o2so
Treatment of non dedicated room with big window
15 posts in this topic
Hi guys,
I am thinking of treating my room. Now, this poses at least two problems:
1. I do not have a dedicated room, this is my living room so it has to look pretty otherwise you know what wife will do (#divorce)
2. My living room/kitchen is my only option and acoustically has possibly all the problems in the world (see photo). Moving furniture around is NOT an option. Big window as side wall (as big as the whole wall), which at least does not vibrate as it is pretty heavy. Floor Boards with rug. Low gyp-rock ceiling. Massive wall-mounted TV behind speakers. Heavily Asymmetrical.
I did not do any measurements and if possible I'd rather avoid doing so. I am after some advice for a first-pass acoustic treatment to get rid of echo which I can hear when I clap my hands and excessive reflections which turn music into a bit of a shouting blob at high volumes.
I saw this and thought it looks pretty enough:
https://www.turramusic.com.au/pages/CatalogueItem.aspx?CIID=5067
I could treat front wall (side of TV behind speakers) and back wall, plus keep one/two large panels under the sofa and lean it/these against the window to cover the point of first reflection when I do critical listening. If strictly necessary, I could even put a couple on the ceiling.
I would not use any bass traps/corners because they are ugly and would never be approved. I would try and fix the excessive reflection first (resulting in glare, messed up sounds at higher volumes), then maybe I could throw in a DRC to control bass modes digitally.
My question is what do you think? Worth the cash investment? Would you suggest a different type of absorbing/diffusing panels?
Oh, I do have planar speakers (which I slide off the wall for critical listening) and a pair of bookshelves (just to make things easier).
Any word of advice that are not "buy a new house" or "move to headphones" or "divorce from your wife" would be greatly appreciated.
Please support our sponsors by clicking on their banners:
Looks like you're hoping that throwing some money at the problem will make it go away....
Plenty of constraints in your request! If it was my living room, I would consider one small furniture rearrangement and look at my options after that. I'm talking about moving the 2-seater that stands in the middle of the room, to the window side and that way shifting your setup away from the window and more into the middle of the room. The 2-seater would naturally act as the first reflection absorber, somewhat easing the challenge.
I realise this may require mounting the tv in a different spot, but you could give it a try and make the change only if it works.
From what can see that window is one of your major culprits.
Drapes!
well it's one of your first reflection points and all that glass is a doosey!
then where  you are sitting, you have nothing but more reflective surfaces directly behind your  head.
Would suggest something there.
But of course there is the ceiling also.
like you said it's your living space, perhaps tackle one thing at a time.
Start where you think you can get away with it.
1 person likes this
I am playing around with these things at the moment and have similar issues that I cannot really move furniture and don't wish to invest in something that may not work.
I would start with the window, front and back wall.  If window coverings is a possibility. Use a temporary method e.g. tape/ suction cup hooks/whatever and cover the windows with curtains/doona cover/doona etc. See if that helps.  For the front and back walls. There are certain acoustic treatments that are nice looking that can be put on the walls or you can buy stuff at Bunnings etc. & cover it with nice looking material, which may be cheaper.
Your solution of having extra under the couches to be taken out is a good solution.
AFAIU you are making the room less live, which means absorption. You could try the product you are referring to, but I would research a bit more and shop around. Plenty of info here on SNA
2 people like this
We grapled with this in our last home. If we'd stayed I would have covered the entire wall behind the TV in diy 50mm panels in a mutually agreeable fabric (rim trilogy one).
In cases where you have all hard surfaces and the echo is close to unbearable, imho this approach is safe and considered. It won't do any damage to the sound and will provide a massive increase in Sabine count....which will fix most of the annoyance.
Behind the couch would help too. But I'd start with the big wall
DIY panels made like these on mass look great imo
151102%20Back%20wall%20wip_zpsxelyta5e.j
Edited by Peter the Greek
5 people like this
I would put the speakers at the window end and sit on the other 2-seater.  Leave the equipment stand where it is.    No furniture to be moved and no treatment required, perhaps.
Benefits would be that the rear wave from the speakers would bounce off a consistent and symmetric front wall (even if it is glass) and the direct wave would disappear past your head into the void of the kitchen.  I have never tried it, but Maggies can go very close to the side walls because there is a null at 90degrees so the side walls don't matter all that much.
2 people like this
Precisely. Thanks but cannot put anything in front of window which is in fact that also sliding door to access balcony.
Sent from my SM-G935F using Tapatalk
Thanks but have no time or skills to do a good DIY job
Good idea but cannot put things in front of window because I would block access to balcony
Filippo, chat to Wavetrain, one of our SNA sponsors. They'll give you some basic no-obligation advice and opinion of costs and go from there.
They were a great help to me some years back before they joined the crew here.
2 people like this
Getting a nice clean look then will be either impossible, or very expensive. Another option is Acoustic Art Panels (conveniently I have some for sale) or speak with Acoustic Vision...but in my experience with rooms like yours, you need a whole heap and a few pictures hung here and there wont have a enough of an impact IMO.
