Jventer
REW and acoustics - help needed please
163 posts in this topic
Can someone please point me to a resource to teach me how to interpret waterfall graphs.
I am trying to measure my room and fix it. Any help will be appreciated.
Edited by Jventer
@Jventer have you seen this from Paul Spencer. Setting up the axis scales properly helps if you haven't sorted that out.
http://redspade-audio.blogspot.com.au/2011/05/rew-understanding-decay-and-waterfall.html
I am in the same boat. Plenty of discussion threads out there including this SNA thread. A lot of it is bass focused. I'd appreciate seeing some example plots with basic commentary such as 'this room is work well except for X and Y'.
The GIK videos are OK for getting a feel for things, including this one which is a basic REW tutorial. You may have seen this stuff?
Can you post some of the plots you've generated. Some examples of my output are posted here.
I'm going to invest some more time into it so if I find anything worthwhile I'll let you know.
Thanks @adamg
I have spent many hours this week doing sweeps and reading REW stuff.
I have a basic issue, I just want to improve my room for 2 channel. It looks like a lot of the info relates to DSP and HT.
I am grappling to understand all the terms and jargon.
Will post graphs and look at your post.
I have now read a lot more, including what @adamg has referred me to.
My interpretation is that I have lots of issues, including bass issues, modal ringing etc.
Big problem is that I still don't understand that much. I really need help please.
Room is 4.4 m wide, 4.6 m long, 2.4 m ceiling. Speakers are at this stage about 35cm from the wall. Listening position is 3.5m from speakers. Left wall has a bay window providing space to the left. Right wall has an open arch way opening into another room. Back wall has an opening as well, basically opening into an entrance and stairs going to second floor.
I can do lots of things in the room if I know what I am supposed to do. It is a lounge, HiFi and TV room that will become HT room too.
Speakers: Osborn Eclipse Tower Reference. That is 3 way with extra low range.
I have lots of graphs and would like to start with these. Measurement is at the listening position. Both speakers together.
@adamg, @svenr, @davewantsmoore, @KenTripp - your help will be much appreciated.
SPL 1:6 smoothed 5:2:17.jpg
Edited by Jventer
Edited.
Edited by Jventer
For the presentation of data in REW, familiarise yourself with the "limits" button.    The handy thing about limits is that it defaults to your last setting, and a convenient way to ensure your charts have the same scale  (making them much easier to read/compare)
General rules:
  • Where you place the microphone is important.   I assume it's in the listening position for now.
  • If you want to take two measurements to be "compared" with one another.  Then the microphone needs to be in exactly the same position.
  • If you post charts where the mic is in different positions, then make sure you say this.
  • Just measure one speaker at a time (eg.  only L, or only R)
Your data shows:
  • You have a very significant 50Hz hum
  • You are probably capturing the output of the L and R speaker together (!?), and/or you have quite a live room, that will benefit from some extra absorption.
  • You could do with some EQ for the bass
2 people like this
@davewantsmoore
Thank you so much for the reply. Much appreciated.
Yes, I have measured the two speakers together.
Measurements are at listening position.
Interesting the 50Hz hum then again at 100hz and repeating at some 50 and 100hz intervals.
What is happening at 400hz?
Which listening position@davewantsmoore ? Most people have two ears and the brain doesn't just 'sum' the inputs, or everything would sound 'combed' and 'flanged' to everyone. For a microphone to 'hear' a speaker as a human does there has to be two microphones at ear distance apart, and they have to be power summed, not just have acoustic pressure amplitude and phase added together.
@Jventer  are you talking about audible prominences at those frequencies, or are you seeing an artefact of combining multiple sources in your plots, namely multiple speakers which may be one speaker and its virtual images in the room, not necessarily two 'real' speakers.
Edited by johnmath
The dip is likely caused by a reflection (eg. from the floor) ....  the reflected sound, is exactly out of phase with the direct sound at 400Hz, and they cancel each other out.
