tastimp Posted December 4, 2016 Share Posted December 4, 2016 (edited) Hi, I'm seeking some opinions/advice on upgrading my Roon-based set up. I currently have a Dell laptop (I5 processor, Windows 10) connected to my main system. I'm running Roon Server and HQ player on that machine. Music files are on NAS in the study. After the best part of a year with Roon and having decided I'm sticking with it, it's time to get rid of the laptop (and it's fan noise) from my loungeroom. The two similarly priced options I'm thinking about are: (1) Fidelizer Nimitra + LPS, with HQ player in the main system with Roon Server running either on Nimitra or on the laptop relocated to the study. (2) Auralic Aries (the "step-up" version with LPS) in the main system with Roon Server on laptop in study. (It's probably worth adding that if the Roon Server remained on the laptop I would ultimately be looking to upgrade that to something headless/fanless, most likely a Sonic Transporter from Small Green Computer.) Any thoughts welcome! Thanks in advance. Edited December 4, 2016 by tastimp Link to comment Share on other sites More sharing options...
a.dent Posted December 5, 2016 Share Posted December 5, 2016 Have you considered a Sonore microRendu or SOtM SMS200 as end point with Roon server on the laptop (in the study)? They are very neat solutions. Link to comment Share on other sites More sharing options...
tastimp Posted December 5, 2016 Author Share Posted December 5, 2016 Have you considered a Sonore microRendu or SOtM SMS200 as end point with Roon server on the laptop (in the study)? They are very neat solutions. I had considered the microRendu but I need something that will connect to the network wirelessly so ruled it out. I notice that wireless connectivity is in the pipeline for the SMS200 so that is now in the picture. Thanks for pointing me in that direction. Link to comment Share on other sites More sharing options...
tastimp Posted February 16, 2017 Author Share Posted February 16, 2017 Have you considered a Sonore microRendu or SOtM SMS200 as end point with Roon server on the laptop (in the study)? They are very neat solutions. So, I now have SOTM SMS 200 and am very happy. Thanks! 1 Link to comment Share on other sites More sharing options...
doomigee2 Posted February 18, 2017 Share Posted February 18, 2017 Having just upgraded from a bluesound node 2 to an Aries- I would strongly recommend the aries. It's great and sounds significantly better than my bluesound. I have the LE version with a geiseler psu Software is good too, might even be good enough to replace roon Link to comment Share on other sites More sharing options...
