrument separation is superb, and you can easily follow each one in isolation, or simply tune into the music as a whole, and then again tune into another single melody or rhythm line, just like you would with a live performance. There's a naturalness to vocals that really needs to be heard to be believed, and a beautiful, expansive sense of air and space around each of the instruments; you can easily picture the size of the recording studio or venue. If you listen closely, the sound of a piano can be heard firstly as finger on keys, then keys hitting felt, then hammers hitting strings,then the body of the piano resonating with the strings, and then that resonance reverberating through the room. Imaging is pinpoint-sharp and clearly defined; when people speak of holographic imaging, this is it!! The image is higher, wider, and deeper than it was before, and the only limitation is my room and the placement of my speakers.
      Treble is clear, defined, and ringing without being harsh or scratchy; tiny triangles, the sound of a cymbal struck on the bell or near the edge, the crack of a rimshot, all rendered in an utterly lifelike way.
      On more than one occasion it's sent shivers down my spine or brought tears to my eyes.
      And to top it all off Anthony was extremely personable, easy to speak to, and was happy to help out with all of my many queries; the sort of service you only get from someone who is passionate about what they do, and does it exceptionally well.
      If you are looking for a power amplifier to build your dream 2-channel system, I cannot recommend this amp highly enough; in my opinion it'll absolutely blow the doors off amps worth many, many thousands of dollars more. Anthony, I have three words for you; thank you, thank you, thank you!
      Steve H
      NSW, Australia
    • By QPR_FC
      Item: Perreaux PMF1150B
      Price: $300 ono
      Reason for selling: Moving O/S
      Extra Info: My former front speaker driver but then relegated to driving my rear B&W 705. Handled my front B&W 805 (also for sale) with ease. Great condition. Refurbished by the legendary Bill Crampton in Canberra who builds his own amps but for those whom cannot afford $7500+ he highly recommends a second-hand Perreaux which he refurbs and mods to sound spectacular from $600 upto $1800 (see my Perreaux 6200B for sale).
      Perreaux PMF1150B.pdf
    • By Aussieamps
      Here is some preliminary photos of one of the latest dual mono block power amplifiers to be produced by Holton Audio.
      The current assembly of these amplifiers is been carried out in Basel, Switzerland
      This particular unit is one of 4 power amplifiers that will be delivered to a customer in Switzerland in the next couple of weeks.
      The blue covering on the main toroidal power transformer is the protective plastic which will be removed once final assembly has been completed.
      I will post more photos of the fully completed amplifier when they become available.
    • By keyboardman_uk
      Item:  Cyrus X power (SILVER) power amplifier
      Price: $850 for cash - or will consider trade or swap for one of those nice Creek power amps (Destiny or Evo) or an Evo 5330se integrated.....
      Item Condition: Mint, nothing to declare, looks new except for the box.
      Reason for selling: This is the second one that I have owned, the first one sold after about 5 minutes and I felt I hadn't had enough time with it.  I love Cyrus and the amazing things they do in little boxes putting out plenty of power. A very revealing amp with bags of clarity and image, not to mention incredible dynamics. They pair superbly with darker sounding speakers like Sonus Faber Venere, Vienna Acoustics and Spendor, Dyn's of course.....Okay, so I discovered an old Creek and fell in love and that's the real reason...there we go.
      Payment Method: Pickup or will post anywhere in Australia - Cash or Bank transfer
      Extra Info: It's in perfect condition, came from a  good home (Makka on here). Comes with power cable, BFA plugs, MC bus cable, original box. (Box in good condition too, will double box for shipping). Had a very easy life in smoke free pet free home.
      Shipping cost would be approx $30 for Aus post (add $10 for insurance) , $40 for TNT express.