OR ty to find someone that does a 600x600 panel and buy a heap of them. Surround your TV and the wall behind the sofa.
1 person likes this
I certainly will. Where do I find the contact details?
You can still access the balcony through drapes fitted to a rod across the top of the doors.Spotlight are the kings of that sort of stuff.A cheap and easy fix in my opinion, and they have a large range to choose from. Go on take the little lady curtain shopping.
1 person likes this
    • By Primare Knob
      I am planning for an HT room and would like to go Atmos/DTS-X. It is more the restricted Atmos setup with the ceiling speakers that is making my life difficult. I have an exposed ceiling with the roof studs starting at 220cm and the ceiling at 250cm.
      In the picture, the black cubes are the 7 channel setup, (I know, no center or sub in the picture), the orange cube are Atmos 35 degree angle from LS, and the green are Atmos 45 degree angle from LS speakers. The six grey cubes are "chairs" and the blue box in the back of the room is a pantry that I cannot move, I might build a cabinet in the other corner in the back to mirror it.
      I was thinking for the LS and RS to go with bi-pole speakers, to suit the back row. For the LSB and RSB I will probably go with mono pole speakers due to the pantry (and possible cabinet)
      For the ceiling speakers I was thinking to go with box speakers angled toward the LS. These speakers within the Atmos preferred dimension will sit smack bang against the exposed roof stud. I could build a lowered floating ceiling to mount the speakers in, but they exposed roof studs will still be in the way since I don't want to lower my ceiling to 220cm height. Going Atmos 7.2.2 will have the same problem that the ceiling speaker will be sitting smack bang against the next exposed roof stud.
      What would be the best option if not DTS-X
    • By Primare Knob
      I am looking into building a home theater room in my garage. The max size (external) is 2.57 height, 4.35 width, 6.00 depth.
      Started my research about golden ratios, of which there are a few and then came across this website which seems to be to most modern one.  http://www.acoustic.ua/forms/rr.en.html
      Funny thing is that almost none of the known ratios come out very well in this new model.
      I also came across this link on the forum http://www.bobgolds.com/Mode/RoomModes.htm but I am not sure how to use or read this.
      Getting the impression that there are different ideal shapes for music or HT rooms, like the trapagon.
      Lots of confusion about dimensions and shapes at the moment.
      The things I want to achieve in this room is.
      7.(2) audio setup expendable to 7(.2.)4
      Center speaker behind screen
      min of 3.5 meter viewing distance from screen
      min 4.4 projector throw distance
      5 seats 2 rows
      Great sound
      The garage is double brick, concrete slab, front and back roller doors and would need to build a new side wall to create the room with entrance door, flat colorbond roof 10cm insulated and particle board lining with 8 exposed timber beams over the width hanging 27 cm down form ceiling.
      I would like to do the room build myself. What guidlines to follow in creating the shape and dimension.
    • By harmo_hammer
      Hi All,
      I have used PBK on and off for a couple of years now. When dealing with my Monitor Sub 12s, the difference the PBK made wasn't always huge, but it flattened the response quite well. I recently had the good fortune to acquire a Paradigm Studio Sub 15 at a vastly discounted rate. After lugging and placing the fifty-something kilo beast into place, I was...  frankly too stuffed to worry about the room correction. I plugged it in, and started to watch "Day After Tomorrow"... excited to experience nice bassy goodness. I was not disappointed.
      About 5 minutes into the movie, there's a guy drilling into an ice shelf, and all hell breaks loose as a few thousand tons of ice breaks off and falls into the sea... This is where the 15" sub reached down, and physically shook the house. The cracking of the ice was just wow! Perhaps there were some room-based quirks that happened to emphasize some frequencies, but I certainly didn't care at that point, I knew I was going to correct it later, expecting the sound to improve, and at the very least, perhaps reign in some of the peaks and troughs.
      The next day, I updated the firmware in the 15", and then fired-up Paradigm's "Perfect Bass Kit"... which is a sub-specific version of Anthem's Room Correction (ARC), and did a fairly standard calibration.
      I watched the same scene, and the physical impact was gone. There was no amazing crunch, thump, or boom, no really deep extension. It was as if the power and majesty of the bass, was reigned back beyond what I would have chosen for it. I've been meaning to have a look at it, but haven't quite gotten to doing a proper investigation yet.
      I just want to see if anyone else has had similar, or completely different experiences with PBK. Any settings I should try?
      Any advice, thoughts, suggestions are welcome!
      All the best!
      Hamish.
    • By BenQ Australia
      Hi StereoNet,
      We’ve designed the treVolo speaker for those who love classical, acoustics and accurate sound in a portal format.
      If this fits your style! BenQ Australia is confident you’ll enjoy our treVolo. We’ve teamed up with Kogan to bring you a 30 Day Money Back Guarantee program. Purchase a treVolo for yourself or someone you know that'll appreciate it. If you're dissatisfied within 30 days, simply return it for a full refund with the required information as found on the T&C's.
      Offer ends: 30th of September so be quick!
      Limited to one (1) treVolo per customer