You can test this theory, by changing the location of the microphone.    Make it a drastic change to illustrate the effect (like move the mic to be 30cm from the speaker).   You should see that the dip disappears, or moves to a different frequency.
Setup REW to output to just one .... or just disconnect one.
That isn't what is being attempted here.
Just a plain 2 channel layout where I have the mic pointing straight to the front - about midway where my ears were if I sat there.
I can hear the hot bass.
I think I understand that, but isn't the objective to improve the *listening* experience?
That's fine.  The precise positioning of the microphone is relatively unimportant (at this stage).
... but if comparing multiple sweeps, then they all need to have had the mic in the same position.
1 person likes this
First objective is to quantify the speakers in-room response ....  and make inferences about the room acoustics.
... and you don't need/want the microphone to "hear like a person" ... you need a regular measurement mic.
Edited by davewantsmoore
Well that's true in one sense and false in another; and the failure of people to appreciate that nuance has constrained the development of stereo reproduction for decades. But my comments aren't helpful in this thread, so I will shut up now.
Edited by johnmath
1 person likes this
11 hours ago, Jventer said:
Here are left right and combined results.
Edited by Jventer
Here are a few photos.
Recently moved into rental, don't like the low ceilings and the paint colour and lots of other things, so planning lots of changes, subject to measurements :).
Do you like my makeshift microphone stand?
Remove the couch/chair (keep the mic in the same place) and compare .... or first just move the mic forwards ~ 1m
1 person likes this
Yes.
How loud (subjectively) are your measurement tones?  Some of those readings are quite low.
8 hours ago, davewantsmoore said:
Yes.
Good point, I first started making measurements at a certain level, then went higher, and then last night I forgot about the higher level and went down to the lower level.
I will in the next two days start at the same position but at higher level. Then do measurements at different points as you suggested.
Thanks a lot for the assistance.
@Jventer
Back of an envelope calculation (if just floor bounce) ...
3m from speakers 1m above floor;  floor bounce cancellation is at 285Hz (roughly).
However, the lounge will most definitely be providing pretty drastic path difference reinforcements and cancellations.  So I would get it well out of the way as @davewantsmoore suggested.
I get all sorts of peaks and troughs simply from my leather chair being in close proximity to the mic;  been there, done that.
[OT:  I have often thought that the chair is actually there when we listen so maybe we hear some of those peaks and troughs anyway.  I suppose that when a body is sitting there and is an absorber rather than a reflector, then the effect might not be as pronounced.  Could be measured I suppose.  3 measurements; nothing there, chair only, chair with sitting person.  Compare.]
1 person likes this
Measure at ~90dB+ in the listening position.    You will find this is quite loud (I would recommend hearing protection if you are close by)
Like you say, working out what is the cause of what you see in the charts is the current mission.
Correcting (using EQ) the peaks and troughs caused by a couch has a lot of caveats, and is generally a bad plan..... they'd likely be better off left alone.    Like many people love to quip - humans don't hear like the microphone.
Perhaps Dave, John & others could comment on my below statements (as I too am learning how to use REW):
  1. if you look at Jventer's last graph and mentally smooth it out ... you get a basically horizontal line @ 45dB below 600hz and at 48dB above 600hz.
  2. the lower line extends to 15hz (which is sensational! :thumb: ) but there is a steep roll-off from about 16Khz.
  3. what do you suggest is the cause of this 16Khz roll-off?  (NB: we'll assume Jv is using a calibrated mic.)  Is it just your typical room absorption?
  4. my own smoothed REW plot is tilted - ie. it's a line which is higher at the LF end and lower at the HF end (sorry, I can't post it now bcoz I'm away from home).  This is with the (calibrated) mic at the listening position.
