jackrinse Posted October 23, 2016 Share Posted October 23, 2016 I am based in Sydney and looking for a new rack to accommodate very large vintage amp and pre + a couple of other bits. It doesn't have to be built for purpose as HIFI stuff tends to be a lot more expensive. You would think a simple shelving system would be easy to find but it seems not. Has anyone seen any affordable solutions in Aus that look like these? Link to comment Share on other sites More sharing options...
jackrinse Posted October 23, 2016 Author Share Posted October 23, 2016 Or maybe like these? Link to comment Share on other sites More sharing options...
Keith_W Posted October 23, 2016 Share Posted October 23, 2016 Get a furniture maker to make them. It might cost about $1000, depending on your choice of wood. Link to comment Share on other sites More sharing options...
jackrinse Posted October 23, 2016 Author Share Posted October 23, 2016 Yes, I think you are right. If you found an "off the shelf" (pardon the pun) solution, it would cost a lot less. I may go the custom route if nothing becomes available. Link to comment Share on other sites More sharing options...
Nada Posted October 23, 2016 Share Posted October 23, 2016 DIY- Ikea Lack Table Audio Rack 2 Link to comment Share on other sites More sharing options...
jackrinse Posted October 23, 2016 Author Share Posted October 23, 2016 My wife and I have enjoyed lots of Ikea furniture but we are trying to buy more substantialy built pieces these days. The Lack Hack certainly.photograph well though. Link to comment Share on other sites More sharing options...
Nada Posted October 23, 2016 Share Posted October 23, 2016 7 hours ago, jackrinse said: Yes, I think you are right. If you found an "off the shelf" (pardon the pun) solution, it would cost a lot less. I may go the custom route if nothing becomes available. Whats your budget? Link to comment Share on other sites More sharing options...
jackrinse Posted October 23, 2016 Author Share Posted October 23, 2016 Hi Nada I don't really know until I come across something I like. Right now funds are low but I know I need something and I want to buy this side of Christmas ideally. I just picked up an old power amp and loved it that much I bought the matching pre from Russia the next day. In truth, I could not really afford it but you know how it is. So the best answer I could give is - Cheap option - Purchase a perfectly formed solution on Ebay for $100 Less cheap option - find some local wiz who builds beautiful things and I could buy something for over a grand but it would be something I would treasure for a long time. Link to comment Share on other sites More sharing options...
Full Range Posted October 23, 2016 Share Posted October 23, 2016 Gumtree is a good place for this type of stand, however they are generally described as TV unit or entertainment display unit and so forth alternativly you can get a solid timber drawer unit and replace the draws with shelves http://www.gumtree.com.au/s-ad/moore-park/other-furniture/chest-of-drawers-and-tv-stand/1127160718 http://www.gumtree.com.au/s-ad/meadowbank/other-furniture/television-stand/1127002261 Link to comment Share on other sites More sharing options...
jackrinse Posted October 23, 2016 Author Share Posted October 23, 2016 @Full Range Yes I was just looking at some coffee table options and entertainment units. The draw idea is good. I will have a good look at the draw available. Thanks Link to comment Share on other sites More sharing options...
Guest BobbyD Posted October 23, 2016 Share Posted October 23, 2016 Like this? Link to comment Share on other sites More sharing options...
Keith_W Posted October 24, 2016 Share Posted October 24, 2016 I was just browsing their website, and saw these: http://www.wyndhamaudio.com.au/collections/types?q=Hi-Fi Racks Link to comment Share on other sites More sharing options...
blybo Posted October 24, 2016 Share Posted October 24, 2016 (edited) @jackrinse how are you at DIY? You can find everything you need at Bunnings. Buy; 3 solid or laminated wood panels and cut to size. 6 (9 if you want a wooden leg below bottom shelf) pre threaded uprights (legs) of desired heights, biggest leg is 230mm. 6 (9) thread inserts to go into bottom of each panel which legs simply screw into. All you would need is a drill and hammer to build it. paint/stain to taste and you are done. I'm seriously looking at doing this in my family room with a pre-ordered Bamboo panels athough I'll also use some audio spikes & shoes to bing up the "isolation" between each section. I don't expect it to make any sonic improvement, but will look more audiophile in presentation. https://www.bunnings.com.au/our-range/brands/l/leggz Edited October 24, 2016 by blybo Link to comment Share on other sites More sharing options...
BATMAQN Posted October 24, 2016 Share Posted October 24, 2016 Probably not much WAF here they are a bit more industrial looking very adjustable though. Link to comment Share on other sites More sharing options...
jackrinse Posted October 24, 2016 Author Share Posted October 24, 2016 @Keith_W Great stuff Keith however out of my range. Link to comment Share on other sites More sharing options...
jackrinse Posted October 24, 2016 Author Share Posted October 24, 2016 @blybo @BATMAQN Yes I have priced up the black threaded rod and loads of nuts and washers already.. $150 gets it all and then you need shelves. Still have this idea on backup Link to comment Share on other sites More sharing options...
BATMAQN Posted October 24, 2016 Share Posted October 24, 2016 Yeah the perspex is where the money cut's in about $300 for 6 shelves from memory @600x600 Link to comment Share on other sites More sharing options...
rocky500 Posted October 24, 2016 Share Posted October 24, 2016 Someone on here mentioned they bought one of these. http://classaaudio.com.au/index.php?id_product=311&controller=product http://classaaudio.com.au/index.php?id_product=878&controller=product I considered one but found something off gumtree. I might try those laminated panels at bunnings next time. Link to comment Share on other sites More sharing options...
blybo Posted October 24, 2016 Share Posted October 24, 2016 Yeah the perspex is where the money cut's in about $300 for 6 shelves from memory @600x600 I think bamboo will be more expensive again. Probably $600-700 for 3x 1200x600x32 shelves Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
BATMAQN Posted October 24, 2016 Share Posted October 24, 2016 1 minute ago, blybo said: I think bamboo will be more expensive again. Probably $600-700 for 3x 1200x600x32 shelves Sent from my iPhone using Tapatalk Woah Link to comment Share on other sites More sharing options...
blybo Posted October 24, 2016 Share Posted October 24, 2016 Woah Well no quote yet but they all seem to be cut from 2400 lengths so I'll have a spare shelf which I'll have to pay for. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
jackrinse Posted October 24, 2016 Author Share Posted October 24, 2016 @BATMAQN I currently have the same Sound Organisation stand that you have in black, mine is silver. I will be selling it to fund the new rack (partially)do you need another ;o) Link to comment Share on other sites More sharing options...
BATMAQN Posted October 24, 2016 Share Posted October 24, 2016 26 minutes ago, jackrinse said: @BATMAQN I currently have the same Sound Organisation stand that you have in black, mine is silver. I will be selling it to fund the new rack (partially)do you need another ;o) Thanks for the offer mate but I'm not after any more racks just means I have to buy more gear to fill it done enough of that already time for a financial rest. 1 Link to comment Share on other sites More sharing options...
jackrinse Posted October 24, 2016 Author Share Posted October 24, 2016 http://www.ebay.com.au/itm/351462372811?rmvSB=true This is nice but not quite deep enough. Link to comment Share on other sites More sharing options...
jackrinse Posted October 24, 2016 Author Share Posted October 24, 2016 1 hour ago, BATMAQN said: Thanks for the offer mate but I'm not after any more racks just means I have to buy more gear to fill it done enough of that already time for a financial rest. What are they worth, $100? Link to comment Share on other sites More sharing options...
