dereko
usb dac
13 posts in this topic
Hi all
I have a stereo amp connected to a Win 10 PC and wish to improve HiFi quality. Can I use an amplified USB DAC an connect to the two RCA outputs ? If so any recommendations? Or is there a DAC without a built in amp as I do not need it.
Thanks Derek
Most USB DACs do not have powered or amplified outputs - they are DACs only, although sometimes with headphone amps.
Importantly... what is your price range? USB DACs range from $50 to several thousands of dollars.
thanks pete
Imlooking between $100 to $200
thank you ill check them out
Derek
Both the Dragonfly and Hifimediy DACs don't have typical RCA outputs - you'd need to run a 3.5mm to 2 x RCA cable to your amp. No biggy!
Yeah I think even I can manage that
Thanks Derek
Thanks blakey72
I had a look at the link and the Schiit does look very good.
I now know what to look for as I was looking at gamer cards etc before I joined this forum
Regards Derek
My first DAC was a Topping D2, cheap and had all the connections that I needed. 16bit @ 48khz on USB.
Thanks TEZZA
I will check this one out too.
By the way,how did it perform?
Derek