  5. yet when I sit down and listen ... I am not overwhelmed with bass.  In fact, my system sounds balanced - and people who have come round to listen ... have agreed.  :)
  6. looking at Jv's (mentally smoothed) graph and comparing it to mine ... I would say Jv's is 'light on' in the low bass ... and too bright in the treble.
  7. what do you guys say.
Thanks,
2.    Measuring at 16khz is tricky....   Moving the mic slightly, or surfaces nearby can change the data captured.....   what I see in the chart if that it is within +/- 2.5dB above 1khz  (ie. there is no massive rolloff) .... but even if you did "call" this a rolloff .... it is likely to do with where the mic is, the couch, etc. etc ..... and if you took many more measurements (including close to the speaker, carefully aligned to the tweeter axis) you'd see different things.
3.  No
4.  Good.
5.  Expected.
6 (and 1)  I see JVs data as basically flat (if you ignore large dips, which are likely modal or SBIR cancellations) .... but agree it should be more tilted like yours  (which is why I commented he "needs some EQ for the bass")
7.    More data is required before some of these inferences can be supported.
1 person likes this
    • By robmid
      I just picked up a virtually unused REL Quake sub for $175 and thought I would give it a go with my LS50's.
      The aim was to enhance the bass without interfering with the natural attributes of the LS50's.
      I have found that using REW setup to measure in room humps and bumps and doing a sweep with the sub OFF then another sweep with the sub ON works well. After a bit of tweaking the sub level, moving the LS50's and sub around everything suddenly came together. A crossover of around 35hZ seems to stop any muddiness or bloat around 80hZ in my room.
      I would assume the REL T-5'S would be better but the Quake has really given my LS50's some real weight without destroying the magic. I have tried a REL T-Zero. It improved bass but didn't have quite enough bottom end weight for me.
      Green trace is LS50's with sub OFF and orange with sub ON.
    • By robmid
      My listening space is relatively small and it isn't practical to move furniture around and it is an awkward space with one corner on the left which is partly enclosed by the side of a cabinet. The right side of the room opens into a void with a high ceiling so I get no reflection from that side. The left side has sliding glass doors and curtains so it sounds different with the curtains closed.
      I have found that my KEF LS50's respond dramatically to positioning and my REL T-Zero sub crossover frequency and level are very difficult to optimise because the LS50's are so responsive that introduction of extra bass can have a dampening effect on their sound.
      I was unable to get the balance right after messing around for months trying to balance my sub and position the LS50's optimally.
      I knew there were an enormous amount of REW users but I didn't think it applied to me because I couldn't make physical change to my room. WRONG!
      I installed REW on my Mac and used the inbuilt mike but the readings weren't very informative. I didn't want to spend hundreds of dollars on a calibrated mike but as luck would have it, Loud Speaker Kits had Dayton Audio iMM-6 mikes for around $25 so I splurged.
      After a some experimenting and variable results I got the hang of it. I took readings without the sub and was able to optimise the LS50's bass response by positioning alone. I couldn't get rid of a dip around 400 hZ but I don't notice any deficiencies.
      This gave my my benchmark for the main speakers.
      Optimising the sub suddenly became simple because I was able to adjust the crossover frequency to eliminate peaks then adjust the level to give a nice smooth balance between the LS50's and Sub which now pressurises my room nicely despite the unconventional shape of my room.
      Now I have an amazing sounding system with gutsy, clean musical bass that has become an extension of the LS50's plus I don't have to get up all the time to fiddle with my sub any more.
      Everybody NEEDS to make REW part of their system even if they can't modify their listening space.
    • By robmid
      Hi all.
      I am using REW 5.6 on a Macbook.
      The graph looks to be ok but I thought the trave should be sitting near 0dB but traces are sitting around 50db. I have configured the sound card, adjusted speaker level, mike input level and dBFS Level is sitting on -12dB and I have adjusted that but it is the same as adjusting the amp level.
      I can calculate dB variations but I am wondering if there is a config that allows me to do that apart from adjusting Data Offset for each reading.
      I am using a calibrated Dayton Audio iMM-6 for measurements.
      Can anyone point me in the right direction please?
    • By Jonesy_SA
      *Please Read Disclaimer at end before posting*
      Hi all
      I’m pretty excited with what landed on my desk today; 2 x 1 inch tweeters and 2 x 5" woofers.
      These are OEM from discontinued products, most likely manufactured by Tymphany/Vifa, in turn specifications such as TS and FR are unavailable; which partly explains my purchase. I have assembled speaker kits before but thought it would be fun to measure some drivers myself in order to produce a 2-way bookshelf system from scratch.
      Driver data as provided by seller:
      Tweeter
      Tweeter: 25mm Soft Dome, 40 Watts – 120 Watts, 8 Ohm Nominal, 25.5 Hz – 20 KHz, Diameter: 94 mm, Cutout Size: 70mm
      Woofer
      Data 50 Watts RMS 100W peak, 4 Ohm, 88 dB, 54Hz, 1" Voice Coil, Poly doped, treated paper cone. Double magnet. Dimensions: 148mm frame, Cut out size: 120mm
      Having trawled Google images I'm pretty confident these came paired in a bookshelf with the following specs:
      Crossover Point 1.9kHz, Nominally 6 ohms, Bass reflex rear vented, Dimensions 295mm high x 175mm wide x 240mm deep, Volume 7 litres internal.
      With that said my plan is to approach from a clean slate and not replicate existing designs. I have never measured TS or FR or designed a crossover so I’m hoping you knowledgeable folk can jump in and assist.
      I am unable to find a good reference explaining how to measure drivers and implement in a system, however my understanding of the process is:
      (1) Measure TS parameters of woofer,
      ARTA:
      http://zobsky.blogspot.co.uk/2008/01/simple-loudspeaker-measurement-jig-for.html
      REW:
      http://www.avsforum.com/forum/155-diy-speakers-subs/1340740-lilmikea-s-diy-impedance-measurement-jig.html
      However this article raises issues with TS data and enclosure design.
      http://www.troelsgravesen.dk/ports.htm
      (2) Design and build enclosure from TS parameters
      (3) Perform frequency response testing of drivers mounted in enclosure (I think I need to obtain the impedance response of the drivers as well)
      (4) Create crossover from data
      (5) Enjoy
      (If you have a relevant link please post it – links above are indicative of how I will approach that aspect)
      Two software suites come to mind when looking into the above:
      REW
      http://www.roomeqwizard.com/ ... REW manual: http://www.roomeqwizard.com/help/help_en-GB/html/index.html
      ARTA
      http://www.artalabs.hr/
      There are others such as SpeakerWorkshop, SoundEasy etc however they are not free and do not offer lite versions. With that said, I believe most suites use the same algorithms for calculating TS, and REW is apparently quite powerful for FR analysis(?).
      My aim is to update the first few posts with milestones and references to the relevant posts while the entire thread will show chronological order and discussion.
      Feel free to jump in and assist :-)
      Jonesy
      #Disclaimer - I will not post the OEM brand details and would ask respondents follow suit. They are a great company that I have purchased from before and I think its fantastic end of line stock is released onto the market and not made landfill; however they may not like their brand name popping up in a DIY thread from Google searches. I would also encourage those that wish to build a speaker kit perhaps look at Loud Speaker Kit (LSK). Their bang for buck drivers are most likely a better option and their kits are well designed#
    • By Cafad
      OK, so I've downloaded Room EQ Wizard and I'm looking forward to spending many hours playing with it, using it to evaluate my new lounge acoustics and getting very confused about room frequencies and nodes and all that great stuff, but...
      I need a microphone to play with it properly and since I have such a broad range to choose from (from $12 to over $200, and that's just on ebay) I was just wondering, does the microphone matter much?
      Or, to put it another way, which microphone should I buy to share my future analysis trials and tribulations with me.
